    stepper precision
    3D Printing General Chat
    6.4k
    • alankilianundefined
      alankilian @arhi
      @arhi Do you mean that the values you are reading are changing by plus or minus one if you read the encoder a lot of times?
      Because that's not unusual for such a high-resolution encoder where one count is 0.005-degrees of angle.
      Also, it's possible to get a +/- 1 oscillation if you stop RIGHT ON the edge of a line and move an infinitesimally-small angle. But I wouldn't expect that on every step. You showed three steps where it was doing it, so I think it's the controller.
      Hey, depending on how the s42b reads the TLE5012B angle sensor it can really only get either 15 bits or 16 bits of value from the angle of the magnet, so your encoder might have twice the resolution of the controller.
      15 bit representation of absolute angle value on the output (resolution of 0.01°)
      16 bit representation of sine / cosine values on the interface
      So I think the controller is doing about as well as it can.
      • arhiundefined
        arhi
        • arhiundefined
          arhi @alankilian
          @alankilian said in stepper precision:
          Yes. But if I turn motor off that does not happen.
          Exactly, happens almost every time, and with TLC for e.g. it was not happening (we'll see how it will behave with alu coupler) and when I turn the driver off it does not happen so it's def "dancing", not by much but..
          WRT "dancing", probably. WRT "position", not really 😞
          The LCD is not showing errors, the "error" led (lost step) is off .. and 800 steps in forward and then 800 back we have error of 0.75° .. that's HUGE IMHO especially considering 1step/second speed
          • fcwiltundefined
            fcwilt @arhi
            @arhi said in stepper precision:
            If you were to configure the stepper (if possible) to only use whole steps would the error go away?
            • DaBitundefined
              DaBit
              That's half a step. I would expect a simple open-loop motor to perform better.
              On the other hand, I am sure you can interpolate a single rotating magnet with 15 bit resolution, but resolution != precision.
              A long time ago I did approximately the same for a customer, but back then it was an entire board with an FPGA, Burr-Brown ADC's and discrete analog frontend. We got ~9 bits of accuracy, the rest got lost in noise and nonlinearities.
              • arhiundefined
                arhi @fcwilt
                @fcwilt said in stepper precision:
                with S42B - not that I know ... I'll do as much tests with S42B first (open and closed loop) then moving to 2208 with different motors ... I'll add graphs as I go trough different tests but as you can see it is all rather slow as I'm doing 1step/sec
                • arhiundefined
                  arhi @DaBit
                  @DaBit said in stepper precision:
                  I heard from some ppl S42B is awesome, but from some other I heard they are POS .. so I decided to try them out .. so far I already decided I will not be using them in my projects
                  yeah but it does "calibration", moves a circle and records magnet readings at halfsteps I think so the resolution here should help a lot with precision.. but..
                  • arhiundefined
                    arhi
                    what I seen on number of reports on-line, open-loop works better than closed loop with S42B 😞
                    • DaBitundefined
                      DaBit
                      That calibration only cancels fixed nonlinearities (and adds stepper imprecision). A slight magnetic short after calibration of changing operating point of the sensor due to temperature is not cancelled.
                      • arhiundefined
                        arhi @DaBit
                        no clue how these magnet sensors work and what really is the supposed 15 bit precision. I normally deal with optical and mechanical ones, the magnetic ones I used only up to 4bit (for basic rotation)
                        • DaBitundefined
                          DaBit
                          Basically 2 linear magnetic flux sensors oriented with 90 degree rotation. Rotating a magnet over them give a sin and cos signal from which you can calculate the angle.
                          Works fairly well. But usually not 15-bit well. A resolver would be more accurate.
                          [edit]
                          From the datasheet:
                          [/edit]
                          So that's 8.5 bits of precision. The extra 6.5 bits of resolution come in handy for the servo loop, but that is not precision.
                          • arhiundefined
                            arhi
                            open loop, full circle, S42B
                            • arhiundefined
                              arhi
                              in closed loop mode the S42B display show constantly error between -0.04° to +0.04°
                              closed loop is running "much" colder than open loop and I doubt it's using full current I configured it to use (can't dig out my current probe to test, no way to get to it now)
                                alankilian
                                The closed-loop mode of the S42B is not intended to improve accuracy compared to open-loop mode when the motor load is well below the motor's load limit.
                                It's intended to improve accuracy when the load intermittently exceeds the maximum motor load.
                                Try your open-loop vs. closed-loop experiment and hold the rotor with something for 10 steps and see how the closed-loop corrects for that once you remove the load and the open loop mode does not correct the error.
                                THAT'S what the closed-loop mode is for. It might cost you some accuracy in the step-to-step positioning, but you gain the ability to (when the load is lessened) correct for overload conditions and missed-steps.
                                Open-loop cannot do that.
                                • arhiundefined
                                  arhi
                                  • arhiundefined
                                    arhi @alankilian
                                    it does correct the missed steps, but it should be also more precise than what I'm seeing 😞 ... 1° error !?!? that's more than half a step
                                    Anyhow done with S42B, moving on to TMC2208 driver and different motors
                                    • arhiundefined
                                      arhi
                                      Would also be cool if someone can reproduce measurements with S42B as this does not require super good/expensive/high resolution encoder, even cheap 1000 lines encoder should be able to see error 0.5° and 1°
                                      • arhiundefined
                                        arhi
                                        • fcwiltundefined
                                          fcwilt @arhi
                                          Have you done any testing of the "two piece" closed loop systems consisting of a stepper/encoder and separate control unit?
                                          • arhiundefined
                                            arhi @fcwilt
                                            Haven't got to it yet, can't find where I put my vallder stepper with encoder and driver combo. Also I wanna finish with few nema17 before I have to use another mount to test the bigger motor
