    G29 / 3 point bed compensation - always tilted slightly
    1.5k
    • Vetiundefined
      Veti @Martin1454
      @Martin1454
      i would advise not to have the G32 in the homez, as the G32 invalidates z=0.
      while analysing change the 3 point with points close to the leadscrews.
      Martin1454undefined 1 Reply Last reply Reply Quote 0
      • Martin1454undefined
        Martin1454 @Veti
        @Veti said in G29 / 3 point bed compensation - always tilted slightly:
        @Martin1454
        Where would you place G32 then?
        • Vetiundefined
          Veti @Martin1454
          @Martin1454
          in the start g code.
          G28
          G32
          G28 Z
            Martin1454 @Veti
            @Martin1454
            G28
            G32
            G28 Z
            So I tried that, but that gives me a fun offset.
            I removed G32 from Homeall and Homez - Then homed all axis from the DWC, and then sent manually G32 and then G28 Z. Then I probed the bed with G29
            • Vetiundefined
              Veti
              post your new homez
                Martin1454 @Veti
                @Veti
                ; homez.g
                ; called to home the Z axis
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 12 2020 17:14:31 GMT+0200 (Centraleuropæisk sommertid)
                ; Z-axis
                G91               		 ; relative positioning
                M561                     ; Clear any bed transform
                G1 X160 Y170 F6000	     ;
                G30						 ;
                • Vetiundefined
                  Veti
                  post your config.g maybe you set your Dive height wrong
                    Martin1454 @Veti
                    @Veti
                    This is the complete config.g
                    G90                                          ; send absolute coordinates...
                    M83                                          ; ...but relative extruder moves
                    M550 P"Duet 3"                               ; set printer name
                    M669 K1                                      ; select CoreXY mode
                    M569 P0.1 S1                                 ; physical drive 0.1 goes forwards
                    M569 P0.2 S1                                 ; physical drive 0.2 goes forwards
                    M569 P0.3 S0                                 ; physical drive 0.3 goes forwards
                    M569 P0.4 S0                                 ; physical drive 0.4 goes forwards
                    M569 P0.5 S0                                 ; physical drive 0.5 goes forwards
                    M569 P0.0 S0                                 ; physical drive 0.0 goes forwards
                    M584 X0.2 Y0.1 Z0.4:0.3:0.5 E0.0             ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
                    M92 X200 Y200 Z800.00 E415.00           	 ; set steps per mm
                    M566 X1500.00 Y1500.00 Z12.00 E120.00        ; set maximum instantaneous speed changes (mm/min)
                    M203 X8400.00 Y8400.00 Z4000.00 E1200.00      ; set maximum speeds (mm/min)
                    M201 X800.00 Y500.00 Z200.00 E250.00          ; set accelerations (mm/s^2)
                    M906 X1200 Y1200 Z800 E800 I40                 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                      ; Set idle timeout
                    M208 X0 Y0 Z0 S1                             ; set axis minima
                    M208 X300 Y250 Z480 S0                       ; set axis maxima
                    M574 X1 S3                                                          ; Set endstops controlled by motor load detection
                    M574 Y1 S3                                                          ; Set endstops controlled by motor load detection
                    M574 Z0 															; Set endstop Z to be probe
                    M915 X Y H200 S1 R0 F0						 						; set X and Y to sensitivity , do nothing when stall, unfiltered
                    M558 P9 C"^io7.in" H5 F100 T6000             ; set Z probe type to bltouch and the dive height + speeds
                    M950 S0 C"io7.out"                           ; create servo pin 7 for BLTouch
                    G31 P500 X30 Y70 Z1.48                          ; set Z probe trigger value, offset and trigger height
                    M557 X40:300 Y80:195 S30                     ; define mesh grid
                    ; Define the X and Y coordinates of the leadscrews.
                    ; Must come after M584 (Set drive mapping), M667 (Select CoreXY Mode) and M669 (Choosing Kinematics type)
                    ; Motor order: Front right (1), front left (2), rear center (3).
                    ; Snn Maximum correction in mm to apply to each leadscrew (optional, default 1.0)
                    M671 X-55:360:360.0 Y170:40:310 S20 P2
                    M308 S0 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                    M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
                    M140 H0                                      ; map heated bed to heater 0
                    M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
                    M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp2
                    M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
                    M950 F1 C"out7" Q500 L127 C"Heat sink"             ; create fan 1 on pin out7 and set its frequency
                    M106 P1 H1 T45                             ; set fan 1 value. Thermostatic control is turned on
                    M950 F0 C"out4" Q500                         ; create fan 0 on pin out4 and set its frequency
                    M106 P0 H-1 C"Part cooler"            ; set fan 0 value. Thermostatic control is turned off
                    M563 P0 D0 H1 F0                             ; define tool 0
                    G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
                    G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
                    T0                                           ; select first tool
                    M501;											Read config override
                    • Vetiundefined
                      Veti
                      @Martin1454 said in G29 / 3 point bed compensation - always tilted slightly:
                      thats not the command for Set endstop Z to be probe
                      this is
                      Your thermistor is configured incorrectly. Find the correct Beta value in your thermistor documentation.
                      are these correct? what stepper motors do you have?
                        Martin1454 @Veti
                        this is
                        The motors are all E3D high torque motors rated at 1.6A, except the extruder which is a small pancake stepper - current seems okay on it - Will look into the thermistors and change it from M574 Z0 to Z1 S2
                        EDIT: I got the Z0 from the Gcode page
                        "The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing. The only printers known that do this using Duet electronics are the RepRapPro Ormerod, Huxley Duo, and Mendel Tricolour machines. When using the Z probe to home Z, M574 Z0 should be used."
                        • Vetiundefined
                          Veti
                          so you are running your z steppers with not enought current
                          set the current to 1200
                            Martin1454 @Veti
                            @Veti
                            Increased the current to 1200 - still gets the large offset
                            • Vetiundefined
                              Veti
                              that make zero sense.
                              G28 Z should establish Z=0 using G30.
                              G29 getting a different offset would mean that the trigger point is different.
                                Phaedrux Moderator @Martin1454
                                G1 X30 Y80 F6000 ; G30 ;
                                G1 X160 Y170 F6000 ; G30
                                Your homeall and homez place the probe at different locations. Make them the same.
                                Martin1454undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  Martin1454 @Phaedrux
                                  @Phaedrux Hmm....
                                  That got me thinking - I Use the X30 Y80 because that places the probe not that far from my first lead screw and that saves time since it doesnt have to move when it starts the 3 point leveling - But! since it is not level when it does the first zeroring of Z, will placeing it off center, make the axis it rotates about not centered also? Or since its a plane, it doesnt matter?
                                  But I'll change it when I get home
                                  • sinned6915undefined
                                    sinned6915
                                    Are you certain that you dont have a dropped corner on one of your axis?
                                      A Former User
                                      You also need to remember there is a huge difference between a surface being level and it being flat...
                                      if it ispossible to use a digital inclinometer you can check the level, first zero the inclinometer to the surface the printer sits on (firstly on the X axis) then carry out 3 point leveling and check how level it is, then zero the inclinometer on the surface on the Y axis orientation and carry out the same 3 point leveling and see what it says. and you will have your answer, which i think might be that your bed it level but not completely flat.
                                      you can also check that your rails are level too.
                                        Martin1454 @sinned6915
                                        @sinned6915 said in G29 / 3 point bed compensation - always tilted slightly:
                                        Im pretty sure non of the corners is dropped - But even if one corner is lower, shouldent the whole system stay "parallel"?
                                        Im wondering if the M561 in my HomeZ.g have anything with the offset to do?
                                        sinned6915undefined 1 Reply Last reply Reply Quote 0
                                          Martin1454 @A Former User
                                          @CaLviNx I dont have one of those tools (yet) but the surface of the bed is a cast aluminium plate that is bought with a really flat surface, so Im suprised if its not flat. As I see it in the first picture, it looks like a flat planar that is just tilted, and not bend.
                                          I'm gonna get the offset working again, and then I'll try to place a bit around with the Z-leadscrews placement and see the impact on the leveling.
                                            Phaedrux Moderator @Phaedrux
                                            @Phaedrux said in G29 / 3 point bed compensation - always tilted slightly:
                                            Did this make any difference?
