    mesh leveling help
    416
    • usas12undefined
      usas12
      Thanks for the reply, Yep straight to the deep end for me, thank god for forums. It's in the "Z stop"
      • usas12undefined
        usas12 @Phaedrux
        @Phaedrux
        I have this
        M574 X1 Y1 S3 ; Set X / Y endstop stall detection
        M574 Z1 S1 P"zstop" ; Set Z endstop probe
        M558 P7 X0 Y0 Z2 H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
        G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
        M557 X10:290 Y20:180 S40 ; Define mesh grid
        on a G29 S0 call I'm getting the Error: z probe 0 not found.
        The switch works fine when homing
        I've tried adding
        M558 P7 C"^Zstop" H5 F120 T6000
        Same result: z probe 0 not found.
        • o_lampeundefined
          o_lampe @usas12
          @usas12 said in mesh leveling help:
          I've tried adding
          Maybe it's zstop**.in**?
          Just guessing...
          • usas12undefined
            usas12
            found out that v3+ firmware cannot have a Zstop work as a end stop and a probe.
            So I tried this
            M574 X1 S3 ; Set X endstop stall detection
            M574 Y1 S3 ; Set Y endstop stall detection
            M574 Z0 P"nil" ; No Z endstop @used by DC42 using G30 homing
            M558 P8 C"zstop" H5 F120 T10000 A5 S0.01 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds @DC42
            G31 Z0 ; Set Z probe trigger value, offset and trigger height
            M557 X4:292 Y4:185 S16:15 ; Set Z probe: Define mesh grid
            M574 C1 S3 ; Stall detect coupler at low end of its range
            Still getting the "z probe 0 not found" error message
              jay_s_uk
              Can you confirm you are running RRF3 by sending and posting the output of M115.
              Also remove
              as its not required
              usas12undefined 1 Reply Last reply Reply Quote 1
              • usas12undefined
                usas12
                This post is deleted!
                • usas12undefined
                  usas12 @jay_s_uk
                    jay_s_uk
                    @usas12
                    If you run
                    M98 P"config.g"
                    Any errors should be shown.
                    Can you also post your full config file.
                    usas12undefined 1 Reply Last reply Reply Quote 0
                    • usas12undefined
                      usas12 @jay_s_uk
                      @jay_s_uk said in mesh leveling help:
                      M98 P"config.g"
                      G21 ; Work in millimetres
                      M555 P2 ; Set firmware compatibility to look like Marlin
                      ; Read https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
                      M550 P"ToolChanger" ; Set machine name
                      M552 S1 ; Enable Networking
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      M667 S1 ; Select CoreXY mode
                      M574 Z1 S2 ; Set Z endstop probe
                      ; Drive direction
                      M569 P0 S0 ; Drive 0 X
                      M569 P1 S0 ; Drive 1 Y
                      M569 P2 S1 ; Drive 2 Z
                      M569 P3 S0 ; Drive 3 E0
                      M569 P4 S0 ; Drive 4 E1
                      M569 P5 S1 ; Drive 5 E2
                      M569 P6 S1 ; Drive 6 E3
                      M569 P7 S0 ; Drive 7 COUPLER
                      M569 P8 S0 ; Drive 8 UNUSED
                      M569 P9 S0 ; Drive 9 UNUSED
                      M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping
                      M208 X-35:328.5 Y-49:243 Z0:300 C0:260 S0 ; Set axis maxima & minima
                      M350 C8 I0 ; Configure microstepping without interpolation
                      M350 X16 Y16 Z16 E16:16:16:16 I1 ; Configure microstepping with interpolation
                      M92 X100 Y100 Z1600 C100 E834:834:834:834 ; Set steps per mm
                      M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min)
                      M201 X6000 Y6000 Z400 C400 E2500:2500:2500:2500 ; Set accelerations (mm/s^2)
                      M906 X2000 Y2000 Z1330 C400 E1680:1680:1680:1680 I30 ; Set motor currents (mA) and motor idle factor in percent
                      M84 S120 ; Set idle timeout
                      ;Stall Detection
                      M915 C S5 F0 H200 ; Coupler
                      ;Stall Detection
                      M915 X Y S5 F0 H400 ; X / Y Axes
                      M305 P0 T100000 B4725 C7.06e-8 ; Set thermistor
                      M143 H0 S225 ; Set temperature limit for heater 0 to 225C
                      M305 S"T0" P1 T100000 B4725 C7.06e-8 ; Set thermistor
                      M143 H1 S300 ; Set temperature limit for heater 1 to 300C
                      M305 S"T1" P2 T100000 B4725 C7.06e-8 ; Set thermistor
                      M143 H2 S300 ; Set temperature limit for heater 2 to 300C
                      M305 S"T2" P3 T100000 B4725 C7.06e-8 ;Set thermistor
                      M143 H3 S300 ; Set temperature limit for heater 3 to 300C
                      M305 S"T3" P4 T100000 B4725 C7.06e-8 ; Set thermistor
                      M143 H4 S300 ; Set temperature limit for heater 4 to 300C
                      M563 P0 S"T0" D0 H1 F2 ; Define tool 0
                      G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
                      G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C
                      M563 P1 S"T1" D1 H2 F4 ; Define tool 1
                      G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
                      G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C
                      M563 P2 S"T2" D2 H3 F6 ; Define tool 2
                      G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets
                      G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C
                      M563 P3 S"T3" D3 H4 F8 ; Define tool 3
                      G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets
                      G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C
                      M106 P0 S0 ; UNUSED
                      M106 P1 S255 H1 T70 ; T0 HE
                      M106 P2 S0 ; T0 PCF
                      M106 P3 S255 H2 T70 ; T1 HE
                      M106 P4 S0 ; T1 PCF
                      M106 P5 S255 H3 T70 ; T2 HE
                      M106 P6 S0 ; T2 PCF
                      M106 P7 S255 H4 T70 ; T3 HE
                      M106 P8 S0 ; T3 PCF
                      M593 F50 ; cancel ringing at 50Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
                      ;M376 H15 ; bed compensation taper
                      ;tool offsets
                      ; !ESTIMATED! offsets for:
                      ; V6-tool: X-9 Y39 Z-5
                      ; Volcano-tool: X-9 Y39 Z-13.5
                      ; Hemera-tool: X-37.5 Y43.5 Z-6
                      G10 P0 X-9 Y39 Z-5 ; T0
                      G10 P1 X-9 Y39 Z-5 ; T1
                      G10 P2 X-9 Y39 Z-5 ; T2
                      G10 P3 X-9 Y39 Z-5 ; T3
                      ;deselect tools
                      T-1
                      ;M572 D0 S0.2 ; pressure advance T0
                      ;M572 D1 S0.2 ; pressure advance T1
                      ;M572 D2 S0.2 ; pressure advance T2
                      ;M572 D3 S0.2 ; pressure advance T3
                      M501; load config-override.g
                        jay_s_uk
                        @usas12
                        The config you have posted is for RRF2.
                        I suggest you look at these files https://github.com/Duet3D/RRF-machine-config-files/tree/master/E3D_Tool_Changer/dc42-wifi-centreZero-quadTitan
                        • usas12undefined
                          usas12 @jay_s_uk
                          @jay_s_uk WOW that made a big difference, Thank you!
                            Phaedrux Moderator @o_lampe
                            @o_lampe said in mesh leveling help:
                            I've tried adding
                            Just guessing...
                            Nope. zstop is correct in this case. https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
