    stepper precision
    3D Printing General Chat
    6.4k
    • arhiundefined
      arhi
      idea came from here: https://forum.duet3d.com/topic/20582/stepper-precision-5
      I borrowed some 16bit encoder from a client to do a test, long story short @mendenmh suggested a solution with python library and it worked to talk to the encoder
      encoder and motor are attached with painters tape enforced with zip ties
      rpi (pin12 step, pin13 direction) with a hat that has 74hct14 to up the signals to 5V and tmc2208 on header (default factory config with ms0 and ms1 connected to 5v)
      • arhiundefined
        arhi
        GSD file (modified as full GSD is not supported by the library)
        #Profibus_DP
        GSD_Revision = 3
        Vendor_Name           = "Kuebler GmbH"
        Model_Name            = "Sendix Singleturn Encoder 58X8 "
        Revision              = "1.2"
        Ident_Number          = 0x5868
        OrderNumber           = "8.58X8.XX3X.3102"
        Protocol_Ident        = 0
        Station_Type          = 0
        ;FMS_supp              = 0
        Hardware_Release      = "1.0"
        Software_Release      = "2.2"
        ;DP_Encoder_profile_version                 = "1.1"
        ;DP_Encoder_class                           = 2
        ;DP_Encoder_manufacturer_specific_functions = 1
        9.6_supp              = 1
        19.2_supp             = 1
        45.45_supp            = 1
        93.75_supp            = 1
        187.5_supp            = 1
        500_supp              = 1
        1.5M_supp             = 1
        3M_supp               = 1
        6M_supp               = 1
        12M_supp              = 1
        MaxTsdr_9.6           = 15
        MaxTsdr_19.2          = 15
        MaxTsdr_45.45         = 15
        MaxTsdr_93.75         = 15
        MaxTsdr_187.5         = 15
        MaxTsdr_500           = 15
        MaxTsdr_1.5M          = 25
        MaxTsdr_3M            = 50
        MaxTsdr_6M            = 100
        MaxTsdr_12M           = 200
        Redundancy            = 0
        Repeater_Ctrl_Sig     = 0
        24V_Pins              = 0
        Implementation_Type   = "SPC3"
        Bitmap_Device         = "5868_PB"
        ;Bitmap_Diag           = "5868_PBD"
        ; *** Slave-Specification ***
        Slave_Family          = 7
        Freeze_Mode_supp      = 1
        Sync_Mode_supp        = 1
        Auto_Baud_supp        = 1
        ;Set_Slave_Add_Supp    = 1
        Min_Slave_Intervall   = 1
        Modular_Station       = 1
        Max_Module            = 2
        Modul_Offset          = 1
        Max_Input_Len         = 8
        Max_Output_Len        = 4
        Max_Data_Len          = 12
        Max_User_Prm_Data_Len = 10
        Max_Diag_Data_Len     = 57
        ; *** Parameter Texts ***
        PrmText = 1
        Text(0) = "Increasing clockwise (0)"
        Text(1) = "Increasing counter clockwise (1)"
        EndPrmText
        PrmText = 2
        Text(0) = "Disabled"
        Text(1) = "Enabled"
        EndPrmText
        PrmText = 3
        Text(0) = "Standard (MUR + TMR)"
        Text(1) = "Alternative (NDR + TMR)"
        EndPrmText
        ; *** Parameters ***
        ExtUserPrmData = 1 "Code sequence"
        ;Bit(0) 0 0-1
        Prm_Text_Ref = 1
        EndExtUserPrmData
        ExtUserPrmData = 2 "Class 2 functionality"
        ;Bit(1) 1 0-1
        Prm_Text_Ref = 2
        EndExtUserPrmData
        ExtUserPrmData = 3 "Scaling function control"
        ;Bit(3) 1 0-1
        Prm_Text_Ref = 2
        EndExtUserPrmData
        ExtUserPrmData = 4 "Scaling type"
        ;Bit(7) 0 0-1
        Prm_Text_Ref = 3
        EndExtUserPrmData
        ExtUserPrmData = 5 "MUR(Standard) / NDR(Alternative)"
        ;Unsigned32 65536 1-65536
        EndExtUserPrmData
        ExtUserPrmData = 6 "TMR"
        ;Unsigned32 268435456 1-268435456
        EndExtUserPrmData
        ; *** Module Definition List ***
        Module = "32 Bit Input/Output, consistent"   0xF1
        Ext_Module_Prm_Data_Len = 10
        Ext_User_Prm_Data_Const(0) = 0x00,0x0A,0x00,0x01,0x00,0x00,0x10,0x00,0x00,0x00
        Ext_User_Prm_Data_Ref(1) = 1 ; Code sequence
        Ext_User_Prm_Data_Ref(1) = 2 ; Class 2 functionality
        Ext_User_Prm_Data_Ref(1) = 3 ; Scaling function control
        Ext_User_Prm_Data_Ref(1) = 4 ; Scaling type
        Ext_User_Prm_Data_Ref(2) = 5 ; MUR (Standard) / NDR (Alternative)
        Ext_User_Prm_Data_Ref(6) = 6 ; TMR
        EndModule
        Module = "32 Bit Input, consistent"          0xD1
        EndModule
        Module = "16 Bit Input/Output, consistent"    0xF0
        EndModule
        Module = "16 Bit Input, consistent"           0xD0
        EndModule
        Module = "MUR=13 Bit Singleturn"             0xF1
        Ext_User_Prm_Data_Const(0) = 0x00,0x0A,0x00,0x00,0x20,0x00,0x00,0x00,0x20,0x00
        EndModule
        Module = "MUR=16 Bit Singleturn"             0xF1
        Ext_User_Prm_Data_Const(0) = 0x00,0x0A,0x00,0x01,0x00,0x00,0x00,0x01,0x00,0x00
        EndModule
        Module = "Speed (RPM) = 16 Bit Input"         0xD0
        EndModule
        Module = "Speed (Steps/sec) = 32 Bit Input"   0xD1
        EndModule
        • arhiundefined
          arhi
          config file
          arhi_readencoder.conf
          [PROFIBUS]
          debug=0
          [PHY]
          type=serial
          dev=/dev/ttyUSB0
          rtscts=False
          dsrdtr=False
          baud=19200
          [FDL]
          [DP]
          master_class=2
          master_addr=125
          [SLAVE_0]
          name=encoder
          addr=63
          gsd=encoder.gsd
          sync_mode=0
          freeze_mode=0
          group_mask=1
          watchdog_ms=0
          ;module_0=MUR=13 Bit Singleturn
          module_0=MUR=16 Bit Singleturn
          output_size=4
          input_size=8
          • arhiundefined
            arhi
            main code
            #!/usr/bin/env python3
            import pyprofibus
            import time
            import RPi.GPIO as GPIO
            def main(watchdog=None):
                    master = None
                    try:
                            config = pyprofibus.PbConf.fromFile("arhi_readencoder.conf")
                            master = config.makeDPM()
                            outData = {}
                            for slaveConf in config.slaveConfs:
                                    slaveDesc = slaveConf.makeDpSlaveDesc()
                                    master.addSlave(slaveDesc)
                                    outData[slaveDesc.slaveAddr] = bytearray((0x00, ))
                            master.initialize()
                            GPIO.setmode(GPIO.BCM)
                            GPIO.setup(12, GPIO.OUT)
                            GPIO.setup(13, GPIO.OUT)
                            GPIO.output(12, GPIO.LOW)
                            GPIO.output(13, GPIO.LOW)
                            roundandroundwego = False
                            firstread = True
                            startvalue = 0
                            totalsteps = 0
                            while not roundandroundwego:
                                    done = False
                                    counter = 0
                                    average = 0
                                    while not done:
                                            outData[slaveDesc.slaveAddr] = bytearray((0x00,0x00,0x00,0x00, ))
                                            for slaveDesc in master.getSlaveList():
                                                    slaveDesc.setOutData(outData[slaveDesc.slaveAddr])
                                            handledSlaveDesc = master.run()
                                            if handledSlaveDesc:
                                                    inData = handledSlaveDesc.getInData()
                                                    if inData is not None:
                                                            print(inData[3] + inData[2]*256)
                                                            average = average + inData[3] + inData[2]*256
                                                            counter = counter + 1
                                                            if (counter > 9):
        done = True
        average = average / 10
                                            if watchdog is not None:
                                                    watchdog()
                                    print("AVERAGE: ", totalsteps, ", ", average,  flush=True)
                                    # did we make full circle
                                    if firstread:
                                            startvalue = average
                                            firstread = False
                                    else:
                                            if abs(startvalue - average) < 20:
                                                    roundandroundwego = True
                                    # now do a step
                                    GPIO.output(12, GPIO.HIGH)
                                    time.sleep(0.0001)
                                    time.sleep(1)
                                    totalsteps = totalsteps + 1
                                    if totalsteps > 400*32:
                            totalsteps = totalsteps - 1
                            print("Total steps: ", totalsteps);
                    except pyprofibus.ProfibusError as e:
                            print("Terminating: %s" % str(e))
                            return 1
                    finally:
                            GPIO.cleanup()
                            if master:
                                    master.destroy()
                    return 0
            if __name__ == "__main__":
                    import sys
                    sys.exit(main())
            • arhiundefined
              arhi
              first test with e3d's "Super Whopper Motor" MOTECH MT-1705HS200AE
              if you look at the code after the step there is delay(1), 1 second delay, I initially started with delay(0.1) so 100ms delay and I seen ton of vibrations ?!?!? even with microstepping, very slow movement, I see vibrations. If you look at the code, I read encoder 10 times, I read it very slow (19200bps), and I see vibrations after 100ms of delay after step before reading?!?!?!?
              example:
              58593
              58592
              58592
              58592
              58592
              58591
              58591
              58591
              58591
              58591
              AVERAGE:  1 ,  58591.6
              58576
              58575
              58575
              58575
              58574
              58574
              58574
              58574
              58574
              58574
              AVERAGE:  2 ,  58574.5
              58557
              58556
              58555
              58555
              58555
              58554
              58554
              58554
              58554
              58554
              AVERAGE:  3 ,  58554.8
              58537
              58537
              58536
              58536
              58535
              58535
              58535
              58535
              58535
              58535
              AVERAGE:  4 ,  58535.6
              It's not "that terrible" but cmon, 100ms delay, ZERO LOAD, vibrations... not expected....
              When I up the delay to 1sec the motor "calms down" and there are no vibrations, example:
              23335
              23335
              23335
              23335
              23335
              23335
              23335
              23335
              23335
              23335
              AVERAGE:  1 ,  23335.0
              23312
              23312
              23312
              23312
              23312
              23312
              23312
              23312
              23312
              23312
              AVERAGE:  2 ,  23312.0
              23287
              23287
              23287
              23287
              23287
              23287
              23287
              23287
              23287
              23287
              AVERAGE:  3 ,  23287.0
              23264
              23264
              23264
              23264
              23264
              23264
              23264
              23264
              23264
              23264
              AVERAGE:  4 ,  23264.0
              • arhiundefined
                arhi
                few raw files attached (zip still not allowed ?!?!?!)
                2208-SuperWhopper-1000ms-singleturn-run2.txt
                2208-SuperWhopper-1000ms-singleturn-run1.txt
                2208-SuperWhopper-100ms-multiturn.zip.renametozip.pdf
                • alankilianundefined
                  alankilian
                  In my experience doing this kind of thing, you need to use a bellows coupling between the motor and encoder to get reading that will be useful for your purpose.
                  Painters tape and zip ties will introduce all kinds of strange angle changes between those two mechanical parts that do not represent the actual position of the stepper motor shaft.
                  • arhiundefined
                    arhi @alankilian
                    @alankilian said in stepper precision:
                    bellows coupling
                    I ordered new couplings but not sure if they would arrive before I need to return the encoder. bellows coupling actually ring more than painters tape, painters tape is very stiff, it behaves for this type of testing (no load!! only the very low inertia of the encoder) perfect. For e.g. I'm not able to move a shaft without encoder catching and a very fast stop (pliers) and no ringing on the encoder... anyhow running multiple turns you see it's pretty repeatable even tape
                      alankilian
                      Try gathering data for one-turn slowly clockwise and one turn slowly counterclockwise.
                      If the data is within your error expectations, you have a good system.
                      I predict (and I may well be wrong) when you compare those two datasets you will see great variation from one to another and that tells you that your measurements are as accurate as the difference between those to readings.
                      Another test is to move 180-degrees, take a reading, move 180-degrees the other direction, take a reading and do that back-and-forth movement/reading for many samples.
                      When you compare multiple reading at the same step location, you will see variation. This also is a measurement of the variation in your measuring setup.
                      • arhiundefined
                        arhi @alankilian
                        already done 🙂 the data is spot on, +-0.0 🙂 comparing directions
                          alankilian
                          What's the angular resolution if your encoder?
                          • arhiundefined
                            arhi @alankilian
                            @alankilian 360/65535 degrees
                              alankilian
                              Well, all I can say is you are getting results that do not match with my experience in such situations.
                              Being able to rotate 180-degrees and repeatable read within 0.005-degree is some kind of black magic indeed. You are a master.
                              • arhiundefined
                                arhi @alankilian
                                😄 we'll see how it goes on the "bigger sample" I just let it go 400 steps forwards and 400 steps backwards and store all the data and spit out differences... would be much easier if I knew python (darn thing don't even have proper arrays) ... as for 180degrees back forth that one I did not test ... I just let it run 3200 steps forward and 3200 steps backwards and compared two greps ... let's see how the aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa sh%$#%^# forgot to pipe it into file 😞 .. need to run it again ... brb
                                mendenmhundefined 1 Reply Last reply Reply Quote 0
                                • mendenmhundefined
                                  mendenmh @arhi
                                  @arhi As to your comment about array in python: the numpy package is the default scientific array package. It is a lot like matlab. It is extraordinarily powerful. The python 'array' class, and python's own lists and tuples, are for entirely different purposes than handling what you want.
                                  • arhiundefined
                                    arhi @mendenmh
                                    @mendenmh I don't plan to learn python and it's libraries today (I hope never), dunno why it was invented and how the hack it gained popularity but... I'll make it work somehow to get this done.... anyone want to send some code for me to run I'll be happy to 😄 .. my example that's attached is enough for anyone to know how to read the data from encoder and move the motor, so I'll run the code provided and report back results 😄 if anyone is interested ...
                                    attm waiting for this to finish:
                                    import pyprofibus
                                    import time
                                            master = None
                                            forwarddata = []
                                            backwardsdata = []
                                            #poserem se na jezik
                                            for i in range(410):
                                                    forwarddata.append(0);
                                                    backwardsdata.append(0);
                                            try:
                                                    outData = {}
                                                    master.initialize()
                                                    totalsteps = 0
                                                    for i in range(400):
                                                            done = False
                                                            counter = 0
                                                            average = 0
                                                            while not done:
        if (counter > 9):
        done = True
        watchdog()
                                                            forwarddata[totalsteps] = average;
                                                            # now do a step
                                                            time.sleep(0.0001)
                                                            time.sleep(1)
                                                    GPIO.output(13, GPIO.HIGH)
                                                            done = False
                                                            counter = 0
                                                            average = 0
                                                            while not done:
        if (counter > 9):
        done = True
        watchdog()
                                                            backwardsdata[totalsteps] = average;
                                                            # now do a step
                                                            time.sleep(0.0001)
                                                            time.sleep(1)
                                                    for i in range( len(backwardsdata) ):
                                                            print(i, forwarddata[i], backwardsdata[i], forwarddata[i] - backwardsdata[i])
                                                    return 1
                                            finally:
                                                    GPIO.cleanup()
                                                    if master:
                                                            master.destroy()
                                            return 0
                                            import sys
                                            sys.exit(main())
                                      alankilian
                                      I'm having a little trouble analyzing your data.
                                      It looks like you are taking 3201 samples every revolution when I look at the .zip file you uploaded.
                                      I didn't take a look at the Python code since I'm also not a Python expert.
                                      Take a look at when your encoder flips over to it's minimum count and see that there seem to be ( to my eyes) 3201 samples between them.
                                      That makes it a little difficult to analyze.
                                      I'll take a look at your next data set after you upload it.
                                      arhiundefined 2 Replies Last reply Reply Quote 0
                                      • arhiundefined
                                        arhi @alankilian
                                        @alankilian going forward then backward and recording all steps was awesome suggestion ... data is ugly 😞
                                        Untitled 1.ods
                                        • arhiundefined
                                          arhi @alankilian
                                          @alankilian
                                          the "multiturn" file is stepping for a while (whole night) going forward. encoder goes up to 65535 and then to 0 (it is absolute encoder) so it allow multiturn but records only positions inside one revolution
                                          the "single turn" have 2 reasons to figure out it's full turn, one is to read the "similar" (20 less difference) position from the first one it reads when it start, and second reason is if it makes 400*32 steps (I assume 1/32 microstepping .9 degree motor ) .. first run it made 3199 steps in second 3200 steps. Motor is 1.8 degree and microstepping is 1/16 so 3200 steps is ok.
                                          Now, you see "more" data, that's cause I do: Step, read encoder 10 times (output all 10), calc average of those 10 and display average value (add them all together and divide by 10). So for every step there is 11 rows in the txt file...
                                          • arhiundefined
                                            arhi
                                            error goes from 60 to 80 or 0.33° to 0.44°
                                            the span is 400 microsteps or 25 full steps so I'm assuming the full step positions are where the error is .33° and between steps the error goes up to .44°. I expected to see 50 peaks and not 25 as I expected that "half step" is nearly as precise as full step (as number of ppl and documents online state)
