    Duet 3 no power coming to bed.
    863
    • BoAundefined
      BoA @eddygara
      @eddygara Power for OUT should be connected here:
      eddygaraundefined 1 Reply Last reply Reply Quote 1
      • BoAundefined
        BoA @eddygara
        @eddygara BTW - the wires connected to OUT0 seem to bery thin. Are You certain they can handle the current? at 12V there might be a significant current flowing.
        • eddygaraundefined
          eddygara @BoA
          @BoA Ok just to make sure so i dont blow up my board, I already have the board connected from the psu via the "power in" your telling me to run another connection from the PSU right next to the PSU to Board line. In order to get power to the Bed?
          BoAundefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • BoAundefined
            BoA @eddygara
            @eddygara Exactly. Keep in mind that "power in" itself can be loaded with a high current 3 heaters 6A each, few fan outputs 2.5A and... steppers drivers... and some other stuff. So separate heatbed power input is for some flexibility in PSU setup and to avoid overloading connectors.
            • eddygaraundefined
              eddygara @BoA
              @BoA Thanks a lot man, I wish this guide wasn't so jumbled around to find this info, the people like you make this product worth it to use.
              • alankilianundefined
                alankilian
                If you want to power both the mainboard and the bed from the same power supply, add a jumper like this.
                (Wire in green)
                You also may have to wire a jumper from GND to GND.
                (This I don't know. I think someone will answer here.)
                eddygaraundefined 1 Reply Last reply Reply Quote 0
                • eddygaraundefined
                  eddygara @alankilian
                  @alankilian Ok this goes against what @boa just said..
                  BoAundefined 1 Reply Last reply Reply Quote 0
                    alankilian
                    Right. I got my information from here:
                    https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
                    • BoAundefined
                      BoA @eddygara
                      @eddygara How? It shows exactly what I said. Connect power from PSU to this input.
                        alankilian @eddygara
                        @eddygara said in Duet 3 no power coming to bed.:
                        I think this was interpeted to mean jumper Vin to the GND screw terminal "right next to the PSU to Board line"
                        • eddygaraundefined
                          eddygara @BoA
                          @BoA You told me to run 2 separate cables from the PSU directly to the board, you didn't say anything about jumping connections, from "Power in" to "Out0" in order to get power from the same PSU
                          • BoAundefined
                            BoA @eddygara
                            @eddygara But that is effectively the same connection.
                              @eddygara Electrically it's the same thing.
                              If you have a high-power bed, then run a second heavy wire all the way from the PSU.
                              Sorry for the confusion.
                              You're getting it!
                              • eddygaraundefined
                                @alankilian Ok cool sorry yall, not savy like this, The Duet Wifi was a simpler system to configure, and there was a lot more documentation on wiring, etc.
                                alankilianundefined BoAundefined 2 Replies Last reply Reply Quote 0
                                  @eddygara Your experience will help build even BETTER documentation for the next person trying this out.
                                  • BoAundefined
                                    BoA @eddygara
                                    @eddygara In general - it is all about wire size and required power. If Your bed require high power separate wire is better option than connectin everything with just one.
                                    If You know, that the wire connected to power in can handle all the current, then just make the jumpers between board terminals.
                                    But if You have average power bed ~200W it would take about 16.6A to run it, and wires on photo look like they can be a source of problems 😉 I would not go below 2.5mm^2 for such heatbed.
