    Mini 5 (with toolboard) and leveling using X2 Motors
    969
    • Vetiundefined
      Veti
      and a g29 across the bed works?
      JayJayundefined 1 Reply Last reply Reply Quote 0
      • JayJayundefined
        JayJay @Veti
        @Veti
        yes it does.
        I re-installed my Duet-2 all is working again with the same bed.g file.
        i have compared my Duet-2 & mini-5 config's and i can see nothing wrong with the mini-5 config
        • Vetiundefined
          Veti @JayJay
          @JayJay
          neither can i. and the probing working sometimes is not something you can configure.
          JayJayundefined 1 Reply Last reply Reply Quote 1
          • JayJayundefined
            JayJay @Veti
            @Veti said in Mini 5 (with toolboard) and leveling using X2 Motors:
            @JayJay
            Thank for the help, i will just wait and see what any of the duet team have to say , this board was a christmas gift so i will ask my uncle where he bought it
              Firmware version? Can you post the results of M122?
              • JayJayundefined
                JayJay @Phaedrux
                @Phaedrux said in Mini 5 (with toolboard) and leveling using X2 Motors:
                The Board is removed so the M122 will show some errors i think.
                i installed the board (and toolboard) in my core-xy , which normally has a duet-3-6hc fitted and the mini-5 runs fine in there, so im not sure why it doesnt like being in my hacked up i3, and even stranger that my Duet-2 wifi runs fine when i put it back into the i3, both printers sit side by side so its not a location related issue.
                i have been racking my brains with this one as it makes no sense at all.
                M115:
                FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-12-24
                M122
                RepRapFirmware for Duet 3 Mini 5+ version 3.2-RC2 running on Duet 3 Mini5plus WiFi (standalone mode)
                Used output buffers: 3 of 40 (11 max)
                Static ram: 98732
                Dynamic ram: 107196 of which 496 recycled
                Never used RAM 38792, free system stack 140 words
                Tasks: NETWORK(ready,192) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,360) TMC(blocked,123) MAIN(running,444) IDLE(ready,20) AIN(blocked,267)
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:01:54 ago, cause: power up
                Last software reset at 2020-12-30 22:53, reason: User, GCodes spinning, available RAM 38752, slot 2
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00451000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,0
                Aux1 errors 0,0,0
                Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
                Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                Date/time: 2021-01-01 15:00:52
                Cache data hit count 222524317
                Slowest loop: 5.31ms; fastest: 0.11ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 4.2ms, write time 0.0ms, max retries 0
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters = 0 -1, chamberHeaters = -1 -1
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 10.70ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is active
                  WiFi firmware version 1.25beta0
                  WiFi MAC address f4:cf:a2:6f:bd:af
                  WiFi Vcc 3.37, reset reason Power up
                  WiFi flash size 2097152, free heap 25264
                  WiFi IP address 192.168.0.115
                  WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  === CAN ===
                  Messages queued 1015, send timeouts 1012, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                  Phaedrux Moderator @JayJay
                  @JayJay said in Mini 5 (with toolboard) and leveling using X2 Motors:
                  That is confusing. An intermittent short in something connected?
                  • JayJayundefined
                    JayJay @Phaedrux
                    its the exact same wiring between the mini-5 and the Duet-2 and i thought about that and have been probing for shorts and found nothing
                      Some thoughts:
                      • Is the tool board definitely running 3.2RC2 as well?
                      • Try adding a settling delay parameter (R) to the M558 command, e.g. R0.2 or R0.5
                      • You said the probe doesn't register as triggered, yet you don't get a head crash. That means either the dive height is too low to probe deep enough, or the probe trigger is being registered for the purpose of stopping the Z move but not for the purpose of recording the stop height. So try increasing the dive height - very carefully!
                      • JayJayundefined
                        JayJay
                        @Phaedrux
                        @Veti
                        Well I finally fixed it....
                        My homeall.g had G30 S-3 in the script.
                        I removed that and changed it to single G30 command on its own and now it completes the G32 action with no errors, I dont know why it works fine on my Duet-2 with the S-3 switch in my homeall but the mini 5 doesnt like it
                          dc42 administrators @JayJay
                          @Phaedrux
                          @Veti
                          Perhaps your Duet 2 is running old firmware that doesn't support the S3 parameter?
                          • JayJayundefined
                            JayJay @dc42
                            @dc42 said in Mini 5 (with toolboard) and leveling using X2 Motors:
                            @Phaedrux
                            @Veti
                            The Duet-2 was/is on Release 3.2-RC1
                            And to confirm
                            Duet-2 WOULD complete the action with G30 S-3
                            Duet-3 Mini-5+ WOULD NOT complete the action G30 S-3
                            The Mini-5+ would only complete after i removed the S-3 switch
