    Steps per mm keep changing
    41
    2.7k
    • JoergS5undefined
      JoergS5 @akhilnex
      @akhilnex said in Steps per mm keep changing:
      M350 X32 Y128 Z128 I1 ; configure microstepping with interpolation
      M350 E128:128:128 I0 ; configure microstepping with interpolation
      M92 X6400.00 Y5120.00 Z5120.00 E1207.22:1207.22:1207.22 ; set steps per mm
      The settings don't fit for a 2005 spindle.
      The calculation is steps/rotation * microsteps / mm/rotation,
      • i.e. 200 * 32 / 5 = 1280 for X
      • 200 * 128 / 5 = 5120 for Y and Z
        so the M92 for X is wrong.
      You can also check the M122 and check for hiccups whether you have lost steps.
      Your M203 setting of speed is very low (only about 6 mm/s), this is also strange.
      But your question was about the extruder:
      E128 with I0 without interpolation could mean too high step rate (3 extruders, plus xyz steps), but this would show up in the hiccup reporting of M122. Speed for extruder is maximum 20 mm/s for each extruder, and 1200 steps/mm meaning 24 kHz for every extruder, total 72 kHz. And I would check the current for the Nema 17 steppers, whether 2100 mA is 50 to 80% of the RMS current in the datasheet.
      I read an intersting article yesterday https://www.geckodrive.com/support/step-motor-basics/accuracy-and-resolution.html about accuracy of steppers. The linearity of steppers of microsteps varies by stepper models. A high microstepping doesn't mean high accuracy. Imho a high ratio gear is a better idea if you want to achieve a high precision of the extruders.
      • akhilnexundefined
        akhilnex
        Gentlemen,
        I have now taken a bunch of pictures to clear things up and I apologize for little information past evening. Let me start by explaining the setup in a more detailed manner. The entire CNC/3D printer is an experimental build and I had been running the CNC (X,Y,Z) portion of it originally through another chipset and external drivers for steppers with good results and accuracy.
        The reason I changed to Duet 3 was to make a machine that can also 3D print and take advantage of being a CNC mill when needed.
        This is based on the reprap configurator tool:
        Pictures below show the entire build and the controller with dual Z-axis (that I plan to manually change to based on either I am using CNC mill or 3D print function)
        The picture below shows the 3 filaments mounted on a tool board with NEMA 17 motors. The filament runs through a 7.5 mm hob nut and to the hot end (hot end never tested still working on steppers):
        What I have tried so far?
        • Changed the microstepping to 16x, 32x, 128x with and without interpolation with same results.
        • Changed motor current in hopes to reduce any back EMF that may be causing deviation in steps per mm
        • Played with steps per mm, acceleration, max speed, current etc. to see if it makes any difference.
        So far I have deviation in all drives that is off by a known amount and I have been wondering if there was a possibility to use a multiplying factor based on deviation that I have been noticing.
        Please find the config.g file attached. I may have tweaked a few things.
        config.g
        • akhilnexundefined
          akhilnex @Veti
          @Veti Thanks. I checked and I am using the cartesian type. Also I have posted the config.g file in my reply to the main thread.
          • akhilnexundefined
            akhilnex @theruttmeister
            @theruttmeister said in Steps per mm keep changing:
            You say that your axies are all running that same leadscrew... but your settings don't match that. Your Y and Z match what you say, your X is off.
            @theruttmeister you are right and I forgot to mention past evening that I installed a gear reducer (5:1) to run the heavy Y axis gantry.
            • Vetiundefined
              Veti
              those are some beefy stepper motors. can you post the specs for them?
              akhilnexundefined 1 Reply Last reply Reply Quote 0
              • akhilnexundefined
                akhilnex @Veti
                @Veti
                NEMA 17: https://www.omc-stepperonline.com/nema-17-bipolar-1-8deg-65ncm-92oz-in-2-1a-3-36v-42x42x60mm-4-wires-it.html
                NEMA 23: https://www.omc-stepperonline.com/nema-23-bipolar-3nm-425oz-in-4-2a-57x57x114mm-4-wires-stepper-motor-cnc.html
                Specification table is on the second tab. I didn't find a torque curve or any performance graph though.
                • Vetiundefined
                  Veti @akhilnex
                  @akhilnex
                  you should aim for about 75% of the rated current.
                  so around 3150 for the nema23.
                  and stay with x16 with interpolation for now.
                  going high puts unnecessary load on the cpu.
                  akhilnexundefined 1 Reply Last reply Reply Quote 1
                  • akhilnexundefined
                    akhilnex @Veti
                    @Veti I have made the changes to 16x and the deviation is still present. Although the amount of deviation is slightly different for requested [actual] readouts: 50 [ 48.5 mm], 100 [102 mm], 150 [155 mm], 200 [210 mm], 250 [265 mm], 300 [317.5]. It seems like the pattern changed but the amount exceeding follows a similar trend starting with low deviation and increasing at 2.5 mm increments as the the requested distance goes up.new reprap 16x.PNG config (1).g
                    • JoergS5undefined
                      JoergS5 @akhilnex
                      @akhilnex please be aware that 1:5 gears are often 1:5.18 gears (exactly 1: 5+2/11 = 1: 5.181818). The datasheet will tell you.
                      • akhilnexundefined
                        akhilnex @JoergS5
                        @JoergS5 that's a good point and I think it is true 5:1 planetary reduction gearbox. Here is the link of what I got on Amazon: https://www.amazon.com/dp/B089R8CC1Z/ref=cm_sw_r_cp_apa_fabc_.-m6FbC0RS0XV
                        Seems like with the new settings the x,y,z axis are running quite accurate. However the NEMA 17 extruder steppers are the one causing trouble.
                        • fcwiltundefined
                          fcwilt
                          I used these for my belt driven Z axis conversion.
                          The 5-to-1 is a true 5-to-1.
                          They have a similar "economy" line product which is not.
                          • JoergS5undefined
                            JoergS5
                            yes, looks like a true 5:1
                            • JoergS5undefined
                              JoergS5 @akhilnex
                              @akhilnex did you check M122 after running the steppers for some time? M122 reports several possible problems, please post the result. (one is hiccups, but also stepper problems, voltage problems etc.).
                              • akhilnexundefined
                                akhilnex @JoergS5
                                @JoergS5 M122
                                RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                                Board ID: 08DJM-956L2-G43S8-6J9D0-3S46Q-9U2GD
                                Used output buffers: 3 of 40 (40 max)
                                Static ram: 154604
                                Dynamic ram: 162740 of which 20 recycled
                                Exception stack ram used: 376
                                Never used ram: 75476
                                Tasks: NETWORK(ready,356) ETHERNET(blocked,436) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,60) MAIN(running,4512) IDLE(ready,76)
                                Owned mutexes:
                                Last reset 00:31:39 ago, cause: software
                                Last software reset at 2020-12-27 10:43, reason: User, spinning module GCodes, available RAM 75476 bytes (slot 3)
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                                Error status: 4
                                MCU temperature: min 40.6, current 41.1, max 41.5
                                Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                Driver 0: standstill, reads 20644, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: standstill, reads 20632, writes 27 timeouts 0, SG min/max 0/81
                                Driver 2: standstill, reads 20645, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: standstill, reads 20646, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: standstill, reads 20646, writes 14 timeouts 0, SG min/max 0/0
                                Driver 5: standstill, reads 20634, writes 27 timeouts 0, SG min/max 0/431
                                Slowest loop: 999.77ms; fastest: 0.13ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 2.8ms, write time 29.6ms, max retries 0
                                Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 1347113ms
                                === MainDDARing ===
                                Scheduled moves: 12, completed moves: 12, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                === AuxDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 57.01ms; fastest: 0.03ms
                                HTTP sessions: 1 of 8
                                • Ethernet -
                                  State: active
                                  Error counts: 0 0 0 0 0
                                  === CAN ===
                                  Messages sent 7600, longest wait 0ms for type 0
                                  === Linux interface ===
                                  State: 0, failed transfers: 0
                                  Last transfer: 1899941ms ago
                                  RX/TX seq numbers: 0/1
                                  SPI underruns 0, overruns 0
                                  Number of disconnects: 0
                                  Buffer RX/TX: 0/0-0
                                • akhilnexundefined
                                  akhilnex
                                  Since X,Y and Z gantries are working fine, I am wondering if the NEMA 17 motors on E0,1,2 that I purchased from stepperonline are faulty. I am thinking about ordering atleast one different brand NEMA 17 and a regular extruder hob gear to check and see if it works any better.
                                  theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                                  • akhilnexundefined
                                    akhilnex
                                    Can an issue arise from having NEMA 23 and NEMA 17 running on the same board? Should they all be the same 23s or 17s?
                                      A Former User @akhilnex
                                      as long as the individual motors are suited for the drivers then you can mix and match whatever you like. (you'd probably want to have the same specs motor if you run multiple motors in parallel or serial on a single driver)
                                      the nema number has more to do with physical dimensions than electrical parameters, so not directly relevant even though physically larger motors usually have lower impedance and higher current ratings.
                                      • JoergS5undefined
                                        JoergS5 @akhilnex
                                        @akhilnex M122 looks ok, but only a part of the drivers were used. You can repeat M122 after a longer test again. The short test didn't show problems.
                                        I thought about that maybe your multi extruder causes the difference. Depending on pressure and temperature, the speed could vary.
                                        • akhilnexundefined
                                          akhilnex @JoergS5
                                          @JoergS5 I haven't even gotten to the multi extruder yet. Just trying to get the extruder steppers to run correctly.
                                          Once I get accurate reading on the filament movement, my next step will be to pass it through the heated multi-extruder. I guess that's the fun of building random design from scratch as every new step brings a brand new set of challenge! 🙃
                                          • JoergS5undefined
                                            JoergS5 @akhilnex
                                            @akhilnex If the extruder speed is still wrong, you could try separating the problem into it's possible single problems. The problem could be the stepper speed, the hob nut, hob nut slipping, filament slipping, different diameters of the filament.
                                            I would use the stepper with a normal pulley first and measure the speed and verify that it has the expected speed. You could use a belt and measure the distance. When it's ok, the problem is behind the stepper shaft. If it's wrong, it can be a configuration, electronics with wiring, stepper, shaft problem.
                                            Developing something new is without question an exciting journey for you!
