Solved Duet3 config Frustration
@Veti
Does that mean they used the 3.3v instead of the 5v? -
@BlueDust I wouldn't read too much into it. That particular case could have been any number of things.
However, if you find you're having troubles here is the relevant doc from antclabs on how to switch between.
@Phaedrux
AntLabs says the BLTouch 3.1 is 5v, and don't want to confuse myself any more on this if I don't have to. I was just curious as I remember older BLTouches needed resistors or something to make them work on the Duet boards. The documentation on Antlabs website in relation to Duet seems old and trying to keep this simple as it was on the Duet2Eth as I use a BLTouch 2.2. They seem to change things up often and I don't mind making a mistake and fixing it, but don't want to break anything and have to buy a new one for something dumb I did (like not reading the instructions).3Pin: Brown (GND), Red (+5V)
Orange (control signal)
2Pin: Black (GND) White (Zmin)As always. Thanks for the help!
Duet3 is 5v tolerant so you shouldn't need to change anything on either the duet or BLTouch. It's been that way for a long time now. Should be plug and play.
@Phaedrux
Is the GPIO Port # referring to the io#.in? Where the number would match where the BLTouch is plugged in?M280 P0 S80 ; set 80deg servo position on GPIO port 0
Thanks
@Phaedrux
I read something on one of the Z Probe M commands and it made me think it was a heater.
Self test works now... -
@BlueDust said in Duet3 config Frustration:
@Phaedrux
Thanks
M280 P0 refers to the M950 S0
The pin name refers to the servo control pin and the probe signal input pins.
Did you get it figured out?
@Phaedrux
Yes, I think I figured it out as I can now home the printer, and BLTouch is working. But found another issue, this time with my PanelDue. I am trying to find the max/min places for each tool using the PanelDue and it's not working.My PanelDue is only updating temp/axis location after reset (of the PanelDue), but appears to stop after I start moving the motors (homing right now). I am guessing it is interference... Controlling the printer always works. Updating current info on the screen is the only thing that stops working.
PanelDue is on 3.2, and Duet3 is on 3.1.Thanks!
Stick with 1.24 on the Panel for now. Will work better when the Duet is also on 3.2.
OK thanks!
Any idea when RepRap 3.2 will be released? I am only looking for a guess.
Sometime this month? -
I just wanted to see this new printer print. And guess what, it's printing. But the part fan isn't turning on automatically. I have to turn it on manually. This must be that F setting on the tool I was playing with before but have no idea how to set it... As I can manually turn the fan on, and it turns on, on the correct tool from DWC... I am not sure what to do to fix this at the moment.
Tool part cooling fan is swapped. That is the problem. Where do I make that change?
Post your config.g file [again] and we'll tell you.
So I think I fixed it, as it appears to be working right now... Will not know until I print something with the 2nd tool...Is this is my current gcode.
Looking at this...
M563 P0 S"LeftExtruder" D0 H1 F0:1Does the 0 and 1 match up with the Pn parameter under the fans? If it does, I am having a hard time understanding what goes to what between the different Gcode commands, as the letters do not match from one to the other. If it's not obvious, I haven't figured out the logic and not able to easily make the connections to different settings in RepRap 3 yet...
; Fans M950 F0 C"out5" Q500 M106 P0 S0 H-1 M950 F1 C"out8" Q500 M106 P1 S1 H1 T40 M950 F2 C"out4" Q500 M106 P2 S0 H-1 M950 F3 C"out7" Q500 M106 P3 S1 H0 T40 ; Tools M563 P1 S"RightExtruder" D1 H0 F2:3 G10 P1 X0 U0 Y0 Z0 G10 P1 R0 S0 M563 P0 S"LeftExtruder" D0 H1 F0:1 G10 P0 X0 U0 Y0 Z0 G10 P0 R0 S0
The F parameter in M563 matches up with the F parameter in M950 and the P parameter in M106.
Thank you!
If I would like to have independent Z motors on a IDEX Cortesian printer for auto bed tramming, would DUET 3 EXPANSION BOARD 3HC, be the correct expansion board to get, or is there another, possibly better option? Is there anything else I would need to make it work?
How many of the 6 internal drivers are you using?
The 3HC expansion would probably be the best way to add more drivers, unless you wanted to use tool board for the print head and free up a driver that way.
@Phaedrux
I am using all 6.Left Extruder
Right Extruder
X Axis
U Axis
Y Axis
Z Axis (two motors tied into one driver). -
Similar issue to the fan problem...
If I try to print with the only the 2nd tool, it will heat up and extrudes plastic, but the 1st tool will make the movements.... Thanks for the help!; Drives M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P0.0 S0 ; physical drive 0.0 goes forwards M569 P0.3 S0 ; physical drive 0.3 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M584 X0.1 Y0.5 Z0.0 U0.4 E0.3:0.2 M350 X16 U16 Y16 Z16 E16:16 I1 M92 X160.00 U160.00 Y160.00 Z800.00 E844.45:844.45 M566 X900.00 U900.00 Y900.00 Z12.00 E2000:2000 M203 X6000.00 U6000.00 Y6000.00 Z180.00 E3600:36000 M201 X400.00 U400.00 Y500.00 Z20.00 E10000:10000 M906 X1000 U1000 Y1200 Z1800 E1000:1000 I30 M84 S30 ; Set idle timeout M572 D0 S0.06 ; Pressure Advance ; Axis Limits M208 X-52 U0 Y0 Z0 S1 ; set axis minima M208 X300 U352 Y300 Z380 S0 ; set axis maxima ; Endstops M574 X1 S3 M574 Y1 S3 M574 U2 S3 M574 Z1 S2 ; Z-Probe M950 S4 C"io4.out" M558 P9 C"^io4.in" H5 F100 R0.2 T6000 A5 B0 G31 P500 X-30 Y-12 Z3.58 M557 X30:270 Y20:280 P2 ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 M950 H0 C"out1" T0 M307 H0 B0 S1.00 M308 S1 P"temp1" Y"thermistor" T100000 B4138 M950 H1 C"out2" T1 M307 H1 B0 S1.00 M308 S2 P"temp2" Y"thermistor" T100000 B4138 M950 H2 C"out3" T2 M307 H2 B0 S1.00 M140 H2 M143 H2 S145 ; Fans M950 F0 C"out5" Q500 M106 P0 S0 H-1 M950 F1 C"out8" Q500 M106 P1 S1 H1 T40 M950 F2 C"out4" Q500 ; M106 P2 S0 H-1 M950 F3 C"out7" Q500 M106 P3 S1 H0 T40 ; Tools but hotend cooling does not M563 P1 S"RightExtruder" D1 H0 F2:3 G10 P1 X0 U0 Y0 Z0 G10 P1 R0 S0 M563 P0 S"LeftExtruder" D0 H1 F0:1 G10 P0 X0 U0 Y0 Z0 G10 P0 R0 S0
