    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.5k
    • Blacksheep99undefined
      Blacksheep99
        Blacksheep99
        Each heater is 120x150mm
          dc42 administrators @Blacksheep99
          @Blacksheep99 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
          The probe\end stop has one but shared power circuits, the servo has a single feed to one pin with shared power, the hot ends have a single pin but share power also.
          Shared +5V or +3.3v power and ground to the Z probe and the endstops is OK, if they use the same power voltage. Sharing power with the servo is also OK if they all need +5V power.
          Shared +VIN power to two heaters is OK as long as the cable can handle the current for two heaters.
          Blacksheep99undefined 1 Reply Last reply Reply Quote 0
            Blacksheep99 @dc42
            @dc42 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
            Thanks @dc42 I'll check the above. The two heaters are using the installed cabling so I should assume that it is up to the task. I am using the same PSU etc.
              Blacksheep99
              It has been mentioned in one of my other threads but worth me double checking. With my 24v psu I will need to change the fans on the printer to 24v also? the current ones are 12v. I think it's easier to replace than buy a converter?
                jay_s_uk
                Either way to be honest.
                My preference is to use the correct voltage fans but other people are happy with buck converters
                • Vetiundefined
                  Veti
                  have you measured the resistance ?
                    Blacksheep99 @Veti
                    @Veti said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                    169.1 Kohms If i read it correctly. That is at room temp which is cool today as there's no heating on at the moment in that room.
                    • Vetiundefined
                      Veti @Blacksheep99
                      modules:composer.user_said_in, @Blacksheep99, ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
                      which is about what temperature?
                        Blacksheep99 @Veti
                        @Veti thermostat in that room says 12c
                          Blacksheep99 @jay_s_uk
                          @jay_s_uk said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                          I think I side with you. I'll order some fans
                          • Vetiundefined
                            Veti
                            ok thats inline with a 100k ntc thermistor.
                            but which one is not as easy to determine.
                            can you put the thermistor at 100C using a known good temperature measuring tool?
                            i.e here is a beta 3950 resistance table.
                            https://www.keenovo.com/NTC-Thermistor-R-T-Table.pdf
                            Blacksheep99undefined 2 Replies Last reply Reply Quote 0
                              Blacksheep99 @Veti
                              I'm not sure how I'd go about that especially with what I have available at the moment. Am I daft thinking i could try suspend it in some boiling water and measure it then?
                              • Vetiundefined
                                Veti
                                can you post a picture of the thermistor in the hotend?
                                  Blacksheep99 @Veti
                                  I'll try. I've a work call now but will do it after.
                                  thanks for your help.
                                    A Former User
                                    How was the original board configured - maybe you can borrow some info from there?
                                      Blacksheep99
                                      Best I can manage at the moment. I'll have to take the shroud off etc.
                                        Blacksheep99 @A Former User
                                        @bearer said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                                        Pics.
                                          Blacksheep99
                                          This other board was below the touch screen.
                                            A Former User
                                            Ouch / RIP. No immediately obvious easy way to get anything from that, the main cpu on the motion controller had seen better days indeed.
                                            (there is what looks like a 8 pin soic flash chip, but might not be worth while extracting it if settings are in the other cpu's flash / eeprom)
