    My wish : Inputs debouncing
    Firmware wishlist
    9
    34
    1.9k
    • dragonnundefined
      dragonn
      As I said in the case when using an event loop, you can not just stop in and loop for some cycles and do nothing in the time if you have other things with still need to run. So you need some extra variables for tracking that your are in a debounce state, for how long and when you started and check them in every loop.
      I am not saying it is hard, I wanted just to point out that probably is not a "5 minutes" job.
      • fcwiltundefined
        fcwilt @dragonn
        @dragonn said in My wish : Inputs debouncing:
        You are correct - it is a 6.5 minute job. 😉
        But with a RTOS it really is a piece of cake - a timed event and two variables per input and your good to go.
        • alankilianundefined
          alankilian @fcwilt
          @fcwilt I will be happy to review your merge request for input debouncing.
          Seriously, you seem to be the person for the job and many people could use this feature.
          • fcwiltundefined
            fcwilt @alankilian
            @alankilian said in My wish : Inputs debouncing:
            Color me confused. 😉
            I made no request for de-bouncing.
            I simply tried to make clear that what the OP, @BoA, seems to need, de-bouncing, was not hard to implement.
            I have always assumed it was already implemented as mechanical switches are a common element used with these boards.
            It seems it may not be and, if that is the case, I find that quite curious.
              alankilian
              I was just razzing you a little bit.
              Many people here have said it's not an easy thing to do (myself included) and you said it was simple, so I wanted to put you on the spot a little.
              I maintain that it will be a LOT of work to build this feature into this firmware for this application.
              • GCODEs for configuring which inputs should have debouncing
              • GCODE to configure setting for each input that wants debouncing
              • Debouncing code that uses almost no resources and works on many different board types and with many different input pins.
              • Safety dealing with everyone's misconfigured debouncing settings.
              • Changes to the configurator.
              • Testing............ For about half of forever.
              • fcwiltundefined
                fcwilt @alankilian
                I said that code needed for de-bouncing an input was simple and it is.
                I never said or meant to imply that the entire effort to add it to the firmware for the family of boards would be a small project.
                JOOC why do you think it would need to be a configurable feature?
                  alankilian @fcwilt
                  @fcwilt said in My wish : Inputs debouncing:
                  It's hard to believe that the firmware doesn't de-bounce the inputs - it's simple code.
                  This is where I mistakenly thought you were saying it was a simple job.
                  I apologize for my misunderstanding.
                  It's good to have a variety of people discussing this kind of thing. It makes for a better product for everyone.
                  You are all a great group of peers.
                  Thank you for letting me get confused at times.
                  fcwiltundefined 1 Reply Last reply Reply Quote 2
                  • fcwiltundefined
                    fcwilt @alankilian
                    We all get confused, make mistakes, make assumptions, read things wrong, etc.
                    It's just the nature of forums.
                    Generally we as a group get it sorted in the end.
                      alankilian
                      Because there will be different kinds of physical switches with different bouncing characteristics as well as different latency needs.
                      We talked about debouncing in a thread where a member was building an encoder-based filament monitor and it was quite bouncy and needed a LOT of filtering. There was ANOTHER person with a filament monitor that was not quite so bouncy, AND in addition, produced many more pulses-per-second, so the debouncing needed to be significantly shorter in order not to miss genuine inputs.
                      I still maintain it's medium-to-difficult complexity job to implement something like this. (As a retired embedded-systems firmware and hardware engineer that is.)
                      • fcwiltundefined
                        fcwilt @alankilian
                        I wonder. Filament sensors aside I would not be surprised to find that real world needs, in most cases, would be served by a fixed set of de-bounce specs.
                        Some things, like filament sensors, would perhaps be best implemented with dedicated hardware.
                        So we have the same background - we can actually talk to one another! 😉
                        • BoAundefined
                          BoA @dragonn
                          @dragonn
                          I just wanted to say that something simple from user stand point isn't often so simple in the software
                          I know. I have over 13+ years of embedded development in my CV. Bare metal, RTOS, Linux, Qnx and VxWorks. 😉 I am just too lazy to setup RRF build at my home computer after all day of work 😉
                          • zaptaundefined
                            zapta @fcwilt
                            Is this because their timing need to be consistent?
                            • fcwiltundefined
                              fcwilt @zapta
                              @zapta said in My wish : Inputs debouncing:
                              Yes
                              The signal out from the sensor may be quite rapid but I've never studied filament sensors that actually monitor filament movement so I have no idea what the signal out actually is.
                              For things like push buttons operated by a person the response time is not critical and, if I recall, anything less than 250mS appears to be "instant".
                              De-bouncing in software is going to introduce an unavoidable delay before it can be determined that the input signal is valid and that any bouncing has ended.
                              If that delay would prevent the input device from working correctly than using hardware de-bounce will eliminate that delay.
