    duet3d sd not detected, rejects http, com5 denied
    2.7k
    • radcadundefined
      radcad
      Would it be better to power on the printer power supply and try to do all this wirelessly or keep working through the USB
        Well if things are working to the point where you can connect to the web interface than what exactly is still the problem?
        radcadundefined 1 Reply Last reply Reply Quote 0
        • radcadundefined
          radcad @Phaedrux
          @Phaedrux it is not connecting currently. i didnt know if the 24 volt for the printer did anything important. and ive read about some ground loop situation happening through USB but i dont really understand what they ment.
            USB power is enough for testing.
            Can you show a screen shot of your SD card folders and files?
            Did you replace the contents of the /www folder with the file I linked?
            When connected with YAT what happens when you send M552?
            • radcadundefined
              radcad @Phaedrux
              @Phaedrux
              what file type does the image need to be? i tried uploading bmp and jpeg both failed.
              I cannot get YAT to connect com port 5 busy
              I followed your instructions best that I could understand, everything should be in the right place.
              It did connect again after I did what you said, after disconnect it would not reconnect.
              • radcadundefined
                radcad
                Tried changing the port still same result.
                  Maybe it would be best to start from the top.
                  https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                  • radcadundefined
                    radcad @Phaedrux
                    @Phaedrux
                    for firmware update is this the file i need from the gethub
                    Duet2and3Firmware-3.2.zip
                      Only update the firmware if you've got a reliable connection to the web interface now.
                      If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                      That will get your firmware and DWC up to date.
                      For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                      https://configtool.reprapfirmware.org/Start
                      radcadundefined 2 Replies Last reply Reply Quote 0
                      • radcadundefined
                        radcad @Phaedrux
                        @Phaedrux
                        YAT and web interface are connected
                        • radcadundefined
                          radcad @Phaedrux
                          @Phaedrux
                          so i put these files on the sd card then run the M commands ?
                            No. Upload them to the system tab in the web interface. One zip file at a time. Start with 2.05.1. It will prompt you to update. And reboot.
                            • radcadundefined
                              radcad @Phaedrux
                              @Phaedrux
                              Failed to upload network error
                              M552 S1 say wifi is ok
                                And you're trying to upload it to the system tab?
                                Can you go to the console tab and send M122 and copy and paste the results?
                                • radcadundefined
                                  radcad @Phaedrux
                                  This post is deleted!
                                    In the system tab you'd find your config.g and the homing files, etc.
                                    That's where you would upload Duet2Firmware-2.05.1.zip
                                    • radcadundefined
                                      radcad @Phaedrux
                                      @Phaedrux
                                      yes in the system tab under file management on the left, is where I tried to upload it, the file does not show up in other tabs
                                        And you're using the upload file button?
                                        Can you post a screen shot of the error?
                                        • radcadundefined
                                          radcad @Phaedrux
                                          @Phaedrux
                                          what file format do i need to save the screen shot as to upload it here?
                                            If you're on windows you can use the print screen button on your keyboard and paste that into paint and save it as a jpeg.
