    Duet2 Wifi connection dropping
    1.4k
    • uneumann36undefined
      uneumann36
      Ah ok, thank you.
      But also when i am not connected at USB, i have the same problems.
        Can you send M122 and copy and paste the results?
          uneumann36
          2.12.2020, 18:20:48 M122
          2.12.2020, 18:20:27 M122
          2.12.2020, 18:17:56 Connected to 192.168.1.148
            Is that from the gcode console in the web interface or over pronterface and usb?
            There should be a large diagnostic report that comes from that.
            What about sending M115? That should report the firmware version.
              uneumann36
              I am sorry, i am not an expert in the computer stuff!
              This is from the web console when printer is in idle.
              When i am at printing, the web console lost connection and is not reachable, but you can see printer is connected via wifi!
              It is in this moment only reachable via pronterface
                uneumann36
                Then i get a failure Code 503
                  uneumann36
                  @Phaedrux said in Duet2 Wifi Firmware confusion:
                  M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                    Please try M122 again.
                      uneumann36
                      I am right now on printing a temp Tower.
                      I type M122, and connection lost!
                      And i can´t connect printer back to Web console
                      • Vetiundefined
                        Veti
                        are there any cables overlapping with the ethernet cable?
                          Can you send M122 over USB then when your print is finished.
                          I'd like to see what firmware version the wifi server is running an what kind of signal strength you're getting.
                          Since you're running 2.03 your board will need a firmware update, but first we need to know if your wifi connection is workable or if we need to do it manually.
                          uneumann36undefined 1 Reply Last reply Reply Quote 0
                            uneumann36
                            No, because it´s wifi
                              uneumann36
                              M122
                              SENDING:M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                              Board ID: 0JD0M-9P61A-J8PSJ-6JTDA-3SD6J-1BRQT
                              Used output buffers: 3 of 24 (8 max)
                              Static ram: 25680
                              Dynamic ram: 93680 of which 0 recycled
                              Exception stack ram used: 396
                              Never used ram: 11316
                              Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:00:30 ago, cause: software
                              Last software reset at 2020-12-02 18:38, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 2)
                              Error status: 0
                              [ERROR] Error status: 0
                              Free file entries: 10
                              MCU temperature: min 28.4, current 29.0, max 29.2
                              Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: standstill, SG min/max 0/158
                              Driver 1: standstill, SG min/max 0/82
                              Date/time: 2020-12-02 18:39:24
                              Cache data hit count 105715423
                              Slowest loop: 6.79ms; fastest: 0.07ms
                              Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 679ms
                              === DDARing ===
                              Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                              Segments left: 0
                              Movement lock held by null
                              http is idle in state(s) 0
                              telnet is idle in state(s) 0
                              file is idle in state(s) 0
                              serial is ready with "M122" in state(s) 0
                              aux is idle in state(s) 0
                              daemon is idle in state(s) 0
                              queue is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 15.52ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              • WiFi -
                                Network state is running
                                WiFi firmware version 1.23
                                WiFi MAC address 48:3f:da:78:53:61
                                WiFi Vcc 3.32, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 25864
                                WiFi IP address 192.168.1.148
                                WiFi signal strength -53dBm, reconnections 0, sleep mode modem
                                ok T0:186.2 /0.0 B:57.8 /0.0
                                uneumann36 @Phaedrux
                                @Phaedrux
                                do you find the result?
                                  Let's start by manually updating the firmware and DWC files.
                                  You'll need to remove the SD card from the Duet and put it in your PC.
                                  First make a backup copy of the SD card contents.
                                  Then replace the contents of the /www folder with the contents of this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
                                  Then download this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2Firmware-2.05.1.zip
                                  extract it, and copy the .bin files in to the /sys folder.
                                  Duet2CombinedFirmware.bin
                                  DuetWifiServer.bin
                                  iap4e.bin
                                  iap4s.bin
                                  Then put the SD card back in the Duet and connect via USB and use pronterface to send the command M997 S0:1
                                  When it reboots, send M122 again to confirm that RRF 2.05.1 and wifi server 1.23 are installed.
                                  Then try to access the web interface again.
                                    uneumann36
                                    Yeah this works well !
                                    Please check if this is good :
                                    SENDING:M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                                    Used output buffers: 3 of 24 (12 max)
                                    Static ram: 25712
                                    Dynamic ram: 93140 of which 0 recycled
                                    Exception stack ram used: 272
                                    Never used ram: 11948
                                    Tasks: NETWORK(ready,1280) HEAT(blocked,1232) MAIN(running,3728) IDLE(ready,160)
                                    Owned mutexes:
                                    Last reset 00:00:29 ago, cause: power up
                                    Error status: 0
                                    MCU temperature: min 32.5, current 32.7, max 33.0
                                    Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                    Cache data hit count 75021852
                                    Slowest loop: 6.39ms; fastest: 0.07ms
                                    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                                    === DDARing ===
                                    Segments left: 0
                                    === Network ===
                                    Slowest loop: 201.15ms; fastest: 0.08ms
                                    HTTP sessions: 0 of 8
                                    • WiFi -
                                      Failed messages: pending 0, notready 0, noresp 1
                                      WiFi flash size 4194304, free heap 26024
                                      WiFi signal strength -54dBm, reconnections 0, sleep mode modem
                                      uneumann36
                                      it works approx 5 min .
                                      Then i got the message :
                                        uneumann36
                                        In this moment it is impossible to have access to Web console.
                                        Only when i switch printer off and on it is connected immediately
                                          uneumann36
                                          Is there anyone who can help me ?
                                          • Exerqtorundefined
                                            Exerqtor
                                            My guess is that your problems might be that you haven't setup a static ip address for your printer, or that your printer is located somewhere with to low signal strength.
                                            Have you read up on setting up static ip for your printer (on the duet wiki), and want to give it a try?
