    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.5k
      jay_s_uk
      what software does the printer originally run?
      Blacksheep99undefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        thats the difficult part.
        is there any way you can get documentation as to what the exact model number is of the thermistor?
        • Blacksheep99undefined
          Blacksheep99 @jay_s_uk
          @jay_s_uk said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
          No idea. I was able to get it working with Cura and outputting gcode based on marlin but that's it. There was no way to access the FW etc.
            jay_s_uk
            you may have to either take a punt on the thermistors as something like 3950's or 4092's.
            Other than that you'll have to change them so you know exactly what you they are.
            I've just had a quick google and nothing has come up.
            • Vetiundefined
              Veti
              first measure the resistance at room temperature so that you can determine that it is a 100k ntc thermistor
                Blacksheep99 @Veti
                @Veti said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                Would there be anything on the part itself to provide a clue? I can go check.
                I changed the R25 number based on what I'd seen others use. On initial test of the bed heater it threw an error as heating too slowly. I ran autotune and it then would heat up to 80c without error. I've a lot to learn.....
                • Vetiundefined
                  Veti @Blacksheep99
                  @Blacksheep99 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                  the settings are specific for your thermistor model.
                    Blacksheep99 @Veti
                    @Veti to be clear, on the bed there are the power cables and then the thermistor cables right?
                      Blacksheep99 @Veti
                      Understood, thanks.
                      • Vetiundefined
                        Veti @Blacksheep99
                        that is normally the case
                        • Vetiundefined
                          Veti
                          can you post a picture of the thermistor?
                            Blacksheep99
                              Blacksheep99
                              Each heater is 120x150mm
                                dc42 administrators @Blacksheep99
                                The probe\end stop has one but shared power circuits, the servo has a single feed to one pin with shared power, the hot ends have a single pin but share power also.
                                Shared +5V or +3.3v power and ground to the Z probe and the endstops is OK, if they use the same power voltage. Sharing power with the servo is also OK if they all need +5V power.
                                Shared +VIN power to two heaters is OK as long as the cable can handle the current for two heaters.
                                  Blacksheep99 @dc42
                                  @dc42 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                                  Thanks @dc42 I'll check the above. The two heaters are using the installed cabling so I should assume that it is up to the task. I am using the same PSU etc.
                                    Blacksheep99
                                    It has been mentioned in one of my other threads but worth me double checking. With my 24v psu I will need to change the fans on the printer to 24v also? the current ones are 12v. I think it's easier to replace than buy a converter?
                                      jay_s_uk
                                      Either way to be honest.
                                      My preference is to use the correct voltage fans but other people are happy with buck converters
                                      • Vetiundefined
                                        Veti
                                        have you measured the resistance ?
                                          Blacksheep99 @Veti
                                          169.1 Kohms If i read it correctly. That is at room temp which is cool today as there's no heating on at the moment in that room.
                                          • Vetiundefined
                                            Veti @Blacksheep99
                                            modules:composer.user_said_in, @Blacksheep99, ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
                                            which is about what temperature?
