    New to the duet COMPLETE NEWBIE
    5.5k
    • gabrealekundefined
      gabrealek
      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:22:13 GMT-0500 (Eastern Standard Time)
      M550 P"Creola" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
      M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z400 S0 ; set axis maxima
      M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
      M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X10:220 Y10:220 S20 ; define mesh grid
      M308 S0 P"e0temp" Y"thermistor" T9880 B4185 ; configure sensor 0 as thermistor on pin e0temp
      M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
      M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H0 S250 ; set temperature limit for heater 0 to 250C
      M308 S1 P"bedtemp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin bedtemp
      M950 H1 C"bedheat" T1 ; create bed heater output on bedheat and map it to sensor 1
      M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H1 ; map heated bed to heater 1
      M143 H1 S80 ; set temperature limit for heater 1 to 80C
      M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
      M563 P0 S"Extruder" D0 F0:1 ; define tool 0
      M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:30:54 GMT-0500 (Eastern Standard Time)
      G91 ; relative positioning
      G1 H2 Z18 F480000 ; lift Z relative to current position
      G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F480000 ; go back a few mm
      G1 H1 X-305 Y-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-405 F3600 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 Z18 F8000 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:31:40 GMT-0500 (Eastern Standard Time)
      G1 H1 X-305 F3000 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F480000 ; go back a few mm
      G1 H1 X-305 F3600 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-18 F480000 ; lower Z again
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:31:58 GMT-0500 (Eastern Standard Time)
      G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered
      Ive checked my wiring and it all seems correct.
      @Phaedrux
        Phaedrux Moderator @gabrealek
        @gabrealek said in New to the duet COMPLETE NEWBIE:
        It would be more traditional for heater0 to be the bed heater and for heater1 to be the first tool heater. I don't think that's strictly enforced now with RRF3 being more flexible about it, but still not a bad idea to conform to the standard.
        Also, your tool definition is lacking a heater.
        Maybe take another crack at the config tool. https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
        gabrealekundefined 1 Reply Last reply Reply Quote 0
          gabrealek @Phaedrux
          @Phaedrux Okay, back into the studio I go. Thank you for helping me!!!!
            Double check your heater and thermistor connections as well. Hopefully that will resolve the odd heater reporting in DWC.
            Otherwise the config looks ok so far.
            After the heaters are sorted you'd want to carefully check the motor directions are correct and endstops are working and then test homing. And then test and tune the heaters and calibrate the extruder.
            follow along
            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
              gabrealek @Phaedrux
              @Phaedrux thanks. Ive checked the connections and redid them as the ender tutorial and now i am having a fault in the hotend and also the bed when i try to heat it as well.
              Here is my new config . . ive been trying to get it right all day. ive done it exactly as the tutorial as well.
              ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)
              M950 H0 C"e0heat" T0 ; create bed heater output on e0heat and map it to sensor 0
              M308 S1 P"e1temp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin e1temp
              M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
              M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
              M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on
              M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
              T0 ; select first tool
                T9880
                I think you're missing a digit in your T values.
                  gabrealek @Phaedrux
                  @Phaedrux I dont understand how i would correct that. . its in there twice. . Ive tried to look up what a T9880 is . . i cant find anything .. Is it a problem with the setting i put in the config?
                    The correct values are T98801
                      gabrealek @Phaedrux
                      @Phaedrux thank you. It is greatly appreciated. Also, is the estop0 supposed to light up like the x,y, and z? When I plug it in it does not light up
                        That depends. What kind of switch are you plugging in as an endstop? The difference would be normally open switch or normally closed switch. The important thing is that the LED changes state when the switch is depressed.
                        What is the intended use for the endstop?
                        gabrealekundefined 5 Replies Last reply Reply Quote 0
                          gabrealek @Phaedrux
                          @Phaedrux I was just wondering. that was all .. thank you for all of your help!! i really appreciate it. Hope I didn't bother you to much. Lol
                            gabrealek @Phaedrux
                            @Phaedrux OKAY, "sighs" new problem of the day. .
                            I got the hang of it now . . just posted to see if you'd find it sooner than my baby eyes
                            Error: G10: Requested temperature out of range
                            M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin e0temp
                            M950 H0 C"bedheat" T0 ; create bed heater output on e0heat and map it to sensor 0
                            M308 S1 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e1temp
                              gabrealek @Phaedrux
                              @Phaedrux
                              I think its this line here maybe??
                                gabrealek @Phaedrux
                                @Phaedrux Fixed it and was able to get it heated up to 180,
                                Now when i try to get the bed heated i get this
                                Error: Heater 0 fault: temperature rising much more slowly than the expected 1.8°C/sec
                                  gabrealek @Phaedrux
                                  @Phaedrux Okay i looked up the issue and found YOU lol, going to PID tune the bed. .
                                    We're on a roll!
                                      gabrealek @Phaedrux
                                      @Phaedrux Good morning from my end. we definitely were on a roll yesterday. I did a PID test for the heated bed and this is what I got,
                                      1/20/2021, 7:25:49 PM M500
                                      1/20/2021, 7:25:31 PM M307 H0 R0.208 C535.3 D7.42 S1.00 V12.0
                                      Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 136C
                                      1/20/2021, 7:23:29 PM Warning: heater behaviour was not consistent during tuning
                                      Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 4384 seconds. This heater needs the following M307 command:
                                      Send M500 to save this command in config-override.g
                                      At this point I don't know what to do.
                                      EDIT: indeed i do, Ill go back in to the shop and tune the hotend as well and try to run the min temps for PLA. . hopefully i dont get any errors. I will let you know once i am finished.
                                      • Vetiundefined
                                        Veti
                                        you send M500 to save the tuning parameters.
                                          gabrealek @Veti
                                          @Veti
                                          Yes i sent it after both test were performed. Here is the summary for both
                                          1/21/2021, 10:15:03 AM M500
                                          1/21/2021, 10:14:47 AM M307 H1 R2.273 C141.1 D6.29 S1.00 V12.0
                                          1/21/2021, 10:14:20 AM Auto tuning heater 1 completed after 3 idle and 5 tuning cycles in 401 seconds. This heater needs the following M307 command:
                                          1/21/2021, 10:11:54 AM Auto tune starting phase 3, fan off
                                          1/21/2021, 10:09:52 AM Auto tune starting phase 2, heater settling
                                          1/21/2021, 10:07:44 AM Auto tune starting phase 1, heater on
                                          1/21/2021, 10:07:39 AM M303 H1 S210
                                          Auto tuning heater 1 using target temperature 210.0°C and PWM 1.00 - do not leave printer unattended
                                          1/21/2021, 10:06:23 AM M106 S127
                                          1/21/2021, 10:00:22 AM Connection established
                                          1/20/2021, 7:27:51 PM Connection interrupted, attempting to reconnect...
                                          HTTP request timed out
                                          1/20/2021, 6:22:39 PM Auto tune starting phase 3, fan off
                                          1/20/2021, 6:14:17 PM Auto tune starting phase 2, heater settling
                                          1/20/2021, 6:10:31 PM Auto tune starting phase 1, heater on
                                          1/20/2021, 6:10:25 PM M303 H0 S60
                                          Auto tuning heater 0 using target temperature 60.0°C and PWM 1.00 - do not leave printer unattended
                                          • Vetiundefined
                                            Veti
                                            i was talking about the delta calibration
