    ToolBoard: 2 wires fan, heater fault and how to extrude ?
    5.4k
    • Pseud3mysundefined
      Pseud3mys @Veti
      @Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
      you can find the error messages in the console or in the popup at the bottom right when they occur.
      I just tested but I don't have any error message (I checked the console and there is no pupop when it stop working)
      • Vetiundefined
        Veti
        are you on duet web control 3.1.1 as well?
        Pseud3mysundefined 1 Reply Last reply Reply Quote 0
          Pseud3mys @Veti
          I think yes, what is the command to check ?
          • Vetiundefined
            Veti
            on the general tab
            Pseud3mysundefined 2 Replies Last reply Reply Quote 0
              Pseud3mys @Veti
              @Veti ok, yes it both version 3.1.1
                Pseud3mys @Veti
                @Veti I tried to update the toolBoard but I go this error:
                02/12/2020 à 18:23:25	Upload of Duet3Firmware_TOOL1LC.bin successful after 1s
                02/12/2020 à 18:23:27	M997 B122
                Board 122 starting firmware update
                02/12/2020 à 18:23:37	M997 S
                Error: Failed to switch off remote heater 2: Board 122 does not have heater 2
                02/12/2020 à 18:23:39	Error: Failed to switch off remote heater 2: Board 122 does not have heater 2
                02/12/2020 à 18:24:06	Connection established
                  Pseud3mys
                  I seem to have update it.. no error. But the version it's still 3.1.0 (on the toolboard 1LC). but I download the 3.1.1 (git hub)
                  • Vetiundefined
                    Veti @Pseud3mys
                    3.1.0 is correct there is no 3.1.1 for the toolboard.
                      Pseud3mys @Veti
                      ah ok. Have you an idea then for the fault state ?
                      • Vetiundefined
                        Veti
                        @Pseud3mys said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
                        do you still get this error message?
                          Pseud3mys @Veti
                          @Veti no, when I update it now it just put "2000°C" and offline on the web site but he is still connected with the CAN bus
                          • Vetiundefined
                            Veti
                            post the output of
                            M122 B121
                            and
                            M122 B122
                              Pseud3mys @Veti
                              • Vetiundefined
                                Veti
                                you power down the system after the firmware update?
                                also power the normal M122 output
                                  Pseud3mys @Veti
                                  @Veti yes, what is the M122 output ?
                                  • Vetiundefined
                                    Veti
                                    i meant provide the m122 output
                                      Pseud3mys @Veti
                                      it was not this ?
                                      • Vetiundefined
                                        Veti
                                        no just send M122. that will provide the output for the duet 3
                                          Pseud3mys @Veti
                                          @Veti ah okay, the popup say "response too long, see console"
                                          02/12/2020 à 19:08:20 M122
                                          RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                                          Board ID: 08DJM-956BA-NA3TJ-6J1D2-3SD6M-9B9LT
                                          Used output buffers: 1 of 40 (23 max)
                                          Static ram: 154604
                                          Dynamic ram: 162588 of which 36 recycled
                                          Exception stack ram used: 224
                                          Never used ram: 75764
                                          Tasks: NETWORK(ready,292) ETHERNET(blocked,436) HEAT(blocked,1248) CanReceiv(suspended,3404) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4520) IDLE(ready,76)
                                          Owned mutexes: LwipCore(NETWORK)
                                          Last reset 00:00:54 ago, cause: software
                                          Last software reset at 2020-12-02 19:07, reason: User, spinning module GCodes, available RAM 75728 bytes (slot 2)
                                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                                          Error status: 0
                                          MCU temperature: min 36.6, current 37.0, max 37.6
                                          Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                                          12V rail voltage: min 11.4, current 11.4, max 11.5, under voltage events: 0
                                          Driver 0: standstill, reads 6703, writes 0 timeouts 0, SG min/max not available
                                          Driver 1: standstill, reads 6704, writes 0 timeouts 0, SG min/max not available
                                          Driver 2: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
                                          Driver 3: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
                                          Driver 4: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
                                          Driver 5: standstill, reads 6701, writes 0 timeouts 0, SG min/max not available
                                          Date/time: 2020-12-02 19:08:18
                                          Slowest loop: 6.33ms; fastest: 0.22ms
                                          === Storage ===
                                          Free file entries: 10
                                          SD card longest read time 2.2ms, write time 0.0ms, max retries 0
                                          === MainDDARing ===
                                          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                          === AuxDDARing ===
                                          Segments left: 0
                                          Movement lock held by null
                                          HTTP is idle in state(s) 0
                                          Telnet is idle in state(s) 0
                                          File is idle in state(s) 0
                                          USB is idle in state(s) 0
                                          Aux is idle in state(s) 0
                                          Trigger is idle in state(s) 0
                                          Queue is idle in state(s) 0
                                          LCD is idle in state(s) 0
                                          SBC is idle in state(s) 0
                                          Daemon is idle in state(s) 0
                                          Aux2 is idle in state(s) 0
                                          Code queue is empty.
                                          === Network ===
                                          Slowest loop: 5.59ms; fastest: 0.03ms
                                          HTTP sessions: 1 of 8
                                          • Ethernet -
                                            State: active
                                            Error counts: 0 0 0 0 0
                                            === CAN ===
                                            Messages sent 59, longest wait 0ms for type 0
                                            === Linux interface ===
                                            State: 0, failed transfers: 0
                                            Last transfer: 54276ms ago
                                            RX/TX seq numbers: 0/1
                                            SPI underruns 0, overruns 0
                                            Number of disconnects: 0
                                            Buffer RX/TX: 0/0-0
                                          • Vetiundefined
                                            Veti
                                            hmm can communication seems to be working.
                                            can you update to the latest beta as the diagnostic has been improved.
