ToolBoard: 2 wires fan, heater fault and how to extrude ?
btw are you on firmware 3.1.1 ?
are you sure thats the maximum speed you printer can achieve?
No, I didn't begin setting up this part. Now, I just try to set up the dual extrudeur and hotends.
@Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
yes
we need to know what the error message is.
I understood, but I have no error message or I don't now where i can see it.
I click on "Heater 2". It turn active, and after fews seconds It turn "fault" as you can see on the picture. But I have no error (even in the consol) -
you can find the error messages in the console or in the popup at the bottom right when they occur.
I just tested but I don't have any error message (I checked the console and there is no pupop when it stop working)
are you on duet web control 3.1.1 as well?
I think yes, what is the command to check ?
@Veti ok, yes it both version 3.1.1
@Veti I tried to update the toolBoard but I go this error:
02/12/2020 à 18:23:25 Upload of Duet3Firmware_TOOL1LC.bin successful after 1s 02/12/2020 à 18:23:27 M997 B122 Board 122 starting firmware update 02/12/2020 à 18:23:37 M997 S Error: Failed to switch off remote heater 2: Board 122 does not have heater 2 02/12/2020 à 18:23:39 Error: Failed to switch off remote heater 2: Board 122 does not have heater 2 02/12/2020 à 18:24:06 Connection established -
I seem to have update it.. no error. But the version it's still 3.1.0 (on the toolboard 1LC). but I download the 3.1.1 (git hub)
3.1.0 is correct there is no 3.1.1 for the toolboard.
ah ok. Have you an idea then for the fault state ?
@Pseud3mys said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
do you still get this error message?
@Veti no, when I update it now it just put "2000°C" and offline on the web site but he is still connected with the CAN bus
post the output of
M122 B121
and
M122 B122 -
you power down the system after the firmware update?
also power the normal M122 output
@Veti yes, what is the M122 output ?
