    stepper precision
    3D Printing General Chat
    6.4k
    • arhiundefined
      arhi
      config file
      arhi_readencoder.conf
      [PROFIBUS]
      debug=0
      [PHY]
      type=serial
      dev=/dev/ttyUSB0
      rtscts=False
      dsrdtr=False
      baud=19200
      [FDL]
      [DP]
      master_class=2
      master_addr=125
      [SLAVE_0]
      name=encoder
      addr=63
      gsd=encoder.gsd
      sync_mode=0
      freeze_mode=0
      group_mask=1
      watchdog_ms=0
      ;module_0=MUR=13 Bit Singleturn
      module_0=MUR=16 Bit Singleturn
      output_size=4
      input_size=8
      • arhiundefined
        arhi
        main code
        #!/usr/bin/env python3
        import pyprofibus
        import time
        import RPi.GPIO as GPIO
        def main(watchdog=None):
                master = None
                try:
                        config = pyprofibus.PbConf.fromFile("arhi_readencoder.conf")
                        master = config.makeDPM()
                        outData = {}
                        for slaveConf in config.slaveConfs:
                                slaveDesc = slaveConf.makeDpSlaveDesc()
                                master.addSlave(slaveDesc)
                                outData[slaveDesc.slaveAddr] = bytearray((0x00, ))
                        master.initialize()
                        GPIO.setmode(GPIO.BCM)
                        GPIO.setup(12, GPIO.OUT)
                        GPIO.setup(13, GPIO.OUT)
                        GPIO.output(12, GPIO.LOW)
                        GPIO.output(13, GPIO.LOW)
                        roundandroundwego = False
                        firstread = True
                        startvalue = 0
                        totalsteps = 0
                        while not roundandroundwego:
                                done = False
                                counter = 0
                                average = 0
                                while not done:
                                        outData[slaveDesc.slaveAddr] = bytearray((0x00,0x00,0x00,0x00, ))
                                        for slaveDesc in master.getSlaveList():
                                                slaveDesc.setOutData(outData[slaveDesc.slaveAddr])
                                        handledSlaveDesc = master.run()
                                        if handledSlaveDesc:
                                                inData = handledSlaveDesc.getInData()
                                                if inData is not None:
                                                        print(inData[3] + inData[2]*256)
                                                        average = average + inData[3] + inData[2]*256
                                                        counter = counter + 1
                                                        if (counter > 9):
        done = True
        average = average / 10
                                        if watchdog is not None:
                                                watchdog()
                                print("AVERAGE: ", totalsteps, ", ", average,  flush=True)
                                # did we make full circle
                                if firstread:
                                        startvalue = average
                                        firstread = False
                                else:
                                        if abs(startvalue - average) < 20:
                                                roundandroundwego = True
                                # now do a step
                                GPIO.output(12, GPIO.HIGH)
                                time.sleep(0.0001)
                                time.sleep(1)
                                totalsteps = totalsteps + 1
                                if totalsteps > 400*32:
                        totalsteps = totalsteps - 1
                        print("Total steps: ", totalsteps);
                except pyprofibus.ProfibusError as e:
                        print("Terminating: %s" % str(e))
                        return 1
                finally:
                        GPIO.cleanup()
                        if master:
                                master.destroy()
                return 0
        if __name__ == "__main__":
                import sys
                sys.exit(main())
        • arhiundefined
          arhi
          first test with e3d's "Super Whopper Motor" MOTECH MT-1705HS200AE
          if you look at the code after the step there is delay(1), 1 second delay, I initially started with delay(0.1) so 100ms delay and I seen ton of vibrations ?!?!? even with microstepping, very slow movement, I see vibrations. If you look at the code, I read encoder 10 times, I read it very slow (19200bps), and I see vibrations after 100ms of delay after step before reading?!?!?!?
          example:
          58593
          58592
          58592
          58592
          58592
          58591
          58591
          58591
          58591
          58591
          AVERAGE:  1 ,  58591.6
          58576
          58575
          58575
          58575
          58574
          58574
          58574
          58574
          58574
          58574
          AVERAGE:  2 ,  58574.5
          58557
          58556
          58555
          58555
          58555
          58554
          58554
          58554
          58554
          58554
          AVERAGE:  3 ,  58554.8
          58537
          58537
          58536
          58536
          58535
          58535
          58535
          58535
          58535
          58535
          AVERAGE:  4 ,  58535.6
          It's not "that terrible" but cmon, 100ms delay, ZERO LOAD, vibrations... not expected....
          When I up the delay to 1sec the motor "calms down" and there are no vibrations, example:
          23335
          23335
          23335
          23335
          23335
          23335
          23335
          23335
          23335
          23335
          AVERAGE:  1 ,  23335.0
          23312
          23312
          23312
          23312
          23312
          23312
          23312
          23312
          23312
          23312
          AVERAGE:  2 ,  23312.0
          23287
          23287
          23287
          23287
          23287
          23287
          23287
          23287
          23287
          23287
          AVERAGE:  3 ,  23287.0
          23264
          23264
          23264
          23264
          23264
          23264
          23264
          23264
          23264
          23264
          AVERAGE:  4 ,  23264.0
          • arhiundefined
            arhi
            few raw files attached (zip still not allowed ?!?!?!)
            2208-SuperWhopper-1000ms-singleturn-run2.txt
            2208-SuperWhopper-1000ms-singleturn-run1.txt
            2208-SuperWhopper-100ms-multiturn.zip.renametozip.pdf
            • alankilianundefined
              alankilian
              In my experience doing this kind of thing, you need to use a bellows coupling between the motor and encoder to get reading that will be useful for your purpose.
              Painters tape and zip ties will introduce all kinds of strange angle changes between those two mechanical parts that do not represent the actual position of the stepper motor shaft.
              • arhiundefined
                arhi @alankilian
                @alankilian said in stepper precision:
                bellows coupling
                I ordered new couplings but not sure if they would arrive before I need to return the encoder. bellows coupling actually ring more than painters tape, painters tape is very stiff, it behaves for this type of testing (no load!! only the very low inertia of the encoder) perfect. For e.g. I'm not able to move a shaft without encoder catching and a very fast stop (pliers) and no ringing on the encoder... anyhow running multiple turns you see it's pretty repeatable even tape
                  alankilian
                  Try gathering data for one-turn slowly clockwise and one turn slowly counterclockwise.
                  If the data is within your error expectations, you have a good system.
                  I predict (and I may well be wrong) when you compare those two datasets you will see great variation from one to another and that tells you that your measurements are as accurate as the difference between those to readings.
                  Another test is to move 180-degrees, take a reading, move 180-degrees the other direction, take a reading and do that back-and-forth movement/reading for many samples.
                  When you compare multiple reading at the same step location, you will see variation. This also is a measurement of the variation in your measuring setup.
                  • arhiundefined
                    arhi @alankilian
                    already done 🙂 the data is spot on, +-0.0 🙂 comparing directions
                      alankilian
                      What's the angular resolution if your encoder?
                      • arhiundefined
                        arhi @alankilian
                        @alankilian 360/65535 degrees
                          alankilian
                          Well, all I can say is you are getting results that do not match with my experience in such situations.
                          Being able to rotate 180-degrees and repeatable read within 0.005-degree is some kind of black magic indeed. You are a master.
                          • arhiundefined
                            arhi @alankilian
                            😄 we'll see how it goes on the "bigger sample" I just let it go 400 steps forwards and 400 steps backwards and store all the data and spit out differences... would be much easier if I knew python (darn thing don't even have proper arrays) ... as for 180degrees back forth that one I did not test ... I just let it run 3200 steps forward and 3200 steps backwards and compared two greps ... let's see how the aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa sh%$#%^# forgot to pipe it into file 😞 .. need to run it again ... brb
                            mendenmhundefined 1 Reply Last reply Reply Quote 0
                            • mendenmhundefined
                              mendenmh @arhi
                              @arhi As to your comment about array in python: the numpy package is the default scientific array package. It is a lot like matlab. It is extraordinarily powerful. The python 'array' class, and python's own lists and tuples, are for entirely different purposes than handling what you want.
                              • arhiundefined
                                arhi @mendenmh
                                @mendenmh I don't plan to learn python and it's libraries today (I hope never), dunno why it was invented and how the hack it gained popularity but... I'll make it work somehow to get this done.... anyone want to send some code for me to run I'll be happy to 😄 .. my example that's attached is enough for anyone to know how to read the data from encoder and move the motor, so I'll run the code provided and report back results 😄 if anyone is interested ...
                                attm waiting for this to finish:
                                import pyprofibus
                                import time
                                        master = None
                                        forwarddata = []
                                        backwardsdata = []
                                        #poserem se na jezik
                                        for i in range(410):
                                                forwarddata.append(0);
                                                backwardsdata.append(0);
                                        try:
                                                outData = {}
                                                master.initialize()
                                                totalsteps = 0
                                                for i in range(400):
                                                        done = False
                                                        counter = 0
                                                        average = 0
                                                        while not done:
        if (counter > 9):
        done = True
        watchdog()
                                                        forwarddata[totalsteps] = average;
                                                        # now do a step
                                                        time.sleep(0.0001)
                                                        time.sleep(1)
                                                GPIO.output(13, GPIO.HIGH)
                                                        done = False
                                                        counter = 0
                                                        average = 0
                                                        while not done:
        if (counter > 9):
        done = True
        watchdog()
                                                        backwardsdata[totalsteps] = average;
                                                        # now do a step
                                                        time.sleep(0.0001)
                                                        time.sleep(1)
                                                for i in range( len(backwardsdata) ):
                                                        print(i, forwarddata[i], backwardsdata[i], forwarddata[i] - backwardsdata[i])
                                                return 1
                                        finally:
                                                GPIO.cleanup()
                                                if master:
                                                        master.destroy()
                                        return 0
                                        import sys
                                        sys.exit(main())
                                  alankilian
                                  I'm having a little trouble analyzing your data.
                                  It looks like you are taking 3201 samples every revolution when I look at the .zip file you uploaded.
                                  I didn't take a look at the Python code since I'm also not a Python expert.
                                  Take a look at when your encoder flips over to it's minimum count and see that there seem to be ( to my eyes) 3201 samples between them.
                                  That makes it a little difficult to analyze.
                                  I'll take a look at your next data set after you upload it.
                                  arhiundefined 2 Replies Last reply Reply Quote 0
                                  • arhiundefined
                                    arhi @alankilian
                                    @alankilian going forward then backward and recording all steps was awesome suggestion ... data is ugly 😞
                                    Untitled 1.ods
                                    • arhiundefined
                                      arhi @alankilian
                                      @alankilian
                                      the "multiturn" file is stepping for a while (whole night) going forward. encoder goes up to 65535 and then to 0 (it is absolute encoder) so it allow multiturn but records only positions inside one revolution
                                      the "single turn" have 2 reasons to figure out it's full turn, one is to read the "similar" (20 less difference) position from the first one it reads when it start, and second reason is if it makes 400*32 steps (I assume 1/32 microstepping .9 degree motor ) .. first run it made 3199 steps in second 3200 steps. Motor is 1.8 degree and microstepping is 1/16 so 3200 steps is ok.
                                      Now, you see "more" data, that's cause I do: Step, read encoder 10 times (output all 10), calc average of those 10 and display average value (add them all together and divide by 10). So for every step there is 11 rows in the txt file...
                                      • arhiundefined
                                        arhi
                                        error goes from 60 to 80 or 0.33° to 0.44°
                                        the span is 400 microsteps or 25 full steps so I'm assuming the full step positions are where the error is .33° and between steps the error goes up to .44°. I expected to see 50 peaks and not 25 as I expected that "half step" is nearly as precise as full step (as number of ppl and documents online state)
                                        • arhiundefined
                                          arhi
                                          I'll use a stiff coupler now to see if that would make a difference...
                                          • arhiundefined
                                            arhi
                                            raw data (the xls is few posts back)
                                            backforth.txt
