ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
My Duet controlled machine
13
139
9.0k
    Blacksheep99 @jay_s_uk
    @jay_s_uk said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
    what software does the printer originally run?
    No idea. I was able to get it working with Cura and outputting gcode based on marlin but that's it. There was no way to access the FW etc.
      jay_s_uk
      you may have to either take a punt on the thermistors as something like 3950's or 4092's.
      Other than that you'll have to change them so you know exactly what you they are.
      I've just had a quick google and nothing has come up.
        Veti
        first measure the resistance at room temperature so that you can determine that it is a 100k ntc thermistor
        undefined 1 Reply Last reply 6 Jan 2021, 11:39 Reply Quote 0
          Blacksheep99 @Veti
          @Veti said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
          thats the difficult part.
          is there any way you can get documentation as to what the exact model number is of the thermistor?
          Would there be anything on the part itself to provide a clue? I can go check.
          I changed the R25 number based on what I'd seen others use. On initial test of the bed heater it threw an error as heating too slowly. I ran autotune and it then would heat up to 80c without error. I've a lot to learn.....
          undefined 1 Reply Last reply 6 Jan 2021, 11:38 Reply Quote 0
            Veti @Blacksheep99
            @Blacksheep99 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
            the settings are specific for your thermistor model.
              Blacksheep99 @Veti
              @Veti to be clear, on the bed there are the power cables and then the thermistor cables right?
              undefined 1 Reply Last reply 6 Jan 2021, 11:40 Reply Quote 0
                Blacksheep99 @Veti
                Understood, thanks.
                  Veti @Blacksheep99
                  that is normally the case
                    Veti
                    can you post a picture of the thermistor?
                      Blacksheep99
                        Blacksheep99
                        Each heater is 120x150mm
                          dc42 administrators @Blacksheep99
                          The probe\end stop has one but shared power circuits, the servo has a single feed to one pin with shared power, the hot ends have a single pin but share power also.
                          Shared +5V or +3.3v power and ground to the Z probe and the endstops is OK, if they use the same power voltage. Sharing power with the servo is also OK if they all need +5V power.
                          Shared +VIN power to two heaters is OK as long as the cable can handle the current for two heaters.
                          undefined 1 Reply Last reply 6 Jan 2021, 12:10 Reply Quote 0
                            Blacksheep99 @dc42
                            @dc42 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                            Thanks @dc42 I'll check the above. The two heaters are using the installed cabling so I should assume that it is up to the task. I am using the same PSU etc.
                              Blacksheep99
                              It has been mentioned in one of my other threads but worth me double checking. With my 24v psu I will need to change the fans on the printer to 24v also? the current ones are 12v. I think it's easier to replace than buy a converter?
                                jay_s_uk
                                Either way to be honest.
                                My preference is to use the correct voltage fans but other people are happy with buck converters
                                undefined 1 Reply Last reply 6 Jan 2021, 13:44 Reply Quote 0
                                  Veti
                                  have you measured the resistance ?
                                  undefined 1 Reply Last reply 6 Jan 2021, 13:41 Reply Quote 0
                                    Blacksheep99 @Veti
                                    169.1 Kohms If i read it correctly. That is at room temp which is cool today as there's no heating on at the moment in that room.
                                    undefined 1 Reply Last reply 6 Jan 2021, 13:42 Reply Quote 0
                                      Veti @Blacksheep99
                                      modules:composer.user_said_in, @Blacksheep99, ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
                                      which is about what temperature?
                                      undefined 1 Reply Last reply 6 Jan 2021, 13:43 Reply Quote 0
                                        Blacksheep99 @Veti
                                        @Veti thermostat in that room says 12c
                                          I think I side with you. I'll order some fans
                                          30 out of 139
