    Mini 5 (with toolboard) and leveling using X2 Motors
    1.0k
    • Vetiundefined
      Veti
      @JayJay said in Mini 5 (with toolboard) and leveling using X2 Motors:
      G30 P0 X50 Y170 Z-99999
      G30 P1 X350 Y170 Z-99999 S2
      can you issue those commands manually? whats the output in the console
      JayJayundefined 1 Reply Last reply Reply Quote 0
      • JayJayundefined
        JayJay @Veti
        @Veti said in Mini 5 (with toolboard) and leveling using X2 Motors:
        i issued both manually
        G30 P0 X50 Y170 Z-99999 completes fine (shows green in the console)
        G30 P1 X350 Y170 Z-99999 S2 shows: Error: Z probe was not triggered during probing move
        but i can physically see the probe operate and the Z axis react and the head lifts back up
        • Vetiundefined
          Veti
          and a g29 across the bed works?
          • JayJayundefined
            JayJay @Veti
            @Veti
            yes it does.
            I re-installed my Duet-2 all is working again with the same bed.g file.
            i have compared my Duet-2 & mini-5 config's and i can see nothing wrong with the mini-5 config
            • Vetiundefined
              Veti @JayJay
              @JayJay
              neither can i. and the probing working sometimes is not something you can configure.
              JayJayundefined 1 Reply Last reply Reply Quote 1
              • JayJayundefined
                JayJay @Veti
                @JayJay
                Thank for the help, i will just wait and see what any of the duet team have to say , this board was a christmas gift so i will ask my uncle where he bought it
                  Firmware version? Can you post the results of M122?
                  • JayJayundefined
                    JayJay @Phaedrux
                    @Phaedrux said in Mini 5 (with toolboard) and leveling using X2 Motors:
                    The Board is removed so the M122 will show some errors i think.
                    i installed the board (and toolboard) in my core-xy , which normally has a duet-3-6hc fitted and the mini-5 runs fine in there, so im not sure why it doesnt like being in my hacked up i3, and even stranger that my Duet-2 wifi runs fine when i put it back into the i3, both printers sit side by side so its not a location related issue.
                    i have been racking my brains with this one as it makes no sense at all.
                    M115:
                    FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-12-24
                    M122
                    RepRapFirmware for Duet 3 Mini 5+ version 3.2-RC2 running on Duet 3 Mini5plus WiFi (standalone mode)
                    Used output buffers: 3 of 40 (11 max)
                    Static ram: 98732
                    Dynamic ram: 107196 of which 496 recycled
                    Never used RAM 38792, free system stack 140 words
                    Tasks: NETWORK(ready,192) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,360) TMC(blocked,123) MAIN(running,444) IDLE(ready,20) AIN(blocked,267)
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:01:54 ago, cause: power up
                    Last software reset at 2020-12-30 22:53, reason: User, GCodes spinning, available RAM 38752, slot 2
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00451000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
                    Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                    Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                    Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                    Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                    Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                    Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                    Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                    Date/time: 2021-01-01 15:00:52
                    Cache data hit count 222524317
                    Slowest loop: 5.31ms; fastest: 0.11ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 4.2ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Bed heaters = 0 -1, chamberHeaters = -1 -1
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 10.70ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is active
                      WiFi firmware version 1.25beta0
                      WiFi MAC address f4:cf:a2:6f:bd:af
                      WiFi Vcc 3.37, reset reason Power up
                      WiFi flash size 2097152, free heap 25264
                      WiFi IP address 192.168.0.115
                      WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
                      Clock register 00002002
                      === CAN ===
                      Messages queued 1015, send timeouts 1012, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                      Phaedrux Moderator @JayJay
                      That is confusing. An intermittent short in something connected?
                      • JayJayundefined
                        JayJay @Phaedrux
                        its the exact same wiring between the mini-5 and the Duet-2 and i thought about that and have been probing for shorts and found nothing
                          Some thoughts:
                          • Is the tool board definitely running 3.2RC2 as well?
                          • Try adding a settling delay parameter (R) to the M558 command, e.g. R0.2 or R0.5
                          • You said the probe doesn't register as triggered, yet you don't get a head crash. That means either the dive height is too low to probe deep enough, or the probe trigger is being registered for the purpose of stopping the Z move but not for the purpose of recording the stop height. So try increasing the dive height - very carefully!
                          • JayJayundefined
                            JayJay
                            @Phaedrux
                            @Veti
                            Well I finally fixed it....
                            My homeall.g had G30 S-3 in the script.
                            I removed that and changed it to single G30 command on its own and now it completes the G32 action with no errors, I dont know why it works fine on my Duet-2 with the S-3 switch in my homeall but the mini 5 doesnt like it
                              dc42 administrators @JayJay
                              @Phaedrux
                              @Veti
                              Perhaps your Duet 2 is running old firmware that doesn't support the S3 parameter?
                              • JayJayundefined
                                JayJay @dc42
                                @dc42 said in Mini 5 (with toolboard) and leveling using X2 Motors:
                                @Phaedrux
                                @Veti
                                The Duet-2 was/is on Release 3.2-RC1
                                And to confirm
                                Duet-2 WOULD complete the action with G30 S-3
                                Duet-3 Mini-5+ WOULD NOT complete the action G30 S-3
                                The Mini-5+ would only complete after i removed the S-3 switch
