    My wish : Inputs debouncing
    Firmware wishlist
    9
    34
    1.9k
    • alankilianundefined
      alankilian @fcwilt
      @fcwilt said in My wish : Inputs debouncing:
      It's hard to believe that the firmware doesn't de-bounce the inputs - it's simple code.
      Weeeellllll........ Not simple at all in fact.
      Here are two articles about debouncing:
      http://www.ganssle.com/debouncing.htm
      http://www.ganssle.com/debouncing-pt2.htm
      As @fcwilt says, it's a tradeoff between response-time and repetition rate and how long the bounce lasts.
      Still, I think it should be possible to implement without using up too much RAM or CPU time.
      There's some simple debouncing in the filament monitor code, but it's not configurable.
      • BoAundefined
        BoA @dc42
        @dc42 It looks like it is queued somehow.
        My current trigger macro:
        M300 P200
        if state.gpOut[1].pwm < 1
        	M42 P1 S1.0
        else
        	M42 P1 S0.75
        G4 S5
        	M81 S1
        else
        	M80
        so it should not trigger more often that ~5s, and trigger should not be active when macro executing. Meanwhile I just tested by just pressing button twice - second time about 1s after. And I got a first "beep", and after about 5s second "beep".
        So it looks that condition for trigger are checked during macro execution, and second trigger event is somehow queued.
          A Former User @BoA
          @BoA said in My wish : Inputs debouncing:
          i recall seeing someting similar ages ago
          • fcwiltundefined
            fcwilt @alankilian
            @alankilian said in My wish : Inputs debouncing:
            I thought you said debouncing wasn't simple 😉
            • BoAundefined
              BoA
              I connected scope and that are the results.
              Pressing button - nice a smooth (this is NC, so disconnecting contacts very good behavior)
              But releasing button (where contacts meeting again) is.. well... not good, but below 1ms in total.
              • o_lampeundefined
                o_lampe
                What, if you use the NO button pin? (if available).
                The bouncing is filtered at the begin of a macro, as somebody mentioned.
                • dragonnundefined
                  dragonn
                  Could you just add a capicator parallel to the button?
                  Sometimes the best solution is doing it in hardware
                  o_lampeundefined 1 Reply Last reply Reply Quote 1
                  • o_lampeundefined
                    o_lampe @dragonn
                    @dragonn said in My wish : Inputs debouncing:
                    An RC combo would be best
                      A Former User @o_lampe
                      @o_lampe said in My wish : Inputs debouncing:
                      there is already series resistance on the inputs, and a footprint for a cap if so inclined
                      • BoAundefined
                        BoA
                        I know this can be fixed in hardware, and I know how. The point was to fix it is SW which do not change input pin characteristics. And debouncing is not a rocket science to implement.
                        Also I am not very happy with though that I would have to take board out just to solder small cap, or even less happy to connect cap. hanging on wires.
                        But this is wish list, so... that is my wish (granted or not).
                        dragonnundefined 1 Reply Last reply Reply Quote 0
                        • dragonnundefined
                          dragonn @BoA
                          That depends on you application architecture, many embedded system without RTOS use something like a simple event loop and implementing debouncing in isn't so simple as it sounds. RRF works on RTOS but it started without it so probably most of the system is a event loop.
                          It can be of course done, they are many ways to do it. I just wanted to say that something simple from user stand point isn't often so simple in the software 😜
                          fcwiltundefined BoAundefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            fcwilt @dragonn
                            Why do you feel that way?
                            I developed the firmware for embedded process control systems for many years and the de-bounce code was quite straightforward.
                            • dragonnundefined
                              dragonn
                              As I said in the case when using an event loop, you can not just stop in and loop for some cycles and do nothing in the time if you have other things with still need to run. So you need some extra variables for tracking that your are in a debounce state, for how long and when you started and check them in every loop.
                              I am not saying it is hard, I wanted just to point out that probably is not a "5 minutes" job.
                              • fcwiltundefined
                                fcwilt @dragonn
                                You are correct - it is a 6.5 minute job. 😉
                                But with a RTOS it really is a piece of cake - a timed event and two variables per input and your good to go.
                                  alankilian @fcwilt
                                  @fcwilt I will be happy to review your merge request for input debouncing.
                                  Seriously, you seem to be the person for the job and many people could use this feature.
                                  • fcwiltundefined
                                    fcwilt @alankilian
                                    Color me confused. 😉
                                    I made no request for de-bouncing.
                                    I simply tried to make clear that what the OP, @BoA, seems to need, de-bouncing, was not hard to implement.
                                    I have always assumed it was already implemented as mechanical switches are a common element used with these boards.
                                    It seems it may not be and, if that is the case, I find that quite curious.
                                      alankilian
                                      I was just razzing you a little bit.
                                      Many people here have said it's not an easy thing to do (myself included) and you said it was simple, so I wanted to put you on the spot a little.
                                      I maintain that it will be a LOT of work to build this feature into this firmware for this application.
                                      • GCODEs for configuring which inputs should have debouncing
                                      • GCODE to configure setting for each input that wants debouncing
                                      • Debouncing code that uses almost no resources and works on many different board types and with many different input pins.
                                      • Safety dealing with everyone's misconfigured debouncing settings.
                                      • Changes to the configurator.
                                      • Testing............ For about half of forever.
                                      • fcwiltundefined
                                        fcwilt @alankilian
                                        I said that code needed for de-bouncing an input was simple and it is.
                                        I never said or meant to imply that the entire effort to add it to the firmware for the family of boards would be a small project.
                                        JOOC why do you think it would need to be a configurable feature?
                                          alankilian @fcwilt
                                          This is where I mistakenly thought you were saying it was a simple job.
                                          I apologize for my misunderstanding.
                                          It's good to have a variety of people discussing this kind of thing. It makes for a better product for everyone.
                                          You are all a great group of peers.
                                          Thank you for letting me get confused at times.
                                          fcwiltundefined 1 Reply Last reply Reply Quote 2
                                          • fcwiltundefined
                                            fcwilt @alankilian
                                            We all get confused, make mistakes, make assumptions, read things wrong, etc.
                                            It's just the nature of forums.
                                            Generally we as a group get it sorted in the end.
