    help me connect the Filamento laser monitor on conn_lcd pin 3
    • konte1978undefined
      konte1978
      Hi I would like some help to configure the duet3d filament monitor. The sensor is connected to pin 3) Stop 10 (ENC_B) of the CONN_LCD.
      The firmware version is v3.1.4
      M591 D1 P5 C "conn_lcd.encb, connlcd.3" R40: 120 E3.0 S0.
      when I send the command M591D1 I get this answer:
      M591 D1
      Extruder 1 has no filament sensor.
      This is the code of the other two perfectly recognized extruders.
      M591 D0 P5 C "e0stop" R40: 120 E3.0 S0
      M591 D2 P5 C "e1stop" R40: 120 E3.0 S0
      • alankilianundefined
        alankilian
        @konte1978 said in help me connect the Filamento laser monitor on conn_lcd pin 3:
        THIS thread says to use C"connlcd.encb" for the M591
        I think when THIS page says "connlcd.encb, connlcd.3" it means you can use either one of those names, but not both of them at the same time.
          konte1978
          @alankilian said in help me connect the Filamento laser monitor on conn_lcd pin 3:
          connlcd.encb
          thank you so much now it is recognized,
          to enable the control, do I have to set the last S to a value of 1?
          S1
            alankilian
            Yes, S1 enables the sensor.
            S0 disables it but it is still configured and running.
            HERE'S the documentation.
            • Adrian52undefined
              Adrian52
              Previous post on this
              https://forum.duet3d.com/topic/10042/indirect-bearing-laser-filament-monitor-concept/97?_=1606766379579
