    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.5k
    • Vetiundefined
      Veti
      can you post a picture of the belt assembly?
      and you can wire the servo to the z probe connector.
      use zprobe.mod for the servo signal line. just like for a bltouch.
      • Blacksheep99undefined
        Blacksheep99
        X Axis
        Y Axis - 2 belts and then a small belt to the stepper
        Z Axis - There must be a belt under the black base. I'll have to dismantle it to check.
        servo and probe wired up. Think this is right although the servo now doesn't respond. Temp wiring...
        • Vetiundefined
          Veti
          how is the motor connected to the lead screw? post a picture of that.
          also you need to work out the pitch of the leadscrew.
          Blacksheep99undefined 1 Reply Last reply Reply Quote 0
            Blacksheep99 @Veti
            @Veti I believe its a belt as that would be logical but I willhave to take the base off the printer as it's under the base I believe. Seems I can't avoid it?
            • Vetiundefined
              Veti
              well if its 1:1 transmition then no
              so work out the pitch of the leadscrew and use this to calculate the steps
              https://blog.prusaprinters.org/calculator_3416/
                Blacksheep99 @Veti
                @Veti said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                Thanks. I would think it is. Pitch looks to be 2mm. Stepper is 1.8 degrees from the spec sheet. stepper at x16 so I think we're looking at 1600 for the Z
                  Blacksheep99 @Blacksheep99
                  @Blacksheep99 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                  I take this back. I know that the build height is 150. I've tried manual Z definition and it's come at 120. If I look at the Y axis then the teeth on the two pullys the motor one is 12 teeth. Harder to count the other but looks to be 16.
                  • Vetiundefined
                    Veti
                    12:16 ratio with 120 would give you 160. so...
                    if its a 16:20 with 120 would give you 150.
                    you ought to open it up and count
                      Blacksheep99 @Veti
                      I will. A job for tomorrow. Thanks again, I do appreciate the help.
                        Blacksheep99
                        Thanks to a lot of help I finally managed to get everything hooked up and in theory working. I just wanted to link to the separate thread I created for completeness.
                        https://forum.duet3d.com/topic/20803/servo-deployed-probe-on-duet-maestro
                        I need to tidy my wiring up, mount the board, bracket for the power cables etc.
                        The next task is getting a successful first print.
                          Blacksheep99
                          Can't thank the people who have helped me enough. Still lots of work to do in terms of getting the printer calibrated properly and playing with settings but to get to this stage I'm extremely happy.
                          It's smushing layers a little and over extruding I think. The part fan is disconnected as I need to cut the shroud that directs the air to the part so it fits around the new probe.
                            Not a bad first print on a conversion.
                            Maybe give this calibration guide a go.
                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                              Blacksheep99
                              I'm getting some decent test prints now. The calibration cube looks so much better and measures accurately.
                              I'm starting to focus on the dual nozzles and try get them working together for dual colour prints. I've measured the nozzle to nozzle as 28mm. I just wondered if there were some techniques I can use to calibrate them?
                              I'm set the printer up with centre of the bed as 0,0 and defined the centre of the tool head to align with that.
                                It'll keep things simpler if you use your tool0 nozzle as the reference point. Then the second nozzle is offset from that.
                                So if the center of your bed is 0,0, and your nozzle0 is touching that point, the offset for the second nozzle is easily found by jogging the print head to move the second nozzle so that it's now at the 0,0 center point. Now you can use the current X Y position as the offset for your second tool.
                                  Blacksheep99 @Phaedrux
                                  @Phaedrux said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                                  Thanks. That makes sense. Does it make most sense to define the tool closest to the probe as the one at 0,0?
                                    Phaedrux Moderator @Blacksheep99
                                    I don't know if that will matter really since they are all related distances anyway. My brains thinks left to right in ascending order, but it doesn't have to be like that.
                                      Your brain thinks the same way as mine.
                                        Blacksheep99
                                        I've done various bit of tuning and calibration now. I've very happy with the results I'm now getting. A testament to the Duet. So impressed that I've picked up a Duet 2 Wifi and I intend to install it in my other printer. Helped by the confidence I have gained on installing this.
                                          Blacksheep99
                                          Needed more top/bottom layers but happy with this part.
                                          First layer (0.2) and a calibration cube
                                            Another successful conversion. Well done.
