    Confused on wiring for Ender 3 Pro Conversion
    1.7k
    • Vetiundefined
      Veti
      hi
      please dont connect the usb while other power is connected.
      see https://duet3d.dozuki.com/Wiki/USB_ground_loops
      have you read this guide?
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
      the config tool is here
      https://configtool.reprapfirmware.org/Start
      • Destruct0Danundefined
        Destruct0Dan
        When ever I connect by USB, I have the power supply cable unplugged from it. I'll check out the guide again and see what it says. Thanks.
        EDIT And this is the guide I have already been using.
          Destruct0Dan
          This post is deleted!
          • Vetiundefined
            Veti @Destruct0Dan
            @Destruct0Dan
            if you set a password its in the config.g that you generated
            i.e
            M551 P"test" ; set password
            Destruct0Danundefined 1 Reply Last reply Reply Quote 0
              Destruct0Dan @Veti
              @Veti Yeah, I went back and set an actual password. Thank you.
                Destruct0Dan
                Now when I start the E3P and everything works fine except I get "ERROR: Temperature reading fault on heater 1: open circuit" I followed all the steps in the setup guide you have linked above. Though the configurator is different than in the guide, it's still pretty straight forward.
                Current temp is showing -273.1c. And when I go to test the heaters, it throws off a bunch of errors and nothing heats up.
                • Vetiundefined
                  Veti
                  what is this test heater macro? that seems to test a second heater that you did not configure.
                  this means that your thermistor is shorted out and has no resistance. check the wiring.
                    Destruct0Dan @Veti
                    @Veti I'm using the Test button that's on the web interface and also on the 7i when I'm looking at that panel. I cut and termed the wires with the pins and connectors for the Duet board. When I copied over from diagram to diagram, it showed the same error. Switched the 2 wires thinking that I may have read it wrong, same error.
                    Vetiundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
                    • Vetiundefined
                      Veti @Destruct0Dan
                      @Destruct0Dan said in Confused on wiring for Ender 3 Pro Conversion:
                      the macro is certainly not for your printer and does not work.
                      check the wire with a multimeter.
                        Destruct0Dan @Veti
                        @Veti Well, guess I have to wait for that to come in. Don't have one. Once I get this, how do I need to test to make sure everything is okay?
                        • Vetiundefined
                          Veti
                          does the bed temperature work?
                          • engikeneerundefined
                            engikeneer @Destruct0Dan
                            @Destruct0Dan FYI, the 'test_xxx' macros (that you're seeing) are the ones that come on the SD card from the factory. They are the end of line tests that Duet3d run with their test setup to check the board, so won't work for your setup. Recommendation is to delete them 🙂
                            i3 clone with a bunch of mods
                            Destruct0Danundefined 1 Reply Last reply Reply Quote 1
                              Destruct0Dan @Veti
                              @Veti No, bed temp won't turn on either.
                                Destruct0Dan @engikeneer
                                @engikeneer Ah okay, thanks. How can I or how do I remove those?
                                engikeneerundefined 1 Reply Last reply Reply Quote 0
                                  @Destruct0Dan via the web control, go to macros to find them, right click and delete.
                                  Otherwise, put the sd card in your PC and delete them.
                                  Might be a way through Paneldue, but I don't have one so wouldn't know how...
                                    Phaedrux Moderator @engikeneer
                                    @engikeneer said in Confused on wiring for Ender 3 Pro Conversion:
                                    Nope.
                                    @Destruct0Dan When you first turn the printer on what do the heater temps report?
                                    Can you post a picture of how you have the thermistor and heater wires connected on the board?
                                    Also post your config.g and the results of sending M122 and M98 P"config.g"
                                    Destruct0Danundefined 2 Replies Last reply Reply Quote 0
                                      Destruct0Dan @Phaedrux
                                          Destruct0Dan
                                            Destruct0Dan
                                            ; Configuration file for Duet Maestro (firmware version 3)
                                            ; generated by RepRapFirmware Configuration Tool v3.1.9 on Sat Nov 28 2020 10:13:54 GMT-0800 (Pacific Standard Time)
                                            M550 P"Ender3ProMaestro2" ; set printer name
                                            M918 P1 E4 F2000000 ; configure direct-connect display
                                            M551 P"REDACTED" ; set password
                                            M552 P192.168.1.23 S1 ; enable network and set IP address
                                            M553 P255.255.255.0 ; set netmask
                                            M554 P192.168.1.254 ; set gateway
                                            M586 P0 S1 ; enable HTTP
                                            M586 P1 S0 ; disable FTP
                                            M586 P2 S0 ; disable Telnet
                                            M569 P0 S0 ; physical drive 0 goes backwards
                                            M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
                                            M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                            M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
                                            M201 X500.00 Y500.00 Z120.00 E5000.00 ; set accelerations (mm/s^2)
                                            M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                                            M84 S30 ; Set idle timeout
                                            M208 X235 Y235 Z260 S0 ; set axis maxima
                                            M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
                                            M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                            M557 X10:220 Y10:220 S20 ; define mesh grid
                                            M308 S0 P"bedtemp" Y"thermistor" T9880 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                                            M143 H0 S80 ; set temperature limit for heater 0 to 80C
                                            M308 S1 P"e0temp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin e0temp
                                            M143 H1 S250 ; set temperature limit for heater 1 to 250C
                                            M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
                                            M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                                            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                            M106 P2 S0 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
                                            M563 P0 S"HotEnd" D0 H1 F0:1:2 ; define tool 0
                                            ; Custom settings
                                            M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                            T0 ; select first tool
