Solved Silacone sock for mosquito
16055140473776388353493397964383.jpg Could not find a sili! sock for my mosquito hotend so i down loaded a mold i thought it turned.out realy good for.high temp silicone got the mold off of thingiverse in case you need one too
1..My question is if i add the sock now i should retune my p.i.d.???? And
2...when i give the gcode comand does it override the previous entry automaticaly... -
yes
and if you make a M500 after the tuning then yes
@ziggymanpopo said in Silacone sock for mosquito:
yes
that depends how you are saving it.
if you use m500 then yes.
otherwise you have to add it to the config.g manually. -
https://www.aliexpress.com/item/4000172934426.html
but the orignal mosquite does not come with a sock, so i take it they did not design for one to be used.
this makes sense, as the silicone would be detrimental at very high temperatures. -
I concur the silicone is good for about 375C sustained. and intermittently to just over 700C according to the manufacturer it would have to be remover for larger print times above 400
Thanks veti
Lol -
Its only a hobby
@Veti said in Silacone sock for mosquito:
this makes sense, as the silicone would be detrimental at very high temperatures.I'm using them and they work very well.
Thanks. All
