    stepper precision
    3D Printing General Chat
    6.4k
    • alankilianundefined
      alankilian
      I'm having a little trouble analyzing your data.
      It looks like you are taking 3201 samples every revolution when I look at the .zip file you uploaded.
      I didn't take a look at the Python code since I'm also not a Python expert.
      Take a look at when your encoder flips over to it's minimum count and see that there seem to be ( to my eyes) 3201 samples between them.
      That makes it a little difficult to analyze.
      I'll take a look at your next data set after you upload it.
      arhiundefined 2 Replies Last reply Reply Quote 0
      • arhiundefined
        arhi @alankilian
        @alankilian going forward then backward and recording all steps was awesome suggestion ... data is ugly 😞
        Untitled 1.ods
        • arhiundefined
          arhi @alankilian
          @alankilian
          the "multiturn" file is stepping for a while (whole night) going forward. encoder goes up to 65535 and then to 0 (it is absolute encoder) so it allow multiturn but records only positions inside one revolution
          the "single turn" have 2 reasons to figure out it's full turn, one is to read the "similar" (20 less difference) position from the first one it reads when it start, and second reason is if it makes 400*32 steps (I assume 1/32 microstepping .9 degree motor ) .. first run it made 3199 steps in second 3200 steps. Motor is 1.8 degree and microstepping is 1/16 so 3200 steps is ok.
          Now, you see "more" data, that's cause I do: Step, read encoder 10 times (output all 10), calc average of those 10 and display average value (add them all together and divide by 10). So for every step there is 11 rows in the txt file...
          • arhiundefined
            arhi
            error goes from 60 to 80 or 0.33° to 0.44°
            the span is 400 microsteps or 25 full steps so I'm assuming the full step positions are where the error is .33° and between steps the error goes up to .44°. I expected to see 50 peaks and not 25 as I expected that "half step" is nearly as precise as full step (as number of ppl and documents online state)
            • arhiundefined
              arhi
              I'll use a stiff coupler now to see if that would make a difference...
              • arhiundefined
                arhi
                raw data (the xls is few posts back)
                backforth.txt
                • arhiundefined
                  arhi
                  S42B - same motor, open-loop mode, here we can see, I think the half stepping too...
                  s42b-openloop-back-forth.txt
                  alankilianundefined arhiundefined 2 Replies Last reply Reply Quote 0
                    alankilian @arhi
                    @arhi Can you post your Python code for this?
                    I suspect there's an "off-by-one" somewhere and you're getting better results than you see in your graph.
                    I'm probably wrong, but if so, you might be happy.
                    • arhiundefined
                      arhi @arhi
                      This post is deleted!
                      • arhiundefined
                        arhi @alankilian
                        @alankilian said in stepper precision:
                        I hoped but it's not 😞 anyhow .. here it is:
                        #!/usr/bin/env python3
                        import pyprofibus
                        import time
                        import RPi.GPIO as GPIO
                        def main(watchdog=None):
                                master = None
                                forwarddata = []
                                backwardsdata = []
                                #poserem se na jezik
                                for i in range(410):
                                        forwarddata.append(0);
                                        backwardsdata.append(0);
                                try:
                                        config = pyprofibus.PbConf.fromFile("arhi_readencoder.conf")
                                        master = config.makeDPM()
                                        outData = {}
                                        for slaveConf in config.slaveConfs:
                                                slaveDesc = slaveConf.makeDpSlaveDesc()
                                                master.addSlave(slaveDesc)
                                                outData[slaveDesc.slaveAddr] = bytearray((0x00, ))
                                        master.initialize()
                                        GPIO.setmode(GPIO.BCM)
                                        GPIO.setup(12, GPIO.OUT)
                                        GPIO.setup(13, GPIO.OUT)
                                        GPIO.output(12, GPIO.LOW)
                                        GPIO.output(13, GPIO.LOW)
                                        totalsteps = 0
                                        for i in range(400):
                                                done = False
                                                counter = 0
                                                average = 0
                                                while not done:
                                                        outData[slaveDesc.slaveAddr] = bytearray((0x00,0x00,0x00,0x00, ))
                                                        for slaveDesc in master.getSlaveList():
        slaveDesc.setOutData(outData[slaveDesc.slaveAddr])
                                                        handledSlaveDesc = master.run()
                                                        if handledSlaveDesc:
        inData = handledSlaveDesc.getInData()
        if inData is not None:
        print(inData[3] + inData[2]*256)
        average = average + inData[3] + inData[2]*256
        counter = counter + 1
        if (counter > 9):
        done = True
        average = average / 10
                                                        if watchdog is not None:
        watchdog()
                                                print("AVERAGE: ", totalsteps, ", ", average,  flush=True)
                                                forwarddata[totalsteps] = average;
                                                # now do a step
                                                GPIO.output(12, GPIO.HIGH)
                                                time.sleep(0.0001)
                                                time.sleep(1)
                                                totalsteps = totalsteps + 1
                                        GPIO.output(13, GPIO.HIGH)
                                                done = False
                                                counter = 0
                                                average = 0
                                                while not done:
        if (counter > 9):
        done = True
        watchdog()
                                                backwardsdata[totalsteps] = average;
                                                # now do a step
                                                time.sleep(0.0001)
                                                time.sleep(1)
                                                totalsteps = totalsteps - 1
                                        for i in range( len(backwardsdata) ):
                                                print(i, forwarddata[i], backwardsdata[i], forwarddata[i] - backwardsdata[i])
                                except pyprofibus.ProfibusError as e:
                                        print("Terminating: %s" % str(e))
                                        return 1
                                finally:
                                        GPIO.cleanup()
                                        if master:
                                                master.destroy()
                                return 0
                        if __name__ == "__main__":
                                import sys
                                sys.exit(main())
                        The "off by one" is imho "not a problem" as if you look at the printout ..
                        0 20828.0 0 20828.0
                        1 20835.0 20869.0 -34.0
                        2 20840.0 20876.0 -36.0
                        398 23964.0 23972.0 -8.0
                        399 23972.0 23976.0 -4.0
                        400 0 23979.0 -23979.0
                        you see that firs read is 20828.0, 0 - so going backwards I did not read backwards at all, and last read is 0, 23979.0 so going forward I didn't read that one ...
                        also you see the "end" going forward it goes up (last dataset, for the TMC driver it's reversed)
                        23964.0
                        23972.0
                        then first read backwards (actually it was not stepped backwards yet that's position after last step forward)
                        23979.0 so larger than 23972
                        and then it goes down again
                        23976.0
                        23972.0
                        also, if you look how error is down to nothing when you just turn direction and how it rises... takes some 20+ steps in reverse for error to catch up the average values..
                        First step back the error is 0.02 degrees
                        • arhiundefined
                          arhi
                          I managed to get S42B v1.0 to work (no clue how any more), now it's running in closedloop mode too so waiting for results... interesting - I have no clue what microstepping it is running at, lcd configured 1/32 but what it is actually doing - no clue, will run the original one direction full circle after this back-forth finish
                          need to find my vallder (leadshine clone) .. dunno where I put the darn thing in this chaos
                          • arhiundefined
                            arhi
                            S42B V1.0 - in closed loop mode def does not work ok .. having ton of issues with it, was not working at all, now it moves but .. the worse part is it's not even showing that there is an error here 😞 .. other ppl also report issues with it so won't waste more time on it 😞 ..
                            s42b-closedloop-back-forth.txt
                              alankilian @arhi
                              @arhi said in stepper precision:
                              If I'm understanding you correctly, that's probably the flexibility in your tape/ziptie connection causing "backlash"
                              When I move datapoints around to fake-eliminate that backlash (if that's what it is) I get a very nice chart of error values.
                              • arhiundefined
                                arhi @alankilian
                                very possible. I tested 10 steps back/forth and was getting values 0-2 for error so assumed that's it but looks like it's not holding water... darn encoder have shaft larger than nema17 and smaller than 8mm so none of my couplers fit.. ordered some new but..
                                • arhiundefined
                                  arhi
                                  S42B, closed loop mode - changed menu to 1/16 (from 1/32) and let it calibrate again
                                  s42b-closedloop-back-forth-go2.txt
                                  • arhiundefined
                                    arhi
                                    enough for now, need to stiffen this coupling
                                    • DaBitundefined
                                      DaBit
                                      If you have it available somewhere you can use some 6mm/8mm inner diameter petrol hose. The rubber kind with a (cotton?) braid as reinforcement embedded in the rubber. Due to the reinforcement that stuff is quite stiff in rotation, due to it being rubber a hose clamp clamps it stiffly around a shaft.
                                      I stumbled over M569.1 in the G-code reference today. Is that already implemented?
                                      In case you have to return the encoder before finishing you tests: I probably have some 2500-line incremental encoders with quadrature output (10000 pulses/rev) lying around over here somewhere. I can miss one or two. If I can find them..
                                      (you may think your mancave is a mess, but I am fairly certain I win that battle)
                                      • arhiundefined
                                        arhi @DaBit
                                        @DaBit said in stepper precision:
                                        no way to get it as most shops are closed but I expect monday to arrive the aluminium 5-5 that I'll drill on one side to 6mm should work ok I'll try to put it in a lathe
                                        no idea
                                        Thanks :), the idea with 16bit was to get really precise data about microstepping, I think I'll manage to get all the testing I want before I return it
                                        uh, I doubt, not 'cause my mancave is normally total chaos but because I purchased a house in 2019 and started renovating and it features a small 50m2 guest house (with 50m2 under roof storage too) in the yard that I planned to use as my new mancave, and since the plan was to move in summer 2020 I started converting my current mancave (a 20m2 room 5m high in appartment) into storage room, so I'm now working from something one could call storage and not mancave, stuff falls on me non stop, if I move too fast stuff falls of my desk, keyboard drawer etc .. very nasty place to work, not at all "artistic chaos", more like "garbage dump" 😞 ... and due to #$%^#^% we did not move yet so .. house is still being renovated and I work berried in "garbage" 😞 .. not something I am happy with 😞
                                        • arhiundefined
                                          arhi
                                          alu coupling mounted.. repeating the measurements..
                                          • DaBitundefined
                                            DaBit
                                            Fingers crossed...
