    Heater Will not turn off once started.
    1.6k
    • Turricannundefined
      Turricann
      No the image on the Pi is the one from the link but just checked,
      pi@duet3:~ $ sudo apt list duetcontrolserver -a
      Listing... Done
      duetcontrolserver/stable,now 3.1.1 armhf [installed,automatic]
      duetcontrolserver/stable 3.1.0 armhf
      duetcontrolserver/stable 1.2.4.0 armhf
      duetcontrolserver/stable 1.2.3.0 armhf
      duetcontrolserver/stable 1.2.2.1 armhf
      duetcontrolserver/stable 1.1.0.5 armhf
      duetcontrolserver/stable 1.0.4.1 armhf
      duetcontrolserver/stable 1.0.3.1 armhf
        Yes, and you can either update the Pi to also be 3.2 b4, or flash the duet back to 3.1.1
          If you wish to use the latest unstable DSF components, you can run the following commands instead:
          wget -q https://pkg.duet3d.com/duet3d.gpg
          wget -q https://pkg.duet3d.com/duet3d-unstable.list
          sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
          sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
          sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
          sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
          https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
            Turricann
            Thanks that is what i needed to sort that issue, I upgraded to try and resolve the original issue about the heater recommended by @T3P3Tony ,
            I will redo config.g now and see what happens with the heaters.. thanks for your support.
              Turricann
              OK config.g redone left every thing else default from a clean install on the Pi
              On my duet 3 6hc i have the below,
              Running on a 24v supply
              Out0 - heatbed. - on/off working OK
              Out1 - 24v heater.
              Out7 - Hotend fan
              Out8 - Partcooling fan
              Out9 -Partcooling fan (Disconnected)
              TEMP0 - Heatbed thermistor(B9350)
              TEMP1 - Hotend Thermistor (B4138)
              Temp3- Thermistor from Z probe.
              IO_0 = pannal Due - currently disconnected.
              IO_3 = Z probe Pinda v2 type
              Driver 0 = X
              Driver 1 = Y
              Driver 2 = Z1
              Driver 3 = E0
              Driver 4 = Z2
              Driver 5 = Z3
              Thats is everything connected and my config.g is,
              ; generated by RepRapFirmware Configuration Tool v3.1.10 on Mon Dec 07 2020 21:49:17 GMT+0000 (Greenwich Mean Time)
              G21 ; Work in millimetres
              M550 P"Duet 3" ; set printer name
              M669 K1 ; select CoreXY mode
              M569 P0.0 S0 ; physical drive 0.0 goes backwards (X)
              M569 P0.1 S1 ; physical drive 0.1 goes forwards (Y)
              M569 P0.3 S1 ; physical drive 0.3 goes forwards (E0)
              M569 P0.2 S0 ; physical drive 0.2 goes backwards (Z1 Front Left Motor)
              M569 P0.4 S0 ; physical drive 0.4 goes backwards (Z2 Back Left Motor)
              M569 P0.5 S0 ; physical drive 0.5 goes backwards (Z3 Right Motor)
              M584 X0.0 Y0.1 Z0.2:0.4:0.5 E0.3 ; three Z motors connected to driver outputs 2,4 and 5
              M671 X205:205:-195 Y-205:205:0 S0.01 ; leadscrews at Front left (X195 Y195), Rear left (X195 Y-195) and right (X0 Y-195)
              M92 X160.00 Y160.00 Z80.00 E420.00 ; set steps per mm M92 X80 Y80 for 1.8º degree steppers and M92 X160 Y160 for 0.9º
              M566 X600.00 Y600.00 Z360.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X3000.00 Y3000.00 Z120.00 E120.00 ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E1800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X410 Y410 Z410 S0 ; set axis maxima
              M574 X1 Y1 S3 ; use stall guard for XY endstops (X min, y max)
              M574 Z1 S2 ; Set endstops controlled by probe
              ;M915 X Y R0 F0 H400 ; Stall guard config when not homing
              M558 P5 C"^io3.in" I1 H1 F1000 T6000 A20 S0.005 ; Prusa PindaV2 sensor config.
              M308 S2 P"temp3" A"Pinda V2" Y"thermistor" T100000 B3950 ; Prusa PindaV2 temperature config.
              G31 P500 X0 Y30 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 X15:375 Y15:375 S20 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
              M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
              M106 P0 S0.7 H1 ; set fan 0 value. Thermostatic control is turned
              M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
              M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
              M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
              M563 P0 S"HOTEND" D0 H1 F0 ; define tool 0
              T0 ; select first tool
                Phaedrux Moderator @Turricann
                @Turricann So with a fresh config and Pi the heater is still staying on once enabled?
                But it's not turning on automatically when power is first applied, right?
                  Turricann
                  yes that is correct as long as the hotend is below 45 Degrees or fan0 has not got thermostatic control disabled .
                  If thermal control is enabled and the hotend is below 45 degrees the heater will turn on and off normally,
                  If its above 45 Degrees the hotend will come on with power.
                  This is why i came to the conclusion the heater will not turn when the fan is on.
                  one more thing is if there are no fans set up i cannot control the heater.
                    It looks like your config was pasted twice maybe in your last post?
                    Turricannundefined 1 Reply Last reply Reply Quote 0
                      Turricann
                      One other thing is when the heater comes on at power up its not instant there is about a 30 second delay like it only happens when the pi powers up.
                        Turricann @Phaedrux
                        @Phaedrux yes it was just realized that myself.
                          Turricann
                          Thermistor attached to heater is a ATC Semitec 104GT-2 104NT-4-R025H42G
                            @Turricann, please state clearly which heater output and which fan output are the ones involved in this issue. I think it's heater 1 on out1, but you appear to have changed the fan configuration between the original config.g you posted and the recent one, and I can't tell whether the fan involved is on out7, out8 or out9.
                              Turricann @dc42
                              @dc42 Heater is on output1 and fan is on out7(F0)
                                Thanks. How have you wired the hot end heater to OUT0 and the fan to OUT7? Are the wires for the heater and fan completely separate, or have you used a common wire for both of them?
                                  Turricann @dc42
                                  @dc42 they have there own power and ground cables. Wired to there respective terminals, there only two pin headers so not much to go wrong there.
                                    droftarts administrators @Turricann
                                    @Turricann are the wires for hot end and fan bundled together? Is there any chance that connections in the wiring loom could be shorting between them? The pins between out1 and out7 are electrically isolated from each other (different MOSFET drivers and not adjacent at the MCU) so it's unlikely to be a short on the board causing this problem. Do you have a mulitmeter that you can use to check for shorts between the fan and heater wiring? Because the symptoms you describe really do point in that direction.
                                    Turricannundefined 1 Reply Last reply Reply Quote 1
                                      Turricann @droftarts
                                      @droftarts Well after some head scratching and working through my wiring you were dead right i had a short between the two ground plane's on a custom pcb which i was using as breakout board, the issue was when i was metering the hotend i removed the screws to get to the back of the PCB when i done this there is no short, but because i inadvertently connected the two ground planes to via's where the screws went threw the PCB and those screw's went into to a metal plate it caused a short.
                                      Picked up a tool board from ooznest to replace my PCB.
                                      Thanks For you support on this.
                                      droftartsundefined 1 Reply Last reply Reply Quote 1
                                        @Turricann Glad you got it sorted! Those sort of issues can be a real pain to track down. Thanks for your continued support of our products!
                                          Turricann
                                          @droftarts there's always a possibility but they are two independent runs straight back to the board, I have checked the cable for short but not between theater and fan.
