    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • GoremanXundefined
      GoremanX
      Works perfect... now I just need to move the camera off-system. Apparently while the Duet is printing (in SBC mode), the SPI bus on the attached pi gets too busy to handle the HQ camera feed and all the captured photos get messed up 😞
        Phaedrux Moderator @GoremanX
        @GoremanX said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
        Interesting. Pi cam module?
        GoremanXundefined 1 Reply Last reply Reply Quote 0
        • GoremanXundefined
          GoremanX @Phaedrux
          @Phaedrux said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
          Yeah it's a genuine Raspberry Pi HQ camera. It works fine as long as the Duet isn't printing, but as soon as it starts printing, the photos end up with very random wide magenta bands all the way across and weird lines of noise. At the end of the print everything returns to normal. So I was gonna build a separate camera using the same HQ module and a Pi Zero W
            I do the same with MotionOS and it works quite well.
            • Greg_the_makerundefined
              Greg_the_maker
              I'm a complete idiot when it comes to programming and I am finding the instructions a little vague. I feel I need some assistance please 🙂
              The Installation is as follows.
              Download.
              Does this mean git clone? That's what I did anyway.
              Rename to just execonmcode
              Rename what? There are a load of .go files in the directory, do I rename one of those?
              chmod etc
              The rest of the install I can manage. I think.
              Thank you for your time.
              • PCRundefined
                PCR
                look some pots up. I made a video about this @Greg_the_maker
                  Greg_the_maker
                  What is it i need to be looking for?
                  • PCRundefined
                    PCR @PCR
                    @PCR said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                    made a little videos how to install it. Mainly for my own reference later
                    How to install and test
                    How to make it as a systemservice
                    Here you go
                      Greg_the_maker
                      thank you 🙂
                      • wilrikerundefined
                        wilriker @Greg_the_maker
                        @Greg_the_maker Thanks for pointing that out. I will point the download instructions towards the GitHub Releases page. For there it should be clear what is meant by renaming also.
                        Manuel
                        My Tool Collection
                          Greg_the_maker
                          Is tehre a way to get terminal messages displayed in the console?
                          For example I need to see a list of usb devices with lsusb, is it possible to have that list returned as an M117 message or similar?
                          • wilrikerundefined
                            @Greg_the_maker In theory this is possible. Right now successful execution will discard the application output and error in execution results in an error being sent to DCS what failed (e.g. file not found but still not the output of the application).
                            I could add that but I am not sure how it will deal with line-breaks.
                            Manuel
                            My Tool Collection
                            Greg_the_makerundefined 1 Reply Last reply Reply Quote 0
                              Greg_the_maker @wilriker
                              @wilriker Ahh ok. was just a thought. would be a nice feature to have though 😉
                              • wilrikerundefined
                                @Greg_the_maker I have to correct myself. In case of an error it will indeed return the output of stdout and stderr combined as an error message. But since we are in short-lived world things can be changed quickly and thus:
                                Release v5.1.2
                                This release adds a new flag -returnOutput to be able to send the collected output of a successful run back to DCS. Prior this was only the case if the execution of the command failed.
                                Note that this cannot be combined with -execAsync.
                                Download
                                As usual get it from GitHub Releases page.
                                Manuel
                                My Tool Collection
                                Greg_the_makerundefined oozeBotundefined 2 Replies Last reply Reply Quote 4
                                  @wilriker Fantastic! Works exactly as desired. Have my upvote!
                                  • oozeBotundefined
                                    oozeBot @wilriker
                                    @wilriker Could you please provide a simple example of using the -returnOutput flag? Thanks
                                    • wilrikerundefined
                                      wilriker @oozeBot
                                      @oozeBot said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                      Simple example:
                                      execonmode -mCode 7777 -command "whoami" -returnOutput
                                      will not just confirm successful completion of the command but as part of this return the output of whoami (that returns the user execonmcode is started as, so probably root) so you can see it e.g. in DWC.
                                      Manuel
                                      My Tool Collection
                                      oozeBotundefined 2 Replies Last reply Reply Quote 0
                                      • oozeBotundefined
                                        oozeBot @wilriker
                                        @wilriker Thanks. So the return is echo'ed in DWC, correct? Could the return value be evaluated within conditional gCode?
                                        garethkyundefined 1 Reply Last reply Reply Quote 0
                                        • garethkyundefined
                                          garethky @oozeBot
                                          I was thinking about this today. Currently there are no variables so there is nothing to write the result back to. (there is a result int from the last code but it can't contain other data types) I think we might have to wait for variables and then we could write the value back to a global.
                                          When that happens... it should be possible to set up an MCode that stores and retrieves values from a file on the SD card. So we could do what M500 does but with key/value semantics of M409:
                                          M7500 K"some.key" V"The value"
                                          M7500 K"some.other.key" V0.05
                                          and then get them back in a global with:
                                          M7500 K"some.key"
                                          echo {global.M7500_value}    ; or whatever you want to name it!
                                          and stored on disk as JSON:
                                          "some": {
                                              "key": "The Value"
                                              "other": {
                                                  "key": 0.05
                                          • EMRosaundefined
                                            EMRosa
                                            Great work! This is incredibly useful and appreciated!
                                            Is there a way to pass quotes through the -command argument?
                                            For example:
                                            execonmcode --command "sudo pkill -fx "blah, blah, blah"" -mCode 7720 -execAsync
                                            I've tried single quotes, escape characters, and changing it to an argument passed through the m-code command;
                                            execonmcode --command "sudo pkill -fx %F" -mCode 7720 -execAsync
                                            and then tried from DWC:
                                            M7720 F"python3 script.py"
                                            but the full argument gets lost. I foolishly tried double quotes and DSF crashed. haha.
                                            Please, forgive my inexperience. There is probably a simple answer to this, but it seems to escape my googling ability.
                                            wilrikerundefined 2 Replies Last reply Reply Quote 0
