3D GCode Viewer integrated with DWC
Duet Web Control wishlist
42
284
31.3k
    bastien @bastien
    @bastien said in 3D GCode Viewer integrated with DWC:
    i just install 3.2, i viewer in sub menu in files but no in main menu
    it's ok, i re install plug in and start in new plug in menu 😊 😊
      DIY-O-Sphere
      @Sindarius
      Are there known issues with the latest version on a maestro?
      Cant't get it working anymore. (RRF 3.2_b4 +0.11.1)
      The previous versions of fw and plugin worked. (guess RRF 3.2_b2 +0.6.5)
      (UTC+1)
      undefined 1 Reply Last reply 13 Dec 2020, 20:10 Reply Quote 0
        Sindarius @DIY-O-Sphere
        @DIY-O-Sphere I pulled down and installed the 3.2-beta4 that is on GitHub, I normally run my own build, and was able to install my plugin without any problems. Make sure you are pulling the latest version of my plugin from the github releases page https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases. I don't believe the firmware version itself should have any play since the plugin is a javascript solution that runs in DWC itself.
        Just double check the following to make sure you are on the latest
        undefined 1 Reply Last reply 14 Dec 2020, 05:28 Reply Quote 0
          DIY-O-Sphere @Sindarius
          @Sindarius
          After de-energising and powering up everything is working now....
          A simple sw-reset after the update was not enough.....
          (UTC+1)
            PCR
            @Sindarius
            File processed with arcwelder
            01_SP2_Unterschale_DQ2_PET_0.3mm_1h39m.gcode.txt
              PCR
              undefined 1 Reply Last reply 23 Dec 2020, 18:33 Reply Quote 0
                Sindarius @PCR
                @PCR I’ll take a look at the file. Those are some impressive arcs πŸ˜„
                  PCR
                  no rush πŸ˜‰ was more like a little note
                  undefined 1 Reply Last reply 23 Dec 2020, 20:24 Reply Quote 0
                    Sindarius @PCR
                    @PCR This probably looks better.
                      Sindarius
                      G3 fix is in RC2
                      https://github.com/Duet3D/DuetWebControl/releases/tag/3.2.0-rc2
                      ? 1 Reply Last reply 30 Dec 2020, 14:27 Reply Quote 0
                        A Former User @Sindarius
                        @Sindarius
                        A small thing that I catched:
                        On all 3-d-software I am aware of, if a cartesian-csys-system is used -> x-y-z are coloured in r-g-b,
                        e.g. "sol...orks" here:
                        e.g. "rh...-3d":
                        e.g. "sim....y-3D":
                        e.g. or the height-map within "DWC":
                        but here it is r-b-g:
                        Before I forget: Thanks for you cool work!
                        πŸ˜‰
                        undefined 1 Reply Last reply 30 Dec 2020, 23:07 Reply Quote 1
                          Sindarius @A Former User
                          @LB Since it is cosmetic I’ll work the change into 3.3
                          ? 1 Reply Last reply 31 Dec 2020, 16:41 Reply Quote 0
                            CCS86
                            Cool plugin!
                            I'm trying it out on a Duet Maestro on DWC/RRF 3.2 RC2
                            Seeing some weirdness on one file. With "spread lines" enabled, everything looks good:
                            But with it disabled, some weirdness:
                            undefined 1 Reply Last reply 31 Dec 2020, 20:17 Reply Quote 0
                              @Sindarius
                              Cool πŸ™‚ - looking forward!
                              Another small thing thatΒ΄s related to it:
                              When within "settingS" choosing "volume" (instead of "bed") the wireframe is by default blue, and since 1 of the axis is also blue it might be a unlucky default colour for the wireframe of the print-volume regarding the default-csys-colouring:
                              If the default would be a slightly transparent white (I know transparency is not there yet so to show what I mean I picked a greyish tone), you could better see the the csys:
                              I know this is a field where opinions might easily differ, so it is maybe just something to think about πŸ˜‰
                              Thanks for all your work,
                              cheers!
                              undefined 1 Reply Last reply 31 Dec 2020, 20:19 Reply Quote 0
                                Sindarius @CCS86
                                @CCS86 if you could share your file that would help me to look at it.
                                undefined 1 Reply Last reply 2 Jan 2021, 20:33 Reply Quote 0
                                  @LB volume is an odd duck because I had to do some things to make something work for delta beds. Transparency is always a pain heh
                                  ? 1 Reply Last reply 2 Jan 2021, 11:21 Reply Quote 0
                                    @Sindarius
                                    reliable results with (alpha + all-of-the-webbrowsers-out-there)=oxymoron 🀣
                                      CCS86 @Sindarius
                                      @Sindarius said in 3D GCode Viewer integrated with DWC:
                                      Sure thing.
                                      Playseat Foot.gcode.txt
                                      undefined 1 Reply Last reply 2 Jan 2021, 21:19 Reply Quote 0
                                        Sindarius @CCS86
                                        @CCS86 Thanks for the file. I managed to take a look at it and the line that is tripping up the viewer is in your ending gcode trips up the viewer into thinking the last layer height should be 5mm tall which causes it to freak out.
                                        G1 Z5 E-3 F4000
                                        I commented out that line and got this
                                        This is not an issue with your gcode but an issue with how the viewer not appreciating a retract and z travel in the same line. I'll look at getting a fix in for 3.3
                                        Also because line rendering does not care about layer height doing forced line rendering showed the correct results.
                                        Either way thank you for sharing your file and I'll get this resolved.
                                        Thanks!
                                          CCS86
                                          Awesome, glad it helped!
