    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
      jay_s_uk
      it relies on the duet software framework to work.
      This would work for what you want https://github.com/DanalEstes/DuetLapse
        A Former User @jay_s_uk
        @jay_s_uk said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
        thanks!
        • GoremanXundefined
          GoremanX
          Is this still the easiest way to issue commands on the pi in SBC mode? Or has a native way been implemented in RRF in recent releases? Just wanted to check before investing time and effort in something that's obsolete 😄
          • GoremanXundefined
            GoremanX
            Hah! Too late, I'm already neck-deep in implementing it
            @wilriker How do I make it execute the command and exit right away and return success without having to wait for the command to complete? I tried sending my command to background with & but that doesn't appear to work. I'm trying to get it to run a process which continues through the duration of the print, but executing the M code just causes it to hang until the process is complete. I thought it would be execAsync, but that gives me an error on the command line saying that's not a supported flag
            • garethkyundefined
              garethky
              I need this in my life! 😀 I was going to do something evil with file monitoring but this is much more direct.
              I'm planning to use it to run some Python to calculate a bed heightmap to enable probing magnetic beds with irregular optimal probing locations.
              • GoremanXundefined
                GoremanX
                @wilriker I don't think -execAsync is implemented in the 5.1 release. I just downloaded the source code for that release and there's no mention of execAsync anywhere. It's only implemented in the current (uncompiled) source code in the repository. Any chance you could push out a more recent release with the current code? It's the last bit I need to get my setup working.
                • wilrikerundefined
                  wilriker
                  Release v.5.1.1
                  This release introduces three new features:
                  • New parameter -execAsync. This will execute all commands asynchronously returning control immediately back to DCS. This flag is active for all captured M-Codes per execonmcode instance, i.e. if some commands should be performed asynchronously and others synchronously start two execonmcode instances.
                  • New parameters -interceptionMode to select between Pre (default), Post and Exectuted
                  • New parameter -noFlush. This will prevent flushing the code channel prior to executing the attached command. This is useful if the command can be executed once it is read from disk. As with -execAsync this applies to all commands of an instance of execonmcode.
                  As usual it can be downloaded from GitHub Releases page.
                  @GoremanX here you go. 😉
                  Manuel
                  My Tool Collection
                  GoremanXundefined 1 Reply Last reply Reply Quote 2
                  • GoremanXundefined
                    GoremanX @wilriker
                    @wilriker Thank you! 😁
                    • GoremanXundefined
                      GoremanX
                      Works perfect... now I just need to move the camera off-system. Apparently while the Duet is printing (in SBC mode), the SPI bus on the attached pi gets too busy to handle the HQ camera feed and all the captured photos get messed up 😞
                        Phaedrux Moderator @GoremanX
                        @GoremanX said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                        Interesting. Pi cam module?
                        GoremanXundefined 1 Reply Last reply Reply Quote 0
                        • GoremanXundefined
                          GoremanX @Phaedrux
                          @Phaedrux said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                          Yeah it's a genuine Raspberry Pi HQ camera. It works fine as long as the Duet isn't printing, but as soon as it starts printing, the photos end up with very random wide magenta bands all the way across and weird lines of noise. At the end of the print everything returns to normal. So I was gonna build a separate camera using the same HQ module and a Pi Zero W
                            I do the same with MotionOS and it works quite well.
                            • Greg_the_makerundefined
                              Greg_the_maker
                              I'm a complete idiot when it comes to programming and I am finding the instructions a little vague. I feel I need some assistance please 🙂
                              The Installation is as follows.
                              Download.
                              Does this mean git clone? That's what I did anyway.
                              Rename to just execonmcode
                              Rename what? There are a load of .go files in the directory, do I rename one of those?
                              chmod etc
                              The rest of the install I can manage. I think.
                              Thank you for your time.
                              • PCRundefined
                                PCR
                                look some pots up. I made a video about this @Greg_the_maker
                                  Greg_the_maker
                                  What is it i need to be looking for?
                                  • PCRundefined
                                    PCR @PCR
                                    @PCR said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                    made a little videos how to install it. Mainly for my own reference later
                                    How to install and test
                                    How to make it as a systemservice
                                    Here you go
                                      Greg_the_maker
                                      thank you 🙂
                                      • wilrikerundefined
                                        wilriker @Greg_the_maker
                                        @Greg_the_maker Thanks for pointing that out. I will point the download instructions towards the GitHub Releases page. For there it should be clear what is meant by renaming also.
                                        Manuel
                                        My Tool Collection
                                          Greg_the_maker
                                          Is tehre a way to get terminal messages displayed in the console?
                                          For example I need to see a list of usb devices with lsusb, is it possible to have that list returned as an M117 message or similar?
                                          • wilrikerundefined
                                            @Greg_the_maker In theory this is possible. Right now successful execution will discard the application output and error in execution results in an error being sent to DCS what failed (e.g. file not found but still not the output of the application).
                                            I could add that but I am not sure how it will deal with line-breaks.
                                            Manuel
                                            My Tool Collection
                                            Greg_the_makerundefined 1 Reply Last reply Reply Quote 0
