    BLTouch Config.
    2.5k
      Ok, so the config for the BLTouch looks fine for 2.05
      What problems exactly are you having?
      Does the Bltouch work to home the Z axis?
      After homing, does sending the nozzle to Z0 lead to the nozzle just touching the bed surface?
      If you've gone through the test and calibrate page to set your XYZ offsets, have you now tried running G29 to get a map of your bed surface?
      https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
      Hélder Rochaundefined 2 Replies Last reply Reply Quote 1
      • Hélder Rochaundefined
        Hélder Rocha @Phaedrux
        @Phaedrux HI... the problem i am having is that, after i calibrate the offset on G31, defining the 0.0 position etc etc, when i do the first probe, the nozzle gets agaist the bed! If i increase or decrease the z value on the G31, it goes allways agaist the bed! Also, i dont haveproperly constant values when i try to define the z offset! It changes constantly. I read that a anti-backlash nut could help. I dont know!
          @Phaedrux Oh, and yes, Bltouch work to home the Z axis.
          After homing z, it stays on 5mm plus the z offset value above the bed.
          I made all the steps that are on that link you sent and yes, i made also the map. Dont know hou to use it, but yes, i made it!
          • Vetiundefined
            Veti @Hélder Rocha
            @Hélder-Rocha said in BLTouch Config.:
            do you mean it does not stop when its triggerd.
            or the nozzle hits the bed before its triggered?
            Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
              Hélder Rocha @Veti
              @Veti i beleave it stops when triggered, and goes up for 5mm. At this moment the Z offset is marked with 1,90. So, after it makes the probe, Z ascend 5mm, in the panel i can check z height is 6,90 (5mm+1,90)... all good, but if i down it 5mm, it stops on Z 1,90, but against the bed. After slice a test cube, just to see if it runs ok, the nozzle does not get the 0,02 mm height i nead for the fisrt layer, because its touching the bed!! But Veti, i starded to download the new versions of firmware, i all strt over. Lets forget this for now. Different issues just appear. Ill open a different topic. Tks a lot for your help.
              • Vetiundefined
                Veti
                this means that your trigger height is incorrect
                • shubharora734undefined
                  shubharora734
                  • Vetiundefined
                    Veti @shubharora734
                    @shubharora734
                    so decrease your trigger height by 1,9
                      Hélder Rocha @Veti
                      @Veti so, you suggest i put my offset in 0.0? But look Veti, i just started to update my firmware to 3.0 and found my first problems. If you care to help me on other topic i created in "firmaware instalation categories", ill be thankfull. many tanks
                      • Vetiundefined
                        Veti @Hélder Rocha
                        please update to 3.2 there is no point in staying on 3.0
                          Hélder Rocha @Veti
                          @Veti all the surch i made, no one advices to go from 2.05 to 3,2 directly! The sugestion is to go first to 3.0, and then update to 3.1 or 3.2! I dont know nothing about this, just following the masters 🙂
                          • Vetiundefined
                            Veti
                            you have to go to 3.2 because you cant flash directly. that is why you need to go to 3.0 first.
                            there is no reason to stay on 3.0
                              How do you have the BLTouch installed? Can you post a photo?
                              When mounted correctly the base of the probe body should be ~8mm above the nozzle tip, which will result in a trigger height of ~2mm.
                                @Phaedrux Nice... realy dont know if i have it right, but i´ll keep this tip for later. After i crack my head with the firmware updates! Eh eh eh
                                  Hélder Rocha
                                  Hi good people. My firmware is allready updated and working fine. Some others things ill have to do in the Macros i have but it stays for later. Now, about my Bltouch i have the follow problem. Independently off the value i put in G31, after the probe is done, the nozzle allways stays at 0,40 mm from the bed!!! I´ll show here my config file, for you ti check if is there anything missplaced.
                                  Sorry, dont know how to use </>!
                                  ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 31 2021 16:45:04 GMT+0000 (Hora padrão da Europa Ocidental)
                                  M550 P"DuetCR10" ; set printer name
                                  M918 P1 E4 F2000000 ; configure direct-connect display
                                  M551 P"Stacus631" ; set password
                                  M552 S1 ; enable network
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P0 S0 ; physical drive 0 goes backwards
                                  M92 X80.00 Y80.00 Z400.00 E422.7 ; set steps per mm
                                  M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
                                  M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                  M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X300 Y300 Z400 S0 ; set axis maxima
                                  M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                                  M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                  G31 P500 X-40 Y-10 Z0 ; set Z probe trigger value, offset and trigger height
                                  M557 X15:250 Y15:250 S20 ; define mesh grid
                                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4700 ; configure sensor 0 as thermistor on pin bedtemp
                                  M307 H0 R0.457 C360.7 D3.84 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
                                  M143 H0 S120 ; set temperature limit for heater 0 to 150C
                                  M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                                  M143 H1 S290 ; set temperature limit for heater 1 to 290C
                                  M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                  M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
                                  • Vetiundefined
                                    Veti
                                    this is wrong. you need to find the correct beta value.
                                    you have not put in your actual value. after changing this, you need to restart the duet.
                                      Hélder Rocha @Veti
                                      @Veti Hi, thank you for the reply.
                                      In the first point you mention, how do i determine the beta value?
                                      In the second point, yes, i know. I have allready stablish "z" with the value the DWC determinate after G30 S-. In fact, i´ve give it different vlues, seen the first time, it stys 0,40 above the bed. I tried to low the nozzle a litle, increasing the "Z" value, but it stays allways at 0,40... regardless the value i have on "Z"!
                                        Hélder Rocha @Hélder Rocha
                                        @Hélder-Rocha "G30 S-1"
                                        • Vetiundefined
                                          Veti
                                          so modify the G31 in the config and test the homing.
                                            Hélder Rocha @Veti
                                            @Veti i have done it several times...i´ve defined Z to 0.23, the first value obtained with G30 S-1. After restart the duet, and do homing, the zozzle stoped 0,40 mm above the bed, but the Z value on the DWC is 0,23mm!
                                            After that, i encreased the Z value 10 by 10 to check if the nozzle wold get closer to the bed! But nothing, it stays at 0,40mm all the times.
