    DWC not opening
    Duet Web Control
    632
      dc42 administrators @User3D
      @User3D said in DWC not opening:
      why is actual IP : 0.0.0.0 ????
      Because no Ethernet link has been established. If you run M122 on the Duet, it will probably show "Establishing link" as the network connection status.
      User3Dundefined 1 Reply Last reply Reply Quote 0
        What exactly are you connecting to? A switch? Router?
        When you had the Duet set to obtain a DHCP address, what did it give you?
        Were you able to ping that address?
        On your PC it looks like you're in subnet 192.168.42, but is the Duet on the same subnet?
        If you manually set an IP on the duet and on your PC and connect them together port to port are you then able to reach DWC by IP address?
        User3Dundefined 2 Replies Last reply Reply Quote 0
        • User3Dundefined
          User3D @dc42
          @dc42 that i figured out yesterday only.
          even after connecting ethernet it didn't work!!
          • User3Dundefined
            User3D @Phaedrux
            @Phaedrux
            • connected to a switch
            • Ping failed!
              How do I check if my Duet is on same subnet??
            • User3Dundefined
              User3D @Phaedrux
              @Phaedrux said in DWC not opening:
              I tried setting manual IP on my PC.
              ipconfig confirms that Pc is running on set IP.
              config.g:
              on M552 :
              ping failed!! DWC still not opening using 192.168.1.100....
              I don't know what i'm missing here!
              • User3Dundefined
                User3D
                @dc42 @Phaedrux any suggestions?
                  Do you get any lights on the duet ethernet port when connected directly to your PC?
                  When connected like that can you also connect via USB terminal and send M122 and post the results?
                  Try another cable?
                  User3Dundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • User3Dundefined
                    User3D @Phaedrux
                    When I connect duet via USB and nothing else but SD card is connected then ethernet light doesn't glow. It glows only after ethernet is connected. I am able to communicate using YAT.
                    Try another cable?
                    YUP! Tried the same with different cable on different PC. STILL NOT OPENING.
                      Phaedrux Moderator @Phaedrux
                      Still haven't seen an M122 result yet.
                      • User3Dundefined
                        User3D @Phaedrux
                        @Phaedrux
                        === Diagnostics ===<LF>RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                        <LF>Board ID: 08DJM-956BA-NA3TN-6J1DJ-3S86L-1TB6T<LF>Used output buffers: 1 of 40 (3 max)<LF>=== RTOS ===<LF>Static ram: 149788<LF>Dyna
                        mic ram: 92908 of which 28 recycled<LF>Never used RAM 116108, free system stack 190 words<LF>Tasks: NETWORK(ready,408) ETHERNE
                        T(blocked,194) HEAT(blocked,188) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,360) TMC(blocked,65) MAI
                        N(running,1134) IDLE(ready,19)<LF>Owned mutexes: USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:03:05 ago, cause: power up<LF>Last s
                        oftware reset details not available<LF>Error status: 0x00<LF>Aux0 errors 0,0,0<LF>Aux1 errors 0,0,0<LF>MCU temperature: min 21.7, cu
                        rrent 35.0, max 35.2<LF>Supply voltage: min 0.1, current 0.2, max 0.3, under voltage events: 0, over voltage events: 0, pow
                        er good: no<LF>12V rail voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0<LF>Driver 0: position 0, ok, reads 0,
                        writes 0 timeouts 0, SG min/max 0/0<LF>Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0<LF>Driver 2: pos
                        ition 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0<LF>Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min
                        /max 0/0<LF>Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0<LF>Driver 5: position 0, ok, reads 0, write
                        s 0 timeouts 0, SG min/max 0/0<LF>Date/time: 1970-01-01 00:00:00<LF>Slowest loop: 5.20ms; fastest: 0.06ms<LF>=== Storage ===<LF>Free
                        file entries: 10<LF>SD card 0 detected, interface speed: 25.0MBytes/sec<LF>SD card longest read time 3.1ms, write time 0.0ms,
                        max retries 0<LF>=== Move ===<LF>DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000<LF>=== MainDDARi
                        ng ===<LF>Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1<LF>===
                        AuxDDARing ===<LF>Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA sta
                        te -1<LF>=== Heat ===<LF>Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1<LF>=== GCodes ===<LF>Segment
                        s left: 0<LF>Movement lock held by null<LF>HTTP is idle in state(s) 0<LF>Telnet is idle in state(s) 0<LF>File is idle in state(s) 0<LF>
                        USB is ready with "M122" in state(s) 0<LF>Aux is idle in state(s) 0<LF>Trigger is idle in state(s) 0<LF>Queue is idle in state(s)
                        0<LF>LCD is idle in state(s) 0<LF>SBC is idle in state(s) 0<LF>Daemon is idle in state(s) 0<LF>Aux2 is idle in state(s) 0<LF>Autopause
                        is idle in state(s) 0<LF>Code queue is empty.<LF>=== Network ===<LF>Slowest loop: 0.19ms; fastest: 0.02ms<LF>Responder states: HTTP
                        (0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions<LF>HTTP sessions: 0 of 8<LF>- E
                        thernet -<LF>State: active<LF>Error counts: 0 0 1 0 0<LF>Socket states: 2 2 2 2 2 2 0 0<LF>=== Filament sensors ===<LF>Extruder 0 senso
                        r: ok<LF>=== CAN ===<LF>Messages queued 735, send timeouts 1662, received 0, lost 0, longest wait 0ms for reply type 0, free b
                        uffers 47<LF>ok<LF>
                          Change your line feed settings in YAT and try again
                          Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
                          • User3Dundefined
                            User3D @Phaedrux
                            @Phaedrux
                            M122
                            Static ram: 149788
                            Dynamic ram: 92908 of which 28 recycled
                            Tasks: NETWORK(ready,408) ETHERNET(blocked,194) HEAT(blocked,188) CanReceiv(blocked,927) CanSender(blocked,371) CanClock
                            (blocked,360) TMC(blocked,65) MAIN(running,1134) IDLE(ready,19)
                            Last reset 00:01:05 ago, cause: power up
                            Last software reset details not available
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Aux1 errors 0,0,0
                            MCU temperature: min 20.3, current 32.8, max 32.8
                            Supply voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0, over voltage events: 0, power good: no
                            Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 3.1ms, write time 0.0ms, max retries 0
                            === MainDDARing ===
                            === AuxDDARing ===
                            Segments left: 0
                            Queue is idle in state(s) 0
                            === Network ===
                            Slowest loop: 0.16ms; fastest: 0.02ms
                            • Ethernet -
                              State: active
                              Extruder 0 sensor: ok
                              === CAN ===
                              Messages queued 255, send timeouts 583, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
                              ok
                              So when you were using DHCP with a router, was the Duet pulling a DHCP address?
                              • User3Dundefined
                                User3D @Phaedrux
                                @Phaedrux
                                This is happening
                                M552 S0
                                Network stopped
                                ok
                                M552 P0.0.0.0 S1
                                ok
                                M552
                                Ethernet is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                                ok
                                • User3Dundefined
                                  User3D @Phaedrux
                                  Hiiiii @Phaedrux ,
                                  Issue is resolved. It was internal network issue. For security purposes, It was blocked by the administrator. I am grateful of your efforts. Thank You so much!
                                    Glad you were able to figure it out.
