Manual Grid Mesh Levelling
863
    Adamfilip @Veti
    @Veti exactly why im going back to a simple setup with manual mesh levelling
      Probe type P0 will work in a pinch.
      Even stall detection on Z may work for you if you meet a few requirements.
        fcwilt @Adamfilip
        @Adamfilip said in Manual Grid Mesh Levelling:
        Yes I have previously had BLtouch that got ripped off from a loose print.. then replaced it and it it died from a head crash, I had a Duet IR Sensor, same fate. so I tried Piezo and it worked for a while but isn't reliable.
        Wow. That is a one streak of bad luck.
        How about an inductive sensor - they are quite sturdy - and if you don't use a bed with any sort of magnets they work very well.
          Adamfilip
          I am using Spring Steel spring bed with magnets underneath
          undefined 1 Reply Last reply 23 Jan 2021, 19:41 Reply Quote 0
            fcwilt @Adamfilip
            Yeah - so am I - really like it but it means no more inductive sensor - back to the noisy BLTouch.
              Adamfilip
              I didnt realize the magnets interfered with inductive sensors, how does prusa get away with it?
              undefined 1 Reply Last reply 23 Jan 2021, 21:07 Reply Quote 0
                dc42 administrators @Adamfilip
                Perhaps they arrange the probe points to be away from the magnets?
                undefined 1 Reply Last reply 23 Jan 2021, 21:09 Reply Quote 1
                  Phaedrux Moderator @dc42
                  @dc42 said in Manual Grid Mesh Levelling:
                  Precisely this.
                    Adamfilip
                    So going back to my original ask.
                    to setup Grid Mesh leveling Manually. is there an easy way to do this?
                    undefined 1 Reply Last reply 23 Jan 2021, 21:53 Reply Quote 0
                      fcwilt @Adamfilip
                      Easy? That depends on what you consider easy.
                      My first reply to you covered how to set the Z probe configuration to allow bed probing when there is no Z probe.
                        Setting m558 P0 and then using g29 as normal will ask you to manually jog the nozzle to touch the bed at each point.
                          Adamfilip
                          Thank you @fcwilt & @Phaedrux I will give that a try
                          undefined 1 Reply Last reply 24 Jan 2021, 14:42 Reply Quote 0
                            fcwilt @Adamfilip
                            It works - I used to do it before I went ahead and installed a Z probe.
                            Have you considered a removable Z probe - then it cannot get damaged during normal operations.
                            undefined 1 Reply Last reply 24 Jan 2021, 15:17 Reply Quote 0
                              Veti
                              this one is very cheap and works well on my delta
                              https://de.aliexpress.com/item/32838312776.html
                                Adamfilip
                                with this, look like you need to run the hotend, cold I assume.
                                an interesting idea
                                  Adamfilip @fcwilt
                                  @fcwilt havent really but definately something to consider
                                  but so gar the G29 manual is working for me.
                                  Thank you for your help with this.
                                  undefined 1 Reply Last reply 24 Jan 2021, 15:18 Reply Quote 1
                                    fcwilt @Adamfilip
                                    Glad to help.
                                      garethky
                                      If you are running a Duet 3 with the SBC, I have released an automated way to probe around the magnets and still get a valid heightmap:
                                      https://forum.duet3d.com/topic/21213/rrf-mesh-level-custom-mesh-bed-probing-with-python?_=1611770964248
                                      19 out of 27
