    G30 S-1 is giving me heart stitches [SOLVED]
    4.7k
    • o_lampeundefined
      o_lampe @Veti
      @Veti
      that was just my interpretation why homeZ doesn't work even after I homed X/Y
      Seems the fake endstops doesn't change anything
      • Vetiundefined
        Veti
        if you dont want to use endstops, you should just setup sensorless homing
        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
        • fcwiltundefined
          fcwilt @o_lampe
          @o_lampe said in G30 S-1 is giving me heart stitches:
          with the homeall script the behaviour is a bit different: it runs to 20,20 then probes (G1 S1) and runs against the rear beam.
          Whenever G30 is issued,the printer freaks out.
          Do you understand what a G1 command with the S1 (now H1) parameter does?
          If you have the X and Y end stops forced active your homeall.g script will not work.
          If you wish to use the Z probe for homing you don't use any G1 S1 Znnn command - just G30 BUT you likely want to use a G1 Xnnn Ynnn command to move to the center of the bed first.
          You also need to have M574 Z0 and a valid Z probe configuration - which you appear to have.
          If you aren't going to have actual end stops and are not going to use sensor-less homing you can force any axis to be "homed" with G92 Xnnn (or Y) but naturally the value nnn should be where the axis is actually positioned at the time.
          I suggest you just install actual end stop sensors.
            Phaedrux Moderator @o_lampe
            Can you send M98 P"config.g" in the console to check for some syntax error messages that are normally lost in startup?
            M584 X0 Y1 Z2 E3 ; drive mapping
            The M584 should come earlier than any of the commands that reference the axis that it creates. I think the only reason it's worked so far is that you're using default mappings, but still weird things can happen.
            Copying your values into the config generator won't duplicate any of the syntax errors that may be there. I really suggest you try generating a fresh set even just to see what it looks like to compare to yours. And yes it will make switching over to RRF3 much easier.
            • o_lampeundefined
              o_lampe @fcwilt
              @fcwilt said in G30 S-1 is giving me heart stitches:
              Thanks @fcwilt
              I read that line last night and I couldn't find sleep, because it makes totally sense.
              It's like re-purposing a fan connector for something else:
                1. you have to undefine the fan
                1. now you can define it as LED-light colour changer or whatever
              @Phaedrux
              I moved the drive mapping right behind the M667 CoreXY definition.
              Now, downing the coffee and back to the printer 🙂
              The new config.g. I've also changed the extruder settings, since the E3d Titan is the only new part of the printer. It's run by a 1.8° 1708 pancake stepper, an improvement against the 0.9° original motor i guess.
              config.g
              • o_lampeundefined
                o_lampe
                One problem less, two new problems?
                I tested the new config and behaviour was unchanged. G30 refuses to run before Z axis is homed. When it runs, it goes all over the place instead of probing where it should.
                G30 X20 Y20 S2 ; is a valid code,right?
                Then I checked my M667 setting again. Here in RepRap-Wiki and then in the Duet dozuki pages and look, what it says:
                This command is deprecated in RRF 2.03 and later. Use M669 instead.
                So I used M669 K1 and started homeAll.
                ; homeall file for use with dc42 Duet firmware on CoreXY printers
                ; This file assumes the endstop switches are at the low end of each axis.
                ; Reverse the X and Y movement for high-end switches.
                ; Adjust the bed upper and lower limits in config.g (M208 commands) to get the correct homing positions
                G91                       ; relative mode
                G1 F2400 		   		; course home X or Y //S1 X-340 Y-240
                G1 S1 X-340               ; course home X
                G1 S1 Y-240               ; course home Y
                G1 X14 Y14 F600             ; move away from the endstops
                G1 S1 X-20                ; fine home X
                G1 S1 Y-20                ; fine home Y
                G1 X20 Y20 F4000
                G1 F600
                G1 S1 Z-300 F600
                G1 Z5 F200
                G30 X20 Y20 S-2
                ; If you are using a microswitch for Z homing, insert similar code for the Z axis here,
                ; but use lower feed rates suitable for your Z axis.
                G90                       ; back to absolute mode
                The tool still dances around the bed, but luckily didn't crash anywhere. The endposition of it can be seen here:
                WHY does it do that?
                The good news is, when I move to X0 Y0 Z5, the position is almost correct.
                Now I can spend my time with mesh bed leveling and see what happens next.
                //edit Should I go to absolute positioning (G90) before G30 in homeAll? Hold your breath, BRB...
                • Vetiundefined
                  Veti
                  your homeall also uses old syntax.
                  the S1 is depricated.
                  also i dont understand why you are making your life so difficult, instead of using the correct generated homing files from the configurator.
                  Using S-2 here is incorrect
                  o_lampeundefined 2 Replies Last reply Reply Quote 0
                  • o_lampeundefined
                    o_lampe @Veti
                    @Veti said in G30 S-1 is giving me heart stitches:
                    No, it's not, the dozuki wiki says, they are the same.
                    G1 Xnnn Ynnn Znnn S0	Ignore endstops while moving.
                    G1 Xnnn Ynnn Znnn S1	Sense endstops while moving. On Delta (only), axis letters refer to individual towers.
                    G1 Xnnn Ynnn Znnn S2	Ignore endstops while moving. Also ignore if axis has not been homed. On Delta and CoreXY, axis letters refer to individual towers.
                    G1 Xnnn Ynnn Znnn S3	Sense endstops while measuring axis length, and set the appropriate M208 limit to the measured position at which the endstop switch triggers.
                    RRF_2.02 and later, BEFORE M452 Laser Mode.
                    S parameter behaves as shown above.
                    • Vetiundefined
                      Veti @o_lampe
                      @o_lampe
                      since S has a double meaning, the use of H is encouraged.
                      • o_lampeundefined
                        o_lampe @Veti
                        Maybe, but I also tried the other options, without any difference
                        • o_lampeundefined
                          o_lampe @Veti
                          @o_lampe
                          Just for your peace of mind, I'll try (again)
                          Why I don't use the config tool is simple: In MY config, I know every line. Where it is and what it does (or should do)
                          A generated file is different.
                          Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • Vetiundefined
                            Veti @o_lampe
                            then at least look at the generated files so that you know how its supposed to be done
                            • fcwiltundefined
                              fcwilt @o_lampe
                              You don't seem to be paying attention.
                              In your new config.g file you have...
                              M574 X1 Y1 Z0 S1 - that is NOT correct - remove the Z0
                              M574 Z1 S2 - that is NOT correct - change it to M574 Z0
                              Now as to your homing file.
                              Do you have actual end stop switches for X and Y OR are you forcing them active?
                              IF you ARE forcing them active your homing file is not going to work.
                              G1 S1 X-340 - will not move but will mark X as homed at whatever position it happens to be at
                              G1 S1 Y-240 - will not move but will mark Y as homed at whatever position it happens to be at
                              G1 X14 Y14 - will move X and Y by 14mm in the direction of the high end of the each axis
                              G1 S1 X-20 - does nothing - will not move
                              G1 S1 Y-20 - does nothing - will not move
                              G1 F600 - serves no purpose - remove it
                              G1 S1 Z-300 F600 - is incorrect - remove it - you are going to use the z probe for homing Z
                              G1 Z5 F200 - should generate an error as Z is not homed - remove it
                              G30 X20 Y20 S-2 - that is not valid syntax - to home with Z probe just use G30 by itself
                              But without actual X and Y end stop sensors you might as well just do the following.
                              G92 X0 - mark X as homed and at position X = 0
                              G92 Y0 - mark Y as homed and at position Y = 0
                              G30 - home Z at the current X and Y position - whatever that happens to be
                              This would work IF the actual starting position of X was 0 and Y was 0.
                              If will be so much simpler if you either install X and Y end stop switches OR use sensor-less homing for X and Y
                              • o_lampeundefined
                                o_lampe @fcwilt
                                Although I must admit that you are right with most of your comment, this line is correct for using the z-probe as endstop.
                                Quote from M574 wiki
                                Snnn Endstop type: ... 2 = Z probe
                                Why did I keep all the useless lines in homeAll? Simply don't want to write it again, when I have real endstops.
                                fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                • o_lampeundefined
                                  o_lampe @fcwilt
                                  As I said earlier, I have to home the Z-axis before running G30. And that's exactly what it does. And it does lift 5mm afterwards, because the axis is now homed according to DWC.
                                  The only it doesn't do, is giving me a Z=0 datum. also G92 Zxxx doesn't.
                                  That's why I had to deal with G30.
                                  • Vetiundefined
                                    Veti
                                    there G30 does not need the z axis to be homed
                                    o_lampeundefined 1 Reply Last reply Reply Quote 1
                                    • fcwiltundefined
                                      fcwilt @o_lampe
                                      Read it all:
                                      Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
                                      M574 Z0 is correct.
                                      • o_lampeundefined
                                        o_lampe @fcwilt
                                        @fcwilt
                                        where's that from, please?
                                        • fcwiltundefined
                                          fcwilt @o_lampe
                                          @fcwilt
                                          Where is what from?
                                          • fcwiltundefined
                                            fcwilt @o_lampe
                                            Because you didn't have M574 Z0 saying to home with the z probe.
