    Bigtreetech smart filament sensor
    16
    3.4k
    • Danalundefined
      Danal
      use a continuity tester or voltmeter to see what it outputs...
      • minimundefined
        minim
        Hi. Did u succeed using this sensor? Considering getting one to test..
        • omniundefined
          omni
          Same question - I just finished making all the cables for my new DUET 2 ethernet setup - and connected the Bigreetech smart filament sensor physically, but haven't found any info on setting up the sensor in Raprap properly....
          Since the sensor should work in Marlin 2.0 pretty much seamlessly - maybe we can check in the source? Does anyone have any ideas?
          • zaptaundefined
            zapta @omni
            Is this the product you try to connect? https://github.com/bigtreetech/smart-filament-detection-module/blob/master/manual/smart filament sensor module manual191205.pdf
            It works also on 3.3V (good), has GND, power and signal wires, and the 'break interface' sounds as an on/off output. In Duet's terminology, this sounds a 'filament run-out sensor' (not to be confused with a 'filament monitor').
            https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors
            omniundefined 1 Reply Last reply Reply Quote 0
            • omniundefined
              omni @zapta
              @zapta Thanks for the answer.
              Yes, that is the product. I have already connected the wiring to the E0 stop properly (+3V, Signal, GND) - but I have seen on the other post (here) that another user has been having problems in setting it in firmware.... it's a pulse sensor it has a rotary encoder (I don't know if it's an optical or magnet one, haven't disassembled it completely). That is why I was asking if anyone had success in setting it up properly...
              • zaptaundefined
                zapta @omni
                @omni, if it's a pulse generating sensor, does option #7 here work? https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
                (you will also need to specify pulses per millimeter, the Duet input you are using, and the extruder it relates to)
                • omniundefined
                  omni @zapta
                  @zapta
                  I've tried it yesterday - but it seems that Duet is not recording any data from the sensor.
                  I configured the sensor as following, just to log data when printing :
                  M591 D0 P7 C"^e0stop" L0.07853981634 R90:110 E3 S0
                  but it did not receive any data.
                  Any ideas on what I can try is highly appreciated.
                  Thanks again
                  eight_headsundefined 1 Reply Last reply Reply Quote 1
                  • eight_headsundefined
                    eight_heads @omni
                    @omni any luck? I have one of these on hand I use on my Marlin machines and would like to use it as well.
                    arhiundefined Stockerbotundefined 2 Replies Last reply Reply Quote 0
                    • arhiundefined
                      arhi @eight_heads
                      @eight_heads lemme answer before he gets online 😄 (he's not very active on forum 😄 ). it works on his board, the config does not need pullup and need much bigger values as it is low res
                      so something like
                      M591 D0 P7 C"e0stop" L7 R50:200 E15 S0
                      phcellaundefined 1 Reply Last reply Reply Quote 0
                      • phcellaundefined
                        phcella @arhi
                        @arhi do you test it on your board?
                        I want to buy the same sensor you did.
                        • arhiundefined
                          arhi @phcella
                          @phcella said in Bigtreetech smart filament sensor:
                          I am not using btr smart filament sensor
                          • Stockerbotundefined
                            Stockerbot @eight_heads
                            @eight_heads I just used @arhi config and tested the BTT Smart Filament sensor on my Duet WIFI - Seems to be working perfectly!
                              Stockerbot @phcella
                              @phcella I just tested, success!
                              • omniundefined
                                omni
                                Mine worked well for a while and then started to give false warnings and stops (under extrusion), and now it does not work at all. I guess that maybe the spring holding the wheel got loose and it's not rotating enough while the filament is passing, but haven't opened it yet to check....
                                • phcellaundefined
                                  phcella @Stockerbot
                                  @Stockerbot Thanks, I will buy one to test it.
