    duet3d sd not detected, rejects http, com5 denied
    2.6k
      dc42 administrators @radcad
      @radcad said in duet3d sd not detected, rejects http, com5 denied:
      now its saying connections timed out, and YAT is back to saying com5 error
      Does Windows Device Manager -> Ports show the Duet?
      btw you should set the YAT terminal settings to Line ending: LF only.
      radcadundefined 1 Reply Last reply Reply Quote 0
      • radcadundefined
        radcad @dc42
        Im not sure how to do that with YAT i am brand new to all this.
        The duet is showing in device manager.
          Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
          • radcadundefined
            radcad @Phaedrux
            @Phaedrux
            Thank you ok that is now changed. still not connecting tho.
            I notice when i re open the settings it reverts back to saying <cl><lf>
            • radcadundefined
              radcad
              Would it be better to power on the printer power supply and try to do all this wirelessly or keep working through the USB
                Well if things are working to the point where you can connect to the web interface than what exactly is still the problem?
                • radcadundefined
                  radcad @Phaedrux
                  @Phaedrux it is not connecting currently. i didnt know if the 24 volt for the printer did anything important. and ive read about some ground loop situation happening through USB but i dont really understand what they ment.
                    USB power is enough for testing.
                    Can you show a screen shot of your SD card folders and files?
                    Did you replace the contents of the /www folder with the file I linked?
                    When connected with YAT what happens when you send M552?
                    • radcadundefined
                      radcad @Phaedrux
                      @Phaedrux
                      what file type does the image need to be? i tried uploading bmp and jpeg both failed.
                      I cannot get YAT to connect com port 5 busy
                      I followed your instructions best that I could understand, everything should be in the right place.
                      It did connect again after I did what you said, after disconnect it would not reconnect.
                      • radcadundefined
                        radcad
                        Tried changing the port still same result.
                          Maybe it would be best to start from the top.
                          https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                          • radcadundefined
                            radcad @Phaedrux
                            @Phaedrux
                            for firmware update is this the file i need from the gethub
                            Duet2and3Firmware-3.2.zip
                              Only update the firmware if you've got a reliable connection to the web interface now.
                              If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                              That will get your firmware and DWC up to date.
                              For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                              https://configtool.reprapfirmware.org/Start
                              radcadundefined 2 Replies Last reply Reply Quote 0
                              • radcadundefined
                                radcad @Phaedrux
                                @Phaedrux
                                YAT and web interface are connected
                                • radcadundefined
                                  radcad @Phaedrux
                                  @Phaedrux
                                  so i put these files on the sd card then run the M commands ?
                                    No. Upload them to the system tab in the web interface. One zip file at a time. Start with 2.05.1. It will prompt you to update. And reboot.
                                    • radcadundefined
                                      radcad @Phaedrux
                                      @Phaedrux
                                      Failed to upload network error
                                      M552 S1 say wifi is ok
                                        And you're trying to upload it to the system tab?
                                        Can you go to the console tab and send M122 and copy and paste the results?
                                        • radcadundefined
                                          radcad @Phaedrux
                                          This post is deleted!
                                            In the system tab you'd find your config.g and the homing files, etc.
                                            That's where you would upload Duet2Firmware-2.05.1.zip
