    Duet2 Wifi connection dropping
    1.8k
      Can you send M122 and copy and paste the results?
      • uneumann36undefined
        uneumann36
        2.12.2020, 18:20:48 M122
        2.12.2020, 18:20:27 M122
        2.12.2020, 18:17:56 Connected to 192.168.1.148
          Is that from the gcode console in the web interface or over pronterface and usb?
          There should be a large diagnostic report that comes from that.
          What about sending M115? That should report the firmware version.
            uneumann36
            I am sorry, i am not an expert in the computer stuff!
            This is from the web console when printer is in idle.
            When i am at printing, the web console lost connection and is not reachable, but you can see printer is connected via wifi!
            It is in this moment only reachable via pronterface
              uneumann36
              Then i get a failure Code 503
                uneumann36
                @Phaedrux said in Duet2 Wifi Firmware confusion:
                M115
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                  Please try M122 again.
                    uneumann36
                    I am right now on printing a temp Tower.
                    I type M122, and connection lost!
                    And i can´t connect printer back to Web console
                    • Vetiundefined
                      Veti
                      are there any cables overlapping with the ethernet cable?
                        Can you send M122 over USB then when your print is finished.
                        I'd like to see what firmware version the wifi server is running an what kind of signal strength you're getting.
                        Since you're running 2.03 your board will need a firmware update, but first we need to know if your wifi connection is workable or if we need to do it manually.
                        uneumann36undefined 1 Reply Last reply Reply Quote 0
                          uneumann36
                          No, because it´s wifi
                            uneumann36
                            M122
                            SENDING:M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                            Board ID: 0JD0M-9P61A-J8PSJ-6JTDA-3SD6J-1BRQT
                            Used output buffers: 3 of 24 (8 max)
                            Static ram: 25680
                            Dynamic ram: 93680 of which 0 recycled
                            Exception stack ram used: 396
                            Never used ram: 11316
                            Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
                            Owned mutexes:
                            Last reset 00:00:30 ago, cause: software
                            Last software reset at 2020-12-02 18:38, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 2)
                            Error status: 0
                            [ERROR] Error status: 0
                            Free file entries: 10
                            MCU temperature: min 28.4, current 29.0, max 29.2
                            Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: standstill, SG min/max 0/158
                            Driver 1: standstill, SG min/max 0/82
                            Date/time: 2020-12-02 18:39:24
                            Cache data hit count 105715423
                            Slowest loop: 6.79ms; fastest: 0.07ms
                            Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 679ms
                            === DDARing ===
                            Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                            Segments left: 0
                            Movement lock held by null
                            http is idle in state(s) 0
                            telnet is idle in state(s) 0
                            file is idle in state(s) 0
                            serial is ready with "M122" in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 15.52ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is running
                              WiFi firmware version 1.23
                              WiFi MAC address 48:3f:da:78:53:61
                              WiFi Vcc 3.32, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 25864
                              WiFi IP address 192.168.1.148
                              WiFi signal strength -53dBm, reconnections 0, sleep mode modem
                              ok T0:186.2 /0.0 B:57.8 /0.0
                              uneumann36 @Phaedrux
                              @Phaedrux
                              do you find the result?
                                Let's start by manually updating the firmware and DWC files.
                                You'll need to remove the SD card from the Duet and put it in your PC.
                                First make a backup copy of the SD card contents.
                                Then replace the contents of the /www folder with the contents of this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
                                Then download this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2Firmware-2.05.1.zip
                                extract it, and copy the .bin files in to the /sys folder.
                                Duet2CombinedFirmware.bin
                                DuetWifiServer.bin
                                iap4e.bin
                                iap4s.bin
                                Then put the SD card back in the Duet and connect via USB and use pronterface to send the command M997 S0:1
                                When it reboots, send M122 again to confirm that RRF 2.05.1 and wifi server 1.23 are installed.
                                Then try to access the web interface again.
                                  uneumann36
                                  Yeah this works well !
                                  Please check if this is good :
                                  SENDING:M122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                                  Used output buffers: 3 of 24 (12 max)
                                  Static ram: 25712
                                  Dynamic ram: 93140 of which 0 recycled
                                  Exception stack ram used: 272
                                  Never used ram: 11948
                                  Tasks: NETWORK(ready,1280) HEAT(blocked,1232) MAIN(running,3728) IDLE(ready,160)
                                  Owned mutexes:
                                  Last reset 00:00:29 ago, cause: power up
                                  Error status: 0
                                  MCU temperature: min 32.5, current 32.7, max 33.0
                                  Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                  Cache data hit count 75021852
                                  Slowest loop: 6.39ms; fastest: 0.07ms
                                  Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                                  === DDARing ===
                                  Segments left: 0
                                  === Network ===
                                  Slowest loop: 201.15ms; fastest: 0.08ms
                                  HTTP sessions: 0 of 8
                                  • WiFi -
                                    Failed messages: pending 0, notready 0, noresp 1
                                    WiFi flash size 4194304, free heap 26024
                                    WiFi signal strength -54dBm, reconnections 0, sleep mode modem
                                    uneumann36
                                    it works approx 5 min .
                                    Then i got the message :
                                      uneumann36
                                      In this moment it is impossible to have access to Web console.
                                      Only when i switch printer off and on it is connected immediately
                                        uneumann36
                                        Is there anyone who can help me ?
                                        • Exerqtorundefined
                                          Exerqtor
                                          My guess is that your problems might be that you haven't setup a static ip address for your printer, or that your printer is located somewhere with to low signal strength.
                                          Have you read up on setting up static ip for your printer (on the duet wiki), and want to give it a try?
                                          • piperswundefined
                                            pipersw
                                            Or power wire of psu or bed are near the wifi module, could you check if it's the case ?
