    when will the new Z-height actually be saved?
    2.3k
    • achrnundefined
      achrn
      What do you mean 'the old Z-height is still there'?
      You have a trigger height of -0.1mm. Is that not what you want?
      holco62undefined 1 Reply Last reply Reply Quote 0
      • holco62undefined
        holco62 @achrn
        @achrn
        When I do everything according to the dozuki description the height is always 4mm too high, ie the previous height is still there.
        Anycubic Predator - Duet-2 wifi PanelDue - Smart effector
        • achrnundefined
          achrn
          That instruction is to set the probe trigger height. You seem to be talking about something else.
          That set of commands only sets up the trigger height of the probe so that the machine knows where the nozzle is relative to the bed when the probe triggers.
          If what you mean is that you have changed where the nozzle is relative to the endstop switches (by changing the geometry of some or all of the endstops / carriages / rods / effector / nozzle / hotend) you need to re-run delta calibration (G32) not recalibrate the z probe trigger height.
            jay_s_uk
            This post is deleted!
              Please post your homeall, homez, bed.g, start.g and your slicer start gcode section so we can see what is happening.
              The smart effector has a negative G31 Z offset because it contacts the bed and presses into it. So -0.1 sounds fine, but perhaps you have another command altering it after startup.
              • holco62undefined
                holco62
                The G32 (achrn) dit the trick 👍 But what a hassle to sort everything out for a beginner🙃
                What is the way to setup Auto calibrating before each print?
                  jay_s_uk
                  add G32 to your start gcode
                  • holco62undefined
                    holco62 @jay_s_uk
                    @jay_s_uk
                    It looks that I don't have a start gcode in my System Directory, or I can't find it
                    • fcwiltundefined
                      fcwilt @holco62
                      @holco62 said in when will the new Z-height actually be saved?:
                      @jay_s_uk
                      They are talking (I think) about the place in S3D where you can enter gcode to be executed before the start of the print.
                      You can also, if you wish, create "start.g" in your system directory and put gcode there - the firmware executes "start.g" at the start of the print.
                      • holco62undefined
                        holco62 @Phaedrux
                        @Phaedrux
                        I don't know where to find the rest
                        bed.g
                        • holco62undefined
                          holco62
                          Tomorrow is a new day, I have to go to bed now.
                          But thanks for all the help 🙂
                            Phaedrux Moderator @holco62
                            in the /sys folder along with config.g
                            • holco62undefined
                              holco62
                              This all I have in the System Directory
                              • holco62undefined
                                holco62 @fcwilt
                                @fcwilt said in when will the new Z-height actually be saved?:
                                @jay_s_uk
                                Made a start.g directory with a G32 file in it, but for the rest I am lost🤔 Start.G.png
                                engikeneerundefined 1 Reply Last reply Reply Quote 0
                                • engikeneerundefined
                                  engikeneer @holco62
                                  @holco62 he meant create a file called start.g in your duet system directory (/sys folder). In that file, put the line:
                                  G32
                                  To answer your other question on the files, please attach your bed.g and homedelta.g files from the system directory (i can see the file names in the screenshot)
                                  i3 clone with a bunch of mods
                                  • holco62undefined
                                    holco62 @engikeneer
                                    @engikeneer said in when will the new Z-height actually be saved?:
                                    G32
                                    Thanks 🙂
                                    start.g is working, one thing though, it das the calibration with a gold bed/hotend, is there a way to bring up the temps first?
                                    The bed.g and the homedelta.g files
                                    Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                      You could add a bed heat up command to the start of your bed.g. something like.
                                      M140 S60 ; set bed to 60 and continue
                                      G28 ; home towers
                                      M116 ; for for tempts to be reached
                                      G30.... etc ; probe for calibration
                                      • fcwiltundefined
                                        fcwilt @holco62
                                        ...is there a way to bring up the temps first?
                                        Short answer - yes - @Phaedrux has shown a simple approach.
                                        Long answer - there are several different ways to do all that is needed to start a print.
                                        For example, instead of putting everything in bed.g you leave just the essential commands there (the commands you already have) and put everything else (setting temps, waiting for temps, etc) in start.g including the G32 to invoke bed.g.
                                        As you become more comfortable with the firmware there are lots of things possible.
                                        I'm including my equivalent of "start.g" just to give you an idea of the possibilities BUT I am NOT suggesting that you try to adopt anything I have done at this time.
                                        There are lots of extra ; characters there that I added because {1} appeared at the start of empty lines when I pasted the code
                                        ; select tool and configure based on filament selected
                                        T0							; select tool 0 so extruder commands below will work
                                        M703							; configure selected filament (sets bed/extruder temps, extrusion multiplier)
                                        ; check for selected filament
                                        if move.extruders[0].filament = ""
                                          M291 R"No Filament Selected" P"Cannot Continue" S2 T0
                                          abort
                                        ; check bed heater active temp setting
                                        if heat.heaters[0].active = 0
                                          M291 R"Bed Heater Active Temp = 0" P"Cannot Continue" S2 T0
                                          abort
                                        ; check extruder heater active temp setting
                                        if heat.heaters[1].active = 0
                                          M291 R"Extruder Heater Active Temp = 0" P"Cannot Continue S2 T0
                                          abort
                                        ; check if homed - allows homing (OK button) or canceling (CLOSE button)
                                        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                          M291 R"Printer has not been homed" P"Home and Continue?" S3 T0
                                          G28
                                        ; setup to print
                                        M291 R"Preparing to print" P"Please wait..." T0
                                        M106 P2 S255					; lights on
                                        M106 P3 S255					; lights on
                                        M106 P4 S255					; lights on
                                        G90						; absolute moves
                                        G1 Z100     F1200				; position for cleaning
                                        G1 X0 Y-145 F6000				; position for cleaning
                                        M291 R"Heating Extruder/Bed" P"Please wait..." T0
                                        M116							; wait for temps to reach set points
                                        M291 R"Priming Extruder" P"Please wait..." T0
                                        G92 E0							; reset the extruder logical position
                                        M83							; extruder relative mode
                                        G1  E10 F120					        ; prime the extruder
                                        M400							; wait for extruding to finish
                                        M98 P"beep_alert_1.g"                                   ; beep paneldue
                                        M291 R"Clean Nozzle and Bed" P"Click OK to begin printing" S3 T0
                                        M98 P"mesh_comp_map_load.g"		                ; load height map as needed
                                        M118 L0 P4 S"FT5|Print begun"
                                        holco62undefined 1 Reply Last reply Reply Quote 2
                                        • holco62undefined
                                          holco62 @fcwilt
                                            abort
                                            abort
                                            abort
                                            G28
                                          ; setup to print
                                          Thanks, I'll see if I can put something together myself.
                                          • holco62undefined
                                            holco62
                                            I've tried
                                            M109 ; Set Extruder Temperature and Wait
                                            M116 ; Wait for tools
                                            in the start.g file with as last line
                                            G32 ; call bed.g
                                            but when I issue a print command generated by Cura the printer directly starts with G32 and after calibration the bed starts to warm up.
                                            What am I doing wrong?
                                            https://picturepush.com/public/16329875
                                            https://www1.picturepush.com/photo/a/16329875/1024/3D-printers/start-g.png
