    stepper precision
    3D Printing General Chat
    6.4k
    • alankilianundefined
      alankilian @arhi
      @arhi Can you post your Python code for this?
      I suspect there's an "off-by-one" somewhere and you're getting better results than you see in your graph.
      I'm probably wrong, but if so, you might be happy.
      • arhiundefined
        arhi @arhi
        This post is deleted!
        • arhiundefined
          arhi @alankilian
          @alankilian said in stepper precision:
          I hoped but it's not 😞 anyhow .. here it is:
          #!/usr/bin/env python3
          import pyprofibus
          import time
          import RPi.GPIO as GPIO
          def main(watchdog=None):
                  master = None
                  forwarddata = []
                  backwardsdata = []
                  #poserem se na jezik
                  for i in range(410):
                          forwarddata.append(0);
                          backwardsdata.append(0);
                  try:
                          config = pyprofibus.PbConf.fromFile("arhi_readencoder.conf")
                          master = config.makeDPM()
                          outData = {}
                          for slaveConf in config.slaveConfs:
                                  slaveDesc = slaveConf.makeDpSlaveDesc()
                                  master.addSlave(slaveDesc)
                                  outData[slaveDesc.slaveAddr] = bytearray((0x00, ))
                          master.initialize()
                          GPIO.setmode(GPIO.BCM)
                          GPIO.setup(12, GPIO.OUT)
                          GPIO.setup(13, GPIO.OUT)
                          GPIO.output(12, GPIO.LOW)
                          GPIO.output(13, GPIO.LOW)
                          totalsteps = 0
                          for i in range(400):
                                  done = False
                                  counter = 0
                                  average = 0
                                  while not done:
                                          outData[slaveDesc.slaveAddr] = bytearray((0x00,0x00,0x00,0x00, ))
                                          for slaveDesc in master.getSlaveList():
                                                  slaveDesc.setOutData(outData[slaveDesc.slaveAddr])
                                          handledSlaveDesc = master.run()
                                          if handledSlaveDesc:
                                                  inData = handledSlaveDesc.getInData()
                                                  if inData is not None:
                                                          print(inData[3] + inData[2]*256)
                                                          average = average + inData[3] + inData[2]*256
                                                          counter = counter + 1
                                                          if (counter > 9):
        done = True
        average = average / 10
                                          if watchdog is not None:
                                                  watchdog()
                                  print("AVERAGE: ", totalsteps, ", ", average,  flush=True)
                                  forwarddata[totalsteps] = average;
                                  # now do a step
                                  GPIO.output(12, GPIO.HIGH)
                                  time.sleep(0.0001)
                                  time.sleep(1)
                                  totalsteps = totalsteps + 1
                          GPIO.output(13, GPIO.HIGH)
                                  done = False
                                  counter = 0
                                  average = 0
                                  while not done:
                                                          if (counter > 9):
        done = True
                                                  watchdog()
                                  backwardsdata[totalsteps] = average;
                                  # now do a step
                                  time.sleep(0.0001)
                                  time.sleep(1)
                                  totalsteps = totalsteps - 1
                          for i in range( len(backwardsdata) ):
                                  print(i, forwarddata[i], backwardsdata[i], forwarddata[i] - backwardsdata[i])
                  except pyprofibus.ProfibusError as e:
                          print("Terminating: %s" % str(e))
                          return 1
                  finally:
                          GPIO.cleanup()
                          if master:
                                  master.destroy()
                  return 0
          if __name__ == "__main__":
                  import sys
                  sys.exit(main())
          The "off by one" is imho "not a problem" as if you look at the printout ..
          0 20828.0 0 20828.0
          1 20835.0 20869.0 -34.0
          2 20840.0 20876.0 -36.0
          398 23964.0 23972.0 -8.0
          399 23972.0 23976.0 -4.0
          400 0 23979.0 -23979.0
          you see that firs read is 20828.0, 0 - so going backwards I did not read backwards at all, and last read is 0, 23979.0 so going forward I didn't read that one ...
          also you see the "end" going forward it goes up (last dataset, for the TMC driver it's reversed)
          23964.0
          23972.0
          then first read backwards (actually it was not stepped backwards yet that's position after last step forward)
          23979.0 so larger than 23972
          and then it goes down again
          23976.0
          23972.0
          also, if you look how error is down to nothing when you just turn direction and how it rises... takes some 20+ steps in reverse for error to catch up the average values..
          First step back the error is 0.02 degrees
          • arhiundefined
            arhi
            I managed to get S42B v1.0 to work (no clue how any more), now it's running in closedloop mode too so waiting for results... interesting - I have no clue what microstepping it is running at, lcd configured 1/32 but what it is actually doing - no clue, will run the original one direction full circle after this back-forth finish
            need to find my vallder (leadshine clone) .. dunno where I put the darn thing in this chaos
            • arhiundefined
              arhi
              S42B V1.0 - in closed loop mode def does not work ok .. having ton of issues with it, was not working at all, now it moves but .. the worse part is it's not even showing that there is an error here 😞 .. other ppl also report issues with it so won't waste more time on it 😞 ..
              s42b-closedloop-back-forth.txt
                alankilian @arhi
                @arhi said in stepper precision:
                If I'm understanding you correctly, that's probably the flexibility in your tape/ziptie connection causing "backlash"
                When I move datapoints around to fake-eliminate that backlash (if that's what it is) I get a very nice chart of error values.
                • arhiundefined
                  arhi @alankilian
                  very possible. I tested 10 steps back/forth and was getting values 0-2 for error so assumed that's it but looks like it's not holding water... darn encoder have shaft larger than nema17 and smaller than 8mm so none of my couplers fit.. ordered some new but..
                  • arhiundefined
                    arhi
                    S42B, closed loop mode - changed menu to 1/16 (from 1/32) and let it calibrate again
                    s42b-closedloop-back-forth-go2.txt
                    • arhiundefined
                      arhi
                      enough for now, need to stiffen this coupling
                      • DaBitundefined
                        DaBit
                        If you have it available somewhere you can use some 6mm/8mm inner diameter petrol hose. The rubber kind with a (cotton?) braid as reinforcement embedded in the rubber. Due to the reinforcement that stuff is quite stiff in rotation, due to it being rubber a hose clamp clamps it stiffly around a shaft.
                        I stumbled over M569.1 in the G-code reference today. Is that already implemented?
                        In case you have to return the encoder before finishing you tests: I probably have some 2500-line incremental encoders with quadrature output (10000 pulses/rev) lying around over here somewhere. I can miss one or two. If I can find them..
                        (you may think your mancave is a mess, but I am fairly certain I win that battle)
                        • arhiundefined
                          arhi @DaBit
                          @DaBit said in stepper precision:
                          no way to get it as most shops are closed but I expect monday to arrive the aluminium 5-5 that I'll drill on one side to 6mm should work ok I'll try to put it in a lathe
                          no idea
                          Thanks :), the idea with 16bit was to get really precise data about microstepping, I think I'll manage to get all the testing I want before I return it
                          uh, I doubt, not 'cause my mancave is normally total chaos but because I purchased a house in 2019 and started renovating and it features a small 50m2 guest house (with 50m2 under roof storage too) in the yard that I planned to use as my new mancave, and since the plan was to move in summer 2020 I started converting my current mancave (a 20m2 room 5m high in appartment) into storage room, so I'm now working from something one could call storage and not mancave, stuff falls on me non stop, if I move too fast stuff falls of my desk, keyboard drawer etc .. very nasty place to work, not at all "artistic chaos", more like "garbage dump" 😞 ... and due to #$%^#^% we did not move yet so .. house is still being renovated and I work berried in "garbage" 😞 .. not something I am happy with 😞
                          • arhiundefined
                            arhi
                            alu coupling mounted.. repeating the measurements..
                            • DaBitundefined
                              DaBit
                              Fingers crossed...
                              • arhiundefined
                                arhi @DaBit
                                @DaBit initially the "vibrations" are still there (1/16, closed loop, s42b)
                                AVERAGE:  449 ,  205.2
                                221
                                221
                                221
                                222
                                222
                                222
                                222
                                221
                                222
                                221
                                AVERAGE:  450 ,  221.5
                                234
                                234
                                234
                                234
                                234
                                235
                                234
                                235
                                234
                                234
                                AVERAGE:  451 ,  234.2
                                256
                                256
                                255
                                256
                                255
                                256
                                256
                                255
                                256
                                256
                                AVERAGE:  452 ,  255.7
                                after it finish we'll check the positional error but.. imho this S42B is a complete and utter POS 😞
                                this is measured second after step!!! so the vibration is either $#^#@ motor or S42B dancing around the target location (same vibration 10sec after step too)
                                  alankilian @arhi
                                  @arhi Do you mean that the values you are reading are changing by plus or minus one if you read the encoder a lot of times?
                                  Because that's not unusual for such a high-resolution encoder where one count is 0.005-degrees of angle.
                                  Also, it's possible to get a +/- 1 oscillation if you stop RIGHT ON the edge of a line and move an infinitesimally-small angle. But I wouldn't expect that on every step. You showed three steps where it was doing it, so I think it's the controller.
                                  Hey, depending on how the s42b reads the TLE5012B angle sensor it can really only get either 15 bits or 16 bits of value from the angle of the magnet, so your encoder might have twice the resolution of the controller.
                                  15 bit representation of absolute angle value on the output (resolution of 0.01°)
                                  16 bit representation of sine / cosine values on the interface
                                  So I think the controller is doing about as well as it can.
                                  • arhiundefined
                                    arhi
                                    • arhiundefined
                                      arhi @alankilian
                                      Yes. But if I turn motor off that does not happen.
                                      Exactly, happens almost every time, and with TLC for e.g. it was not happening (we'll see how it will behave with alu coupler) and when I turn the driver off it does not happen so it's def "dancing", not by much but..
                                      WRT "dancing", probably. WRT "position", not really 😞
                                      The LCD is not showing errors, the "error" led (lost step) is off .. and 800 steps in forward and then 800 back we have error of 0.75° .. that's HUGE IMHO especially considering 1step/second speed
                                      • fcwiltundefined
                                        fcwilt @arhi
                                        If you were to configure the stepper (if possible) to only use whole steps would the error go away?
                                        • DaBitundefined
                                          DaBit
                                          That's half a step. I would expect a simple open-loop motor to perform better.
                                          On the other hand, I am sure you can interpolate a single rotating magnet with 15 bit resolution, but resolution != precision.
                                          A long time ago I did approximately the same for a customer, but back then it was an entire board with an FPGA, Burr-Brown ADC's and discrete analog frontend. We got ~9 bits of accuracy, the rest got lost in noise and nonlinearities.
                                          • arhiundefined
                                            arhi @fcwilt
                                            @fcwilt said in stepper precision:
                                            with S42B - not that I know ... I'll do as much tests with S42B first (open and closed loop) then moving to 2208 with different motors ... I'll add graphs as I go trough different tests but as you can see it is all rather slow as I'm doing 1step/sec
