    G30 S-1 is giving me heart stitches [SOLVED]
    4.6k
    • Vetiundefined
      Veti
      the G30 command give you insufficient axis homed?
      • fcwiltundefined
        fcwilt @o_lampe
        @o_lampe said in G30 S-1 is giving me heart stitches:
        As always I homed X/Y before homeZ with G92 X0 Y0.
        The would work IF the actual positions of X and Y were zero. How do you know they are?
        Do I really have to install endstops for X/Y axis?
        No - you can use sensor-less homing.
        I don't care for that myself. To me using physical end stop sensors for homing is like stopping your car using the brakes. Sensor-less homing seems like stopping your car by running into the car in front of you. 😉
        As to using G30: did you read the docs on what each variant of G30 does?
        o_lampeundefined 1 Reply Last reply Reply Quote 1
        • o_lampeundefined
          o_lampe @Veti
          @Veti said in G30 S-1 is giving me heart stitches:
          No, the macro doesn't run G30 because of the error message.
          I used jumpers on X/Y endstops and defined them as active high
          When I ask M119 it reports X/Y at min endstops. Now I should be able to use the homeall macro. But it stops after the same line as above mentioned.
          • Vetiundefined
            Veti
            post your homeall then
            • o_lampeundefined
              o_lampe @fcwilt
              @fcwilt said in G30 S-1 is giving me heart stitches:
              Yes, and I also tried some other versions with various Px and Sx parameters.
              • o_lampeundefined
                o_lampe @Veti
                ; homeall file for use with dc42 Duet firmware on CoreXY printers
                ; This file assumes the endstop switches are at the low end of each axis.
                ; Reverse the X and Y movement for high-end switches.
                ; Adjust the bed upper and lower limits in config.g (M208 commands) to get the correct homing positions
                G91                       ; relative mode
                G1 F2400 		   		; course home X or Y //S1 X-340 Y-240
                G1 S1 X-340               ; course home X
                G1 S1 Y-240               ; course home Y
                G1 X14 Y14 F600             ; move away from the endstops
                G1 S1 X-20                ; fine home X
                G1 S1 Y-20                ; fine home Y
                G1 X20 Y20 F4000
                G1 F600
                G1 S1 Z-300 F600
                G1 Z5 F200
                G30
                ; If you are using a microswitch for Z homing, insert similar code for the Z axis here,
                ; but use lower feed rates suitable for your Z axis.
                G90                       ; back to absolute mode
                ; If you homed the Z axis using an endstop switch, you can insert a G92 command here to correct the height.
                • Vetiundefined
                  Veti
                  what script wont work without endstops
                  • o_lampeundefined
                    o_lampe
                    with the homeall script the behaviour is a bit different: it runs to 20,20 then probes (G1 S1) and runs against the rear beam.
                    Whenever G30 is issued,the printer freaks out.
                    • o_lampeundefined
                      o_lampe @Veti
                      @Veti
                      that was just my interpretation why homeZ doesn't work even after I homed X/Y
                      Seems the fake endstops doesn't change anything
                      • Vetiundefined
                        Veti
                        if you dont want to use endstops, you should just setup sensorless homing
                        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
                        • fcwiltundefined
                          fcwilt @o_lampe
                          Do you understand what a G1 command with the S1 (now H1) parameter does?
                          If you have the X and Y end stops forced active your homeall.g script will not work.
                          If you wish to use the Z probe for homing you don't use any G1 S1 Znnn command - just G30 BUT you likely want to use a G1 Xnnn Ynnn command to move to the center of the bed first.
                          You also need to have M574 Z0 and a valid Z probe configuration - which you appear to have.
                          If you aren't going to have actual end stops and are not going to use sensor-less homing you can force any axis to be "homed" with G92 Xnnn (or Y) but naturally the value nnn should be where the axis is actually positioned at the time.
                          I suggest you just install actual end stop sensors.
                            Phaedrux Moderator @o_lampe
                            Can you send M98 P"config.g" in the console to check for some syntax error messages that are normally lost in startup?
                            M584 X0 Y1 Z2 E3 ; drive mapping
                            The M584 should come earlier than any of the commands that reference the axis that it creates. I think the only reason it's worked so far is that you're using default mappings, but still weird things can happen.
                            Copying your values into the config generator won't duplicate any of the syntax errors that may be there. I really suggest you try generating a fresh set even just to see what it looks like to compare to yours. And yes it will make switching over to RRF3 much easier.
                            • o_lampeundefined
                              o_lampe @fcwilt
                              Thanks @fcwilt
                              I read that line last night and I couldn't find sleep, because it makes totally sense.
                              It's like re-purposing a fan connector for something else:
                                1. you have to undefine the fan
                                1. now you can define it as LED-light colour changer or whatever
                              @Phaedrux
                              I moved the drive mapping right behind the M667 CoreXY definition.
                              Now, downing the coffee and back to the printer 🙂
                              The new config.g. I've also changed the extruder settings, since the E3d Titan is the only new part of the printer. It's run by a 1.8° 1708 pancake stepper, an improvement against the 0.9° original motor i guess.
                              config.g
                              • o_lampeundefined
                                o_lampe
                                One problem less, two new problems?
                                I tested the new config and behaviour was unchanged. G30 refuses to run before Z axis is homed. When it runs, it goes all over the place instead of probing where it should.
                                G30 X20 Y20 S2 ; is a valid code,right?
                                Then I checked my M667 setting again. Here in RepRap-Wiki and then in the Duet dozuki pages and look, what it says:
                                This command is deprecated in RRF 2.03 and later. Use M669 instead.
                                So I used M669 K1 and started homeAll.
                                G91                       ; relative mode
                                G1 X20 Y20 F4000
                                G1 F600
                                G1 S1 Z-300 F600
                                G1 Z5 F200
                                G30 X20 Y20 S-2
                                The tool still dances around the bed, but luckily didn't crash anywhere. The endposition of it can be seen here:
                                WHY does it do that?
                                The good news is, when I move to X0 Y0 Z5, the position is almost correct.
                                Now I can spend my time with mesh bed leveling and see what happens next.
                                //edit Should I go to absolute positioning (G90) before G30 in homeAll? Hold your breath, BRB...
                                • Vetiundefined
                                  Veti
                                  your homeall also uses old syntax.
                                  the S1 is depricated.
                                  also i dont understand why you are making your life so difficult, instead of using the correct generated homing files from the configurator.
                                  Using S-2 here is incorrect
                                  o_lampeundefined 2 Replies Last reply Reply Quote 0
                                  • o_lampeundefined
                                    o_lampe @Veti
                                    No, it's not, the dozuki wiki says, they are the same.
                                    G1 Xnnn Ynnn Znnn S0	Ignore endstops while moving.
                                    G1 Xnnn Ynnn Znnn S1	Sense endstops while moving. On Delta (only), axis letters refer to individual towers.
                                    G1 Xnnn Ynnn Znnn S2	Ignore endstops while moving. Also ignore if axis has not been homed. On Delta and CoreXY, axis letters refer to individual towers.
                                    G1 Xnnn Ynnn Znnn S3	Sense endstops while measuring axis length, and set the appropriate M208 limit to the measured position at which the endstop switch triggers.
                                    RRF_2.02 and later, BEFORE M452 Laser Mode.
                                    S parameter behaves as shown above.
                                    • Vetiundefined
                                      Veti @o_lampe
                                      @o_lampe
                                      since S has a double meaning, the use of H is encouraged.
                                      • o_lampeundefined
                                        o_lampe @Veti
                                        Maybe, but I also tried the other options, without any difference
                                        • o_lampeundefined
                                          o_lampe @Veti
                                          @o_lampe
                                          Just for your peace of mind, I'll try (again)
                                          Why I don't use the config tool is simple: In MY config, I know every line. Where it is and what it does (or should do)
                                          A generated file is different.
                                          Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                          • Vetiundefined
                                            Veti @o_lampe
                                            then at least look at the generated files so that you know how its supposed to be done
