    Duet3 6CH + 3CH expansion board - Missing steps.
    153
    8.7k
    • hackinistratorundefined
      hackinistrator @evomotors
      @evomotors
      are you 100% sure that its "data loss" causing the issue ?
      it seems you set everything correctly (i'm far from being expert...) maybe the board ignores your current limit settings .
      can you try running the same gcode (or simple high accel macro) while the motors disconnected from the load (remove belts) ?
      i'm not sure its a comm speed issue . maybe the tboard simply ignores motor current settings .
      evomotorsundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
      • evomotorsundefined
        evomotors @hackinistrator
        @hackinistrator said in Duet3 6CH + 3CH expansion board - Missing steps.:
        @evomotors
        I'm not 100% sure that it's caused by data loss. If I set my motors current limits correctly it should not ignore them, unless there is a bug in the firmware.
        I prefer not to remove belts, but even if I do, what it is going to prove? How can you tell if gantry in the correct position if belts are disconnected?
        But you maybe correct, it does feels like motors ether underpowered or pulses are irregular on these fast moves. Unfortunately there is no way for me to tell, I don't have oscilloscope on hands. But it should be really easy for @dc42 to test.
        I'm still waiting for @dc42 to look at the videos and reply.
          deckingman @hackinistrator
          @hackinistrator Have you watched the videos that @evomotors posted? If the board ignores the motor current, then it does so selectively at some seemingly random time after a print starts, then restores it again immediately after.
          hackinistratorundefined 1 Reply Last reply Reply Quote 0
            evomotors
            I'm getting lonely here after proving existence of the issue. 👎
            @dc42 Do you want me to perform some additional tests?
              Thanks for your patience. He's aware and will respond ASAP.
              evomotorsundefined 1 Reply Last reply Reply Quote 0
                evomotors @Phaedrux
                @Phaedrux said in Duet3 6CH + 3CH expansion board - Missing steps.:
                Oh thanks! The good news that I'm not alone here.
                deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  deckingman @evomotors
                  @evomotors For want of anything better to say or suggest, have you tried commenting out the M593 (DAA) to see if that makes any difference? No reason for suggesting it other than it's something which modifies motion planning, which might get applied to main boards but not expansion boards. I don't know if that's even possible but testing without M593 would at least eliminate it as a potential cause. Just a thought if you've got nothing better to do while you are waiting...........
                    dc42 administrators @evomotors
                    @evomotors, I believe at least some of these issues are caused by CAN clock sync jitter, meaning that the expansion board clocks don't run perfectly in sync either the main board. When I measured it, I found that it was higher than I expected, frequently reaching 300us and sometimes more under conditions of high step rates and short move segments. Fortunately we've had a plan to reduce this jitter ever since we designed Duet 3. I've been working on this all day, and the jitter is now reduced to 13us even with heavy traffic. There is the possibility to reduce it still further.
                    I have two other related issues to investigate before we release an early 3.3 beta.
                    evomotorsundefined 1 Reply Last reply Reply Quote 1
                      hackinistrator @deckingman
                      @deckingman sure , i watched the vid.
                      i'm not sure if the issue occurs at random time.
                      if you check the vid , you can see the printer completed pretty fast accel moves without issues while moving on XY plane .
                      the issue occurred when it was making fast diagonal move - single motor running .
                      what is the default motor current on those drivers anyways ?
                      maybe its a good idea to try and reduce motor current on exp. board to very low value and see if it has any effect .
                      there are no CAN errors so i don't see how it can be comm. error .
                        T3P3Tony administrators @hackinistrator
                        @hackinistrator there is some timing jitter (as @dc42 has pointed out) that is not currently reported in 3.2.
                        @evomotors thanks for all the work in detailing the problem, we are working on it!
                          evomotors @dc42
                          @dc42 @T3P3Tony
                          Thank you for your hard work. Waiting to test the changes.
                            I am pleased to report that we have made substantial progress on this issue. In addition to fixing the CAN clock jitter, we have identified and fixed an issue that could cause whole moves to be abandoned on CAN-connected expansion boards. We have only been able to reproduce this using high step rates and short moves, however the cause of the issue (floating point rounding error) could conceivably happen at lower step rates too.
                            I expect to provide unofficial 3.3beta versions of all firmwares tomorrow.
                            Luke'sLaboratoryundefined evomotorsundefined 2 Replies Last reply Reply Quote 2
                            • Luke'sLaboratoryundefined
                              Luke'sLaboratory @dc42
                              @dc42 Holy crap! Big if true!!!!!! I can't wait to try out the firmware to see if it solves my issues!
                              Luke
                              http://lukeslab.online
                                evomotors @dc42
                                Do you need a beta tester? 🙂
                                • Vetiundefined
                                  Veti @evomotors
                                  @evomotors said in Duet3 6CH + 3CH expansion board - Missing steps.:
                                  always welcome.
                                  the firmware will be available for all here
                                  https://github.com/Duet3D/RepRapFirmware/releases
                                    evomotors
                                    @dc42 Any updates? I guess there some roadblocks with other issues.
                                      @evomotors, https://forum.duet3d.com/topic/20991/early-rrf-3-3beta-files-available
                                        evomotors @dc42
                                        @dc42 said in Duet3 6CH + 3CH expansion board - Missing steps.:
                                        Issue still exists after 3.3beta install. Visually no difference.
                                        This is after starting and canceling print:
                                        M122
                                        RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                        Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G
                                        Used output buffers: 1 of 40 (15 max)
                                        Static ram: 149772
                                        Dynamic ram: 64248 of which 104 recycled
                                        Never used RAM 140548, free system stack 126 words
                                        Tasks: Linux(ready,141) HEAT(blocked,299) CanReceiv(blocked,893) CanSender(blocked,346) CanClock(blocked,326) TMC(blocked,52) MAIN(running,613) IDLE(ready,19)
                                        Owned mutexes: HTTP(MAIN)
                                        Last reset 00:20:29 ago, cause: power up
                                        Last software reset details not available
                                        Error status: 0x00
                                        Aux0 errors 0,0,0
                                        Aux1 errors 0,0,0
                                        MCU temperature: min 23.3, current 35.4, max 35.6
                                        Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                        12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                        Driver 0: position 71266, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/243
                                        Driver 1: position 8428, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/248
                                        Driver 2: position 1039, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/269
                                        Driver 3: position 0, standstill, reads 15770, writes 24 timeouts 0, SG min/max 0/267
                                        Driver 4: position 0, standstill, reads 15783, writes 11 timeouts 0, SG min/max 0/0
                                        Driver 5: position 0, standstill, reads 15783, writes 11 timeouts 0, SG min/max 0/0
                                        Date/time: 2021-01-16 15:50:32
                                        Slowest loop: 178.46ms; fastest: 0.03ms
                                        === Storage ===
                                        Free file entries: 10
                                        DMs created 125, maxWait 700263ms, bed compensation in use: mesh, comp offset 0.000
                                        === MainDDARing ===
                                        Scheduled moves 2249, completed moves 2249, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                                        === AuxDDARing ===
                                        Heater 0 is on, I-accum = 0.4
                                        Heater 1 is on, I-accum = 0.3
                                        Segments left: 0
                                        Movement lock held by null
                                        Telnet is idle in state(s) 0
                                        File* is idle in state(s) 0
                                        USB is idle in state(s) 0
                                        Aux is idle in state(s) 0
                                        Queue* is idle in state(s) 0
                                        LCD is idle in state(s) 0
                                        SBC is idle in state(s) 0
                                        Daemon is idle in state(s) 0
                                        Aux2 is idle in state(s) 0
                                        Code queue is empty.
                                        === CAN ===
                                        Messages queued 7096, send timeouts 0, received 38, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 414, free buffers 48
                                        === SBC interface ===
                                        State: 4, failed transfers: 0
                                        Last transfer: 1ms ago
                                        RX/TX seq numbers: 44700/44700
                                        SPI underruns 0, overruns 0
                                        Number of disconnects: 0, IAP RAM available 0x2c478
                                        Buffer RX/TX: 0/0-0
                                        === Duet Control Server ===
                                        Duet Control Server v3.2.0
                                        Code buffer space: 4096
                                        Full transfers per second: 31.34
                                        Maximum length of RX/TX data transfers: 2656/1664
                                        M122 B1
                                        Diagnostics for board 1:
                                        Duet EXP3HC firmware version 3.3beta (2021-01-16 08:18:18)
                                        Bootloader ID: not available
                                        Never used RAM 154492, free system stack 166 words
                                        HEAT 92 CanAsync 92 CanRecv 86 TMC 30 MAIN 306 AIN 259
                                        Last reset 00:21:14 ago, cause: power up
                                        Last software reset data not available
                                        Driver 0: position -343134, 160.0 steps/mm,  standstill, reads 45658, writes 24 timeouts 0, SG min/max 0/218, steps req 1681012 done 1337262
                                        Driver 1: position -74772, 160.0 steps/mm,  standstill, reads 45661, writes 24 timeouts 0, SG min/max 0/349, steps req 1442638 done 1203360
                                        Driver 2: position 5964, 172.0 steps/mm,  standstill, reads 45669, writes 20 timeouts 0, SG min/max 0/198, steps req 32691 done 32719
                                        Moves scheduled 2198, completed 2198, in progress 0, hiccups 185, step errors 0
                                        Peak sync jitter 14, peak Rx sync delay 183, resyncs 0, no step interrupt scheduled
                                        VIN: 24.7V, V12: 12.3V
                                        MCU temperature: min 43.8C, current 44.0C, max 44.2C
                                        Ticks since heat task active 246, ADC conversions started 1274238, completed 1274236, timed out 0
                                        Last sensors broadcast 0x00000000 found 0 0 ticks ago, loop time 0
                                        CAN messages queued 58, send timeouts 0, received 13653, lost 0, free buffers 36, error reg 11004e
                                        And this is after just after boot before printing:
                                        m122 B1
                                        Never used RAM 154420, free system stack 200 words
                                        HEAT 79 CanAsync 92 CanRecv 86 TMC 64 MAIN 298 AIN 259
                                        Last reset 00:00:49 ago, cause: software
                                        Driver 0: position 0, 160.0 steps/mm,  standstill, reads 49081, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0
                                        Driver 1: position 0, 160.0 steps/mm,  standstill, reads 49083, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0
                                        Driver 2: position 0, 172.0 steps/mm,  standstill, reads 49087, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0
                                        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0
                                        Peak sync jitter 11, peak Rx sync delay 181, resyncs 1, no step interrupt scheduled
                                        MCU temperature: min 43.8C, current 43.8C, max 44.0C
                                        Ticks since heat task active 236, ADC conversions started 49228, completed 49226, timed out 0
                                        Last sensors broadcast 0x00000000 found 0 240 ticks ago, loop time 0
                                        CAN messages queued 60, send timeouts 3, received 403, lost 0, free buffers 36, error reg 11004f
                                          Thanks, from the M122 B1 report there's evidently still an issue with steps being lost on the 3HC.
                                          Have you already posted your config.g and the GCode file somewhere?
                                            evomotors @dc42
                                            Yes, it is the same configuration and stl file as posted above in this thread
                                            https://forum.duet3d.com/topic/20713/duet3-6ch-3ch-expansion-board-missing-steps/79?_=1610818681447
                                            The config is where XY connected to expansion board
