    First Layer and Extrusion Problems
    5.6k
    • fcwiltundefined
      fcwilt @A Former User
      @CaLviNx said in First Layer and Extrusion Problems:
      and besides the point there is still NO NEED to add a macro to send the "probe/nozzle" to the centre of the bed when you can 100%
      Not completely true.
      There are other times when you need to set the Z=0 datum such as when creating a height map or loading it.
      It is important to use the same probe point. The macro I use insures that the same point is used in every case. There is no chance for a typo or my faulty memory to cause a problem.
      • fcwiltundefined
        fcwilt @Frederik
        @Frederik said in First Layer and Extrusion Problems:
        @fcwilt you are right, I meant probe. It's all a bit confusing in the beginning 🙂
        I understand which is why I strive to be as clear as I can and not say things that are potentially confusing or abiguous - and yet it still happens.
          A Former User @fcwilt
          @fcwilt
          Sorry but if you are using x3 leadsrews it would naturally be good practice to be initiating the bed.g file after homing and then applying the correction and after that correction has been applied you would have the head/probe/nozzle RE-Probe in the centre to re-establish the datum before printing commences.
            A Former User
            For example everything gets done at once
            ; bed.g
            G28                         ; Home all
            G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw
            G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw
            G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw
            G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw (Second Pass)
            G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw (Second Pass)
            G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw (Second Pass)
            G91                         ; Switch to relative positioning moves
            G1 H2 Z5 F8000              ; Drop the Z axis (the bed) by 5mm relative to its current position
            G90                         ; Revert back to absolute positioning moves
            G1 X160 Y155 F8000          ; Position the nozzle at the centre of the bed
            G30                         ; Probe and set the height as probed
            G29 S1 P"heightmap.csv"     ; Load the height map
            • fcwiltundefined
              Yes if you do everything in bed.g you are having the probe point only specified in that one location.
              But not everyone does it that way. I certainly don't.
              My bed.g file only auto-levels the bed and sets the Z=0 datum.
              But there are other times when setting the Z=0 datum is important.
              For example I have more than one height map that is loaded depending on the state of a fan name that I am current using in lieu of variables.
              The macro that loads the height map uses a few others macros. One configures the probe, one positions the probe to bed center, one does the probing.
              To position the probe to bed center I don't have to remember the correct XY values I simply call the macro and it does the math and positions the probe.
                @fcwilt
                so does that one above......................
                • fcwiltundefined
                  @fcwilt
                  But if you have to set the Z=0 datum somewhere else you have to remember to use those same values.
                  • Frederikundefined
                    Frederik
                    so i hope i changed everything accordingly.
                    after i run a mesh i got this hightmap
                    and this the consol putput:
                    20.11.2020, 22:08:00	G32
                    Leadscrew adjustments made: 0.283 0.880 0.293, points used 3, (mean, deviation) before (0.453, 0.263) after (-0.000, 0.000)
                    Leadscrew adjustments made: -0.044 0.333 -0.061, points used 3, (mean, deviation) before (0.053, 0.172) after (-0.000, 0.000)
                    Height map loaded from file heightmap.csv
                    20.11.2020, 22:05:43	G29
                    156 points probed, min error -0.837, max error 1.678, mean 0.186, deviation 0.523
                    Height map saved to file heightmap.csv
                      @fcwilt said in First Layer and Extrusion Problems:
                      why would a beginner (as it was you that put the beginner thing out there) require to be going down the route of setting a Z=0 elsewhere ?
                        A Former User @Frederik
                        @Frederik
                        do you have a picture of your setup ? (as in the printer itself)
                        Frederikundefined 1 Reply Last reply Reply Quote 0
                        • Frederikundefined
                          Frederik @A Former User
                          @CaLviNx IMG_20201120_221537.jpg IMG_20201120_221704.jpg IMG_20201120_221621.jpg
                          My Printer is a Ratrig VCore Pro Kit with the EasyMod and EVA Carriage.
                          I startet my journey into 3d printing around 4 weeks ago with Information gathering etc...
                          ... And 4 days ago, I finished the build.
                            @Frederik
                            if it was me I would firstly tension the bed to bed frame springs, then measure them and make they all the same height, perpendicular to the bed frame.
                            Then I would home all with the final homing of Z axis taking place with the probe located at the bed centre.
                            Then I would have the printer carry out a G32 (more than once) NOTHING else, and allow it to "level" the bed/frame using the three lead screws, and allow it to apply those corrections .
                            Then carry out a single G30 probing at the centre of the bed to re-establish the datum point.
                            Then finally carry out a G29 and see what it comes up with.
                            You need to remember level doesnt mean flat..... and dont get too hung up on the graphic look at the amount of deviation you have.
                            how many linear rails does the z axis run on ?
                            • Frederikundefined
                              @CaLviNx Ok, i will test this in the morning.
                              I have 2 Linear Rails on z ( left + right in the middle ). The Leadscrews are ~ 6 cm in front of them
                                A very strange (to me anyway) arrangement for linear rails, in that you would expect 3 rails with three lead screws.
                                But if it works then happy days. Personally I always have x3 rails/lead screws and have the bed frame with a degree of articulation to allow the levelling to operate as it should, once you get it setup the levelling gives you great prints
                                • Vetiundefined
                                  Veti
                                  M671 X425:200:-25 Y240:-25:240 S1 ; leadscrews at front left, rear middle and front right
                                  how are these points near the leadscrews?
                                  • Frederikundefined
                                    @CaLviNx That´s how this kit is designed. Eventually, I will change it to a kinematic mount without the 2 Linear Rails like the HevOrt. At the moment I have a battle with my E3d Volcano... it is constantly clogging and I don´t know what
                                    I´m doing wrong... trying to print PLA with ~ 205 ° Nozzle and 60° Bed.
                                    • Frederikundefined
                                      Frederik @Veti
                                      @Veti i have this settings:
                                      M671 X425:200:-25 Y240:-25:240 S3 - position of Spindles with drives 2.3.4
                                      and this are the spot i´m probing:
                                      G30 P0 X330 Y250 Z-99999 ; Probe near the front left lead-screw
                                      G30 P1 X165 Y0 Z-99999 ; Probe near the rear lead screw
                                      G30 P2 X0 Y250 Z-99999 S3 ; Probe near the front right lead-screw
                                      • Vetiundefined
                                        Veti
                                        is 0,0 not the bottom left of your printbed?
                                        • Frederikundefined
                                          Frederik @Veti
                                          @Veti x0,y0 ls in my case the right, rear corner
                                          • Frederikundefined
                                            Frederik
                                            I could only mount the Endstop on the left side of my carriage and the Y Endstop is at the back
