    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    30.6k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @Sindarius
      @Sindarius
      After de-energising and powering up everything is working now....
      A simple sw-reset after the update was not enough.....
      (UTC+1)
      • PCRundefined
        PCR
        @Sindarius
        File processed with arcwelder
        01_SP2_Unterschale_DQ2_PET_0.3mm_1h39m.gcode.txt
        • PCRundefined
          PCR
          Sindariusundefined 1 Reply Last reply Reply Quote 0
          • Sindariusundefined
            Sindarius @PCR
            @PCR I’ll take a look at the file. Those are some impressive arcs πŸ˜„
            • PCRundefined
              PCR
              no rush πŸ˜‰ was more like a little note
                Sindarius @PCR
                @PCR This probably looks better.
                  Sindarius
                  G3 fix is in RC2
                  https://github.com/Duet3D/DuetWebControl/releases/tag/3.2.0-rc2
                    A Former User @Sindarius
                    @Sindarius
                    A small thing that I catched:
                    On all 3-d-software I am aware of, if a cartesian-csys-system is used -> x-y-z are coloured in r-g-b,
                    e.g. "sol...orks" here:
                    e.g. "rh...-3d":
                    e.g. "sim....y-3D":
                    e.g. or the height-map within "DWC":
                    but here it is r-b-g:
                    Before I forget: Thanks for you cool work!
                    πŸ˜‰
                    Sindariusundefined 1 Reply Last reply Reply Quote 1
                      Sindarius @A Former User
                      @LB Since it is cosmetic I’ll work the change into 3.3
                      • CCS86undefined
                        CCS86
                        Cool plugin!
                        I'm trying it out on a Duet Maestro on DWC/RRF 3.2 RC2
                        Seeing some weirdness on one file. With "spread lines" enabled, everything looks good:
                        But with it disabled, some weirdness:
                          @Sindarius
                          Cool πŸ™‚ - looking forward!
                          Another small thing thatΒ΄s related to it:
                          When within "settingS" choosing "volume" (instead of "bed") the wireframe is by default blue, and since 1 of the axis is also blue it might be a unlucky default colour for the wireframe of the print-volume regarding the default-csys-colouring:
                          If the default would be a slightly transparent white (I know transparency is not there yet so to show what I mean I picked a greyish tone), you could better see the the csys:
                          I know this is a field where opinions might easily differ, so it is maybe just something to think about πŸ˜‰
                          Thanks for all your work,
                          cheers!
                            Sindarius @CCS86
                            @CCS86 if you could share your file that would help me to look at it.
                            CCS86undefined 1 Reply Last reply Reply Quote 0
                              @LB volume is an odd duck because I had to do some things to make something work for delta beds. Transparency is always a pain heh
                                @Sindarius
                                reliable results with (alpha + all-of-the-webbrowsers-out-there)=oxymoron 🀣
                                • CCS86undefined
                                  CCS86 @Sindarius
                                  @Sindarius said in 3D GCode Viewer integrated with DWC:
                                  Sure thing.
                                  Playseat Foot.gcode.txt
                                    Sindarius @CCS86
                                    @CCS86 Thanks for the file. I managed to take a look at it and the line that is tripping up the viewer is in your ending gcode trips up the viewer into thinking the last layer height should be 5mm tall which causes it to freak out.
                                    G1 Z5 E-3 F4000
                                    I commented out that line and got this
                                    This is not an issue with your gcode but an issue with how the viewer not appreciating a retract and z travel in the same line. I'll look at getting a fix in for 3.3
                                    Also because line rendering does not care about layer height doing forced line rendering showed the correct results.
                                    Either way thank you for sharing your file and I'll get this resolved.
                                    Thanks!
                                    • CCS86undefined
                                      CCS86
                                      Awesome, glad it helped!
                                      • theruttmeisterundefined
                                        theruttmeister
                                        *is printing a multi part file...
                                        One of the parts as apparently on a blob of oil or some nonsense, is going to fail and probably ruin the whole print.
                                        Pause print. Sigh.
                                        Remember that the g-code viewer has a cancel part function.
                                        upload version 3.2 of DWC.
                                        enable Gcode Viewer plugin.
                                        cancel the failing part.
                                        RESUME PRINT!
                                        ALL. OF. THE. WINNING.
                                        Like seriously, epic epic feature to have.
                                        Isolate, substitute, verify.
                                        Phaedruxundefined Sindariusundefined 2 Replies Last reply Reply Quote 3
                                          Phaedrux Moderator @theruttmeister
                                          @theruttmeister said in 3D GCode Viewer integrated with DWC:
                                          Mid Print?! Without skipping a beat? Nice.
                                            Sindarius @theruttmeister
                                            @theruttmeister I have to say that I am impressed with this
