Mini 5 (with toolboard) and leveling using X2 Motors
969
    JayJay @Veti
    @Veti
    yes it does.
    I re-installed my Duet-2 all is working again with the same bed.g file.
    i have compared my Duet-2 & mini-5 config's and i can see nothing wrong with the mini-5 config
    undefined 1 Reply Last reply 31 Dec 2020, 14:03 Reply Quote 0
      Veti @JayJay
      @JayJay
      neither can i. and the probing working sometimes is not something you can configure.
      undefined 1 Reply Last reply 31 Dec 2020, 14:42 Reply Quote 1
        JayJay @Veti
        @Veti said in Mini 5 (with toolboard) and leveling using X2 Motors:
        @JayJay
        Thank for the help, i will just wait and see what any of the duet team have to say , this board was a christmas gift so i will ask my uncle where he bought it
          Firmware version? Can you post the results of M122?
          undefined 1 Reply Last reply 1 Jan 2021, 13:13 Reply Quote 0
            JayJay @Phaedrux
            @Phaedrux said in Mini 5 (with toolboard) and leveling using X2 Motors:
            The Board is removed so the M122 will show some errors i think.
            i installed the board (and toolboard) in my core-xy , which normally has a duet-3-6hc fitted and the mini-5 runs fine in there, so im not sure why it doesnt like being in my hacked up i3, and even stranger that my Duet-2 wifi runs fine when i put it back into the i3, both printers sit side by side so its not a location related issue.
            i have been racking my brains with this one as it makes no sense at all.
            M115:
            FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-12-24
            M122
            RepRapFirmware for Duet 3 Mini 5+ version 3.2-RC2 running on Duet 3 Mini5plus WiFi (standalone mode)
            Used output buffers: 3 of 40 (11 max)
            Static ram: 98732
            Dynamic ram: 107196 of which 496 recycled
            Never used RAM 38792, free system stack 140 words
            Tasks: NETWORK(ready,192) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,360) TMC(blocked,123) MAIN(running,444) IDLE(ready,20) AIN(blocked,267)
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:01:54 ago, cause: power up
            Last software reset at 2020-12-30 22:53, reason: User, GCodes spinning, available RAM 38752, slot 2
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00451000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Date/time: 2021-01-01 15:00:52
            Cache data hit count 222524317
            Slowest loop: 5.31ms; fastest: 0.11ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 4.2ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Bed heaters = 0 -1, chamberHeaters = -1 -1
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 10.70ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is active
              WiFi firmware version 1.25beta0
              WiFi MAC address f4:cf:a2:6f:bd:af
              WiFi Vcc 3.37, reset reason Power up
              WiFi flash size 2097152, free heap 25264
              WiFi IP address 192.168.0.115
              WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              === CAN ===
              Messages queued 1015, send timeouts 1012, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
            undefined 1 Reply Last reply 1 Jan 2021, 17:28 Reply Quote 0
              Phaedrux Moderator @JayJay
              @JayJay said in Mini 5 (with toolboard) and leveling using X2 Motors:
              That is confusing. An intermittent short in something connected?
              undefined 1 Reply Last reply 5 Jan 2021, 14:27 Reply Quote 0
                JayJay @Phaedrux
                its the exact same wiring between the mini-5 and the Duet-2 and i thought about that and have been probing for shorts and found nothing
                  Some thoughts:
                  • Is the tool board definitely running 3.2RC2 as well?
                  • Try adding a settling delay parameter (R) to the M558 command, e.g. R0.2 or R0.5
                  • You said the probe doesn't register as triggered, yet you don't get a head crash. That means either the dive height is too low to probe deep enough, or the probe trigger is being registered for the purpose of stopping the Z move but not for the purpose of recording the stop height. So try increasing the dive height - very carefully!
                    JayJay
                    @Phaedrux
                    @Veti
                    Well I finally fixed it....
                    My homeall.g had G30 S-3 in the script.
                    I removed that and changed it to single G30 command on its own and now it completes the G32 action with no errors, I dont know why it works fine on my Duet-2 with the S-3 switch in my homeall but the mini 5 doesnt like it
                    dc42undefined 1 Reply Last reply 20 Jan 2021, 21:54 Reply Quote 1
                      dc42 administrators @JayJay
                      @Phaedrux
                      @Veti
                      Perhaps your Duet 2 is running old firmware that doesn't support the S3 parameter?
                      undefined 1 Reply Last reply 20 Jan 2021, 21:59 Reply Quote 0
                        JayJay @dc42
                        @dc42 said in Mini 5 (with toolboard) and leveling using X2 Motors:
                        @Phaedrux
                        @Veti
                        The Duet-2 was/is on Release 3.2-RC1
                        And to confirm
                        Duet-2 WOULD complete the action with G30 S-3
                        Duet-3 Mini-5+ WOULD NOT complete the action G30 S-3
                        The Mini-5+ would only complete after i removed the S-3 switch
