Unsolved Duet2 Wifi connection dropping
I am right now on printing a temp Tower.
I type M122, and connection lost!
And i can´t connect printer back to Web console -
are there any cables overlapping with the ethernet cable?
Can you send M122 over USB then when your print is finished.
I'd like to see what firmware version the wifi server is running an what kind of signal strength you're getting.
Since you're running 2.03 your board will need a firmware update, but first we need to know if your wifi connection is workable or if we need to do it manually.
No, because it´s wifi
M122
SENDING:M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P61A-J8PSJ-6JTDA-3SD6J-1BRQT
Used output buffers: 3 of 24 (8 max)
Static ram: 25680
Dynamic ram: 93680 of which 0 recycled
Exception stack ram used: 396
Never used ram: 11316
Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
Owned mutexes:
Last reset 00:00:30 ago, cause: software
Last software reset at 2020-12-02 18:38, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 2)
Error status: 0
[ERROR] Error status: 0Free file entries: 10
MCU temperature: min 28.4, current 29.0, max 29.2
Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/158
Driver 1: standstill, SG min/max 0/82
Date/time: 2020-12-02 18:39:24
Cache data hit count 105715423
Slowest loop: 6.79ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 679ms
=== DDARing ===
Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.52ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address 48:3f:da:78:53:61
WiFi Vcc 3.32, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25864
WiFi IP address 192.168.1.148
WiFi signal strength -53dBm, reconnections 0, sleep mode modem
ok T0:186.2 /0.0 B:57.8 /0.0
- WiFi -
@Phaedrux
do you find the result? -
Let's start by manually updating the firmware and DWC files.
You'll need to remove the SD card from the Duet and put it in your PC.
First make a backup copy of the SD card contents.
Then replace the contents of the /www folder with the contents of this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
Then download this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2Firmware-2.05.1.zip
extract it, and copy the .bin files in to the /sys folder.
Duet2CombinedFirmware.bin
DuetWifiServer.bin
iap4e.bin
iap4s.binThen put the SD card back in the Duet and connect via USB and use pronterface to send the command
M997 S0:1
When it reboots, send M122 again to confirm that RRF 2.05.1 and wifi server 1.23 are installed.
Then try to access the web interface again.
@Phaedrux said in Duet2 Wifi Firmware confusion:
Yeah this works well !
Please check if this is good :
SENDING:M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Used output buffers: 3 of 24 (12 max)
Static ram: 25712
Dynamic ram: 93140 of which 0 recycled
Exception stack ram used: 272
Never used ram: 11948
Tasks: NETWORK(ready,1280) HEAT(blocked,1232) MAIN(running,3728) IDLE(ready,160)
Owned mutexes:
Last reset 00:00:29 ago, cause: power up
Error status: 0
MCU temperature: min 32.5, current 32.7, max 33.0
Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Cache data hit count 75021852
Slowest loop: 6.39ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
=== Network ===
Slowest loop: 201.15ms; fastest: 0.08ms
HTTP sessions: 0 of 8- WiFi -
Failed messages: pending 0, notready 0, noresp 1
WiFi flash size 4194304, free heap 26024
WiFi signal strength -54dBm, reconnections 0, sleep mode modem
- WiFi -
it works approx 5 min .
Then i got the message :
In this moment it is impossible to have access to Web console.
Only when i switch printer off and on it is connected immediately
Is there anyone who can help me ?
My guess is that your problems might be that you haven't setup a static ip address for your printer, or that your printer is located somewhere with to low signal strength.
Have you read up on setting up static ip for your printer (on the duet wiki), and want to give it a try?
Or power wire of psu or bed are near the wifi module, could you check if it's the case ?
Hi
Thank you for your reply.Of course the Duet Board get a static IP from my Fritzbox 7590.
And the Powe wire is not in the near of the Wifi antena.
So i am frustrated . -
Any idea´s?
Let me look into that error message you're getting from DWC now.
When you lose connection, does the blue LED on the module go out?
Hi
No , the blue Wifi LED on the Duet Board stay on ! -
Usually that error message would indicate that the connection buffers are getting used up causing a disconnect.
How many devices do you have running DWC?
What browser are you using?
When you are connected can you verify that your DWC files have been updated to 2.0.7?
I run only one Duet2 Board on the DWC.
My Browser is Chrome.
In The moment i can´t connect me
So is there a other possibility to see if i have 2.07?
