    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
      Clean the bed maybe?
      lui2004undefined 1 Reply Last reply Reply Quote 0
      • lui2004undefined
        lui2004 @Phaedrux
        @Phaedrux allready done with iso....
        I will check this 👍🏼
        • RyanPundefined
          RyanP @lui2004
          @lui2004
          Wish I had of caught this post before you went through everything. The MicroSwiss DD can't use a pancake style motor. This is due to the MS DD not being geared. Use a 42-34 Nema 17.
          I ran through all the same problems and was immediately fixed by putting the stock motor on, a 42-34.
          CR10S, August 2018
          Anycubic Photon S December 2019
          Ender 5 Feb 2020
          Ender 5 Plus May 2020
          Anycubic Photon Mono X Nov 2020
          https://3dimensiongames.com/
          lui2004undefined 1 Reply Last reply Reply Quote 1
          • Vetiundefined
            Veti
            you are right @RyanP
            • lui2004undefined
              lui2004 @RyanP
              @RyanP i have the original one here 42-40
              • lui2004undefined
                lui2004 @Veti
                @Veti @Phaedrux
                so this my result after frimware retraction setup,if you have somthing to make the print better tell me how 😉
                i have printed faster and other widht
                my actual config.g
                ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
                G90                                      ; Send absolute coordinates...
                M83                                      ; ...but relative extruder moves
                M550 P"Ender 5"                          ; Set machine name
                M552 S1                                  ; Enable network
                M586 P0 S1                               ; Enable HTTP
                M586 P1 S0                               ; Disable FTP
                M586 P2 S0                               ; Disable Telnet
                M569 P0 S1                               ; Physical drive 0 goes forwards
                M569 P1 S1                               ; Physical drive 1 goes forwards
                M569 P2 S0                               ; Physical drive 2 goes backwards
                M569 P3 S1                              ; Physical drive 3 goes forwards
                M584 X0 Y1 Z2 E3                               ; set drive mapping
                M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
                M92 X80.20 Y80.12 Z794.04 E277.89             ; set steps per mm
                M566 X900.00 Y900.00 Z60.00 E4000.00      ; Set maximum instantaneous speed changes (mm/min)
                M203 X15000.00 Y15000.00 Z600.00 E8000.00  ; Set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z200.00 E8000.00          ; set accelerations (mm/s^2)
                M906 X800 Y800 Z800 E1400 I30                   ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                  ; Set idle timeout
                M208 X0 Y0 Z0 S1                         ; Set axis minima
                M208 X220 Y220 Z300 S0                   ; Set axis maxima
                M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                M574 Z1 S2 									   ; configure Z-probe endstop for low end on Z
                ;Filament Sensors
                M591 D0 P2 C"!e0_stop" S1   			   ;Extruder 1(0)
                M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
                M558 P9 C"^zprobe.in" H3 F60 T6000 A10 R0.75 S0.003            ; set Z probe type to bltouch and the dive height + speeds
                G31 P500 X41.2 Y4.5 Z2.498                  ; set Z probe trigger value, offset and trigger height
                M557 X41.2:221.2 Y4.5:219.5 S20                       ; define mesh grid
                M671 X28.8:198.8:198:28.8 Y24:24:194:194
                M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                M140 H0                                        ; map heated bed to heater 0
                M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                M143 H1 S300 								   ; set temperature limit for heater 1 to 300C
                M307 H1 B0 S1.00
                M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                M563 P0 D0 H1                            ; Define tool 0 S3D
                ;M563 P0 D0 H1 F0							; Für Prusa Slicer
                G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
                G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
                M572 D0 S0.05 ; Pressure Advance
                M207 P0 S0.25 R0 F2100 T2100 Z0 ; Firmware Retraction
                M204 P500 T2000
                M501
                Changed only this the rest are the same as i posted before:
                Slicer settings:
                Benchy:
                • Vetiundefined
                  Veti
                  that look good
                    Looking very good. The benchy hull line is a known artifact, likely due to cooling shrinkage.
                    https://help.prusa3d.com/en/article/the-benchy-hull-line_124745#:~:text=The 3DBenchy is a 3D,testing and benchmarking 3D printers.&text=Ever since it's release%2C one,the infamous Benchy hull line.
                    • lui2004undefined
                      lui2004 @Phaedrux
                      @Phaedrux ok i will read it.
                      It can be because i have only 40% partfan because i use Petg.
                      • Vetiundefined
                        Veti
                        thats a petg print? for that its very good.
                        • lui2004undefined
                          lui2004 @Veti
                          @Veti yes its petg 👍🏼
                          • Vetiundefined
                            Veti
                            which manufacturer of petg?
                            • lui2004undefined
                              lui2004 @Veti
                              @Veti Filatex3D
                              • lui2004undefined
                                lui2004
                                @Phaedrux said in After Micro swiss DD upgrade,Extruder skips steps:
                                benchy hull line
                                i will test it now with PLA and 100% part fan
                                • lui2004undefined
                                  lui2004
                                  Hi
                                  i have breake the cable of my thermistor 😞
                                  but i have a new pne here:
                                  specs:
                                  NTC-Thermistor 100 K 3950
                                  Thermistor Cartridge:
                                  Size: 1.25mmx2.0mm glass bead
                                  High accuracy: 1%
                                  Resistance value at 25°C=100K
                                  Wiring length: 1m / 39.3"
                                  Operating temperature range: -40 ° C + 300 ° C
                                  Rated power: 45MW
                                  how i set it in my config.g ?
                                  i have it like this :
                                  M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                                  M307 H1 B0 S1.00
                                  is it ok ?
                                  • Vetiundefined
                                    Veti @lui2004
                                    @lui2004
                                    yes
                                    B3950 thermistors are bit hit and miss.
                                    Do not assume that when you are setting your temperature to 200C now that its the same temperature as before.
                                    • lui2004undefined
                                      lui2004 @Veti
                                      @Veti said in After Micro swiss DD upgrade,Extruder skips steps:
                                      ok !
                                      which thermistor you prefer ?
                                      • Vetiundefined
                                        Veti
                                        Semitec 104GT-2 are better defined,
                                        e.g.
                                        https://de.aliexpress.com/item/32816085854.html
                                        i personally use a pt1000 but i dont think they exist in the glass bulb that you want.
                                        • lui2004undefined
                                          lui2004 @Veti
                                          Semitec 104GT-2
                                          ok is this the correct one :
                                          https://reprapworld.de/products/extruder/extruder_parts/thermistors/104nt_4_r025h42g_semitec_thermistor_100k_ntc/?f=gs&f=gs&mkwid=sPXPyq0nv_dc|pcrid|191801720052|pkw||pmt||slid||prid|62&pgrid=50293152428&ptaid=pla-298340505777&gclid=CjwKCAiAiML-BRAAEiwAuWVgggb4ckwj-aGLGhTIkNoxYfI1v3Fr-CB8v40s1W2gqoAAvGfc1Hr1jRoC4CsQAvD_BwE
                                          • Vetiundefined
                                            Veti
                                            yes but you need the fibreglass sleeving.
                                            https://reprapworld.de/products/extruder/extruder_parts/thermistors/fibreglass_sleeving_incl_thermistor/
