My wish : Inputs debouncing
Firmware wishlist
9
34
1.8k
    BoA
    I have a button connected to one of io inputs, and trigger set on it. I noticed that tigger macro is executed more than once, and I suspect this is because lack of debouncing on inputs.
    Second option would be to ignore trigger in case it is actually executed.
    G4 S1 at the end of trigger macro does not help at all.
    ? 1 Reply Last reply 21 Jan 2021, 20:29 Reply Quote 0
      A Former User @BoA
      @BoA said in My wish : Inputs debouncing:
      you could perhaps start the macro with a M581 P-1 Tn to disable it immediately, ** if ** that is fast enough. (if needed you could dwell and re-enable it at the end of the macro as well)
        whopping pochard
        It does seem like there ought to be debounce enabled in the software! A very quick search on GitHub showed debounce on rotary encoder input and fan rpm input, but none that I could see associated with basic switch inputs.
        There are also debounce ICs if you want to hit it with the hardware hammer.
          A Former User
          might help to be specific about board and pin in use + type of switch.
          the duet2 has filter caps on all the endstop inputs, duet3 lists them as DNP
          undefined 1 Reply Last reply 22 Jan 2021, 13:19 Reply Quote 0
            BoA @A Former User
            @bearer It is DUET3, pin is io8.in
            Button type - GQ30PF-11E/G/24V/S - NC contacts used for io pin, and NO for PSU "priming" before M80 executed.
            undefined 1 Reply Last reply 22 Jan 2021, 13:32 Reply Quote 0
              fcwilt @BoA
              Firmware version?
              It's hard to believe that the firmware doesn't de-bounce the inputs - it's simple code.
              undefined undefined 3 Replies Last reply 22 Jan 2021, 13:32 Reply Quote 0
                BoA @fcwilt
                @fcwilt Firmware 3.2 - running standalone
                @fcwilt said in My wish : Inputs debouncing:
                Perhaps it does. It is a big button, perhaps more bouncy than others. Not sure. But I have trigger executed twice with one push. I might have some spare time this weekend to hook a scope on the pin and see what is going on exactly if that would help.
                undefined 1 Reply Last reply 22 Jan 2021, 13:37 Reply Quote 0
                  fcwilt @BoA
                  @BoA Thanks for the info.
                  It's possible that, if there is de-bounce code, it made an assumption about how long the bouncing would last. There's a trade off - the more bouncing you code for the slower the response time.
                  It would be interesting to see how your button performs.
                    AFAIR, changes on an input pin that activates a trigger are already disabled until the trigger macro has finished executing, because that was the intention. But I could be mistaken.
                    undefined 1 Reply Last reply 22 Jan 2021, 19:14 Reply Quote 0
                      alankilian @fcwilt
                      Weeeellllll........ Not simple at all in fact.
                      Here are two articles about debouncing:
                      http://www.ganssle.com/debouncing.htm
                      http://www.ganssle.com/debouncing-pt2.htm
                      As @fcwilt says, it's a tradeoff between response-time and repetition rate and how long the bounce lasts.
                      Still, I think it should be possible to implement without using up too much RAM or CPU time.
                      There's some simple debouncing in the filament monitor code, but it's not configurable.
                      undefined 1 Reply Last reply 22 Jan 2021, 20:12 Reply Quote 0
                        BoA @dc42
                        @dc42 It looks like it is queued somehow.
                        My current trigger macro:
                        M300 P200
                        if state.gpOut[1].pwm < 1
                        M42 P1 S1.0
                        else
                        M42 P1 S0.75
                        G4 S5
                        M81 S1
                        else
                        M80
                        so it should not trigger more often that ~5s, and trigger should not be active when macro executing. Meanwhile I just tested by just pressing button twice - second time about 1s after. And I got a first "beep", and after about 5s second "beep".
                        So it looks that condition for trigger are checked during macro execution, and second trigger event is somehow queued.
                        ? 1 Reply Last reply 22 Jan 2021, 20:01 Reply Quote 0
                          A Former User @BoA
                          i recall seeing someting similar ages ago
                            fcwilt @alankilian
                            @alankilian said in My wish : Inputs debouncing:
                            I thought you said debouncing wasn't simple 😉
                              BoA
                              I connected scope and that are the results.
                              Pressing button - nice a smooth (this is NC, so disconnecting contacts very good behavior)
                              But releasing button (where contacts meeting again) is.. well... not good, but below 1ms in total.
                                o_lampe
                                What, if you use the NO button pin? (if available).
                                The bouncing is filtered at the begin of a macro, as somebody mentioned.
                                  dragonn
                                  Could you just add a capicator parallel to the button?
                                  Sometimes the best solution is doing it in hardware
                                  undefined 1 Reply Last reply 26 Jan 2021, 11:19 Reply Quote 1
                                    o_lampe @dragonn
                                    @dragonn said in My wish : Inputs debouncing:
                                    An RC combo would be best
                                    ? 1 Reply Last reply 26 Jan 2021, 12:05 Reply Quote 0
                                      A Former User @o_lampe
                                      @o_lampe said in My wish : Inputs debouncing:
                                      there is already series resistance on the inputs, and a footprint for a cap if so inclined
                                        BoA
                                        I know this can be fixed in hardware, and I know how. The point was to fix it is SW which do not change input pin characteristics. And debouncing is not a rocket science to implement.
                                        Also I am not very happy with though that I would have to take board out just to solder small cap, or even less happy to connect cap. hanging on wires.
                                        But this is wish list, so... that is my wish (granted or not).
                                        undefined 1 Reply Last reply 26 Jan 2021, 15:44 Reply Quote 0
                                          dragonn @BoA
                                          That depends on you application architecture, many embedded system without RTOS use something like a simple event loop and implementing debouncing in isn't so simple as it sounds. RRF works on RTOS but it started without it so probably most of the system is a event loop.
                                          It can be of course done, they are many ways to do it. I just wanted to say that something simple from user stand point isn't often so simple in the software 😜
                                          undefined undefined 2 Replies Last reply 26 Jan 2021, 15:49 Reply Quote 0
                                          6 out of 34
