BLTouch Config.
@Veti all the surch i made, no one advices to go from 2.05 to 3,2 directly! The sugestion is to go first to 3.0, and then update to 3.1 or 3.2! I dont know nothing about this, just following the masters
you have to go to 3.2 because you cant flash directly. that is why you need to go to 3.0 first.
there is no reason to stay on 3.0 -
How do you have the BLTouch installed? Can you post a photo?
When mounted correctly the base of the probe body should be ~8mm above the nozzle tip, which will result in a trigger height of ~2mm.
@Phaedrux Nice... realy dont know if i have it right, but i´ll keep this tip for later. After i crack my head with the firmware updates! Eh eh eh
Hi good people. My firmware is allready updated and working fine. Some others things ill have to do in the Macros i have but it stays for later. Now, about my Bltouch i have the follow problem. Independently off the value i put in G31, after the probe is done, the nozzle allways stays at 0,40 mm from the bed!!! I´ll show here my config file, for you ti check if is there anything missplaced.
Sorry, dont know how to use </>!
; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 31 2021 16:45:04 GMT+0000 (Hora padrão da Europa Ocidental); General preferences
M550 P"DuetCR10" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M551 P"Stacus631" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E422.7 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-40 Y-10 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:250 Y15:250 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4700 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 R0.457 C360.7 D3.84 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S120 ; set temperature limit for heater 0 to 150C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S290 ; set temperature limit for heater 1 to 290C; Fans
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
@Hélder-Rocha said in BLTouch Config.:
this is wrong. you need to find the correct beta value.
you have not put in your actual value. after changing this, you need to restart the duet.
@Veti Hi, thank you for the reply.
In the first point you mention, how do i determine the beta value?In the second point, yes, i know. I have allready stablish "z" with the value the DWC determinate after G30 S-. In fact, i´ve give it different vlues, seen the first time, it stys 0,40 above the bed. I tried to low the nozzle a litle, increasing the "Z" value, but it stays allways at 0,40... regardless the value i have on "Z"!
@Hélder-Rocha "G30 S-1"
so modify the G31 in the config and test the homing.
@Veti i have done it several times...i´ve defined Z to 0.23, the first value obtained with G30 S-1. After restart the duet, and do homing, the zozzle stoped 0,40 mm above the bed, but the Z value on the DWC is 0,23mm!
After that, i encreased the Z value 10 by 10 to check if the nozzle wold get closer to the bed! But nothing, it stays at 0,40mm all the times. -
the config you see, i have "Z" value at "0", because i put it to "0" before a leave my printer last night. I intent to restart the configuration today.
post your homeall
@Veti can you tell me how to use the </>? I dont know how and i´ll like to do it correctly!
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 31 2021 16:45:05 GMT+0000 (Hora padrão da Europa Ocidental)
G91 ; relative positioning
G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-305 Y-305 F240 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X200 Y150 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
G31 P25 X-40 Y-10 Z1.20 ; Set Z probe trigger value, offset and trigger height
your original value was far bigger
@Veti it was not workig correctly either with the old firmware. After update the firmware, i already tried with 1.60 and it stops at 0,40mm.... the question is: Dont matter the value i define in G31 "Z", the probe will allways stop at 0,40 mm plus 5mm(because G1 Z5 F100 ) above the bed. If i down the nozzle by 5mm, in the DWC will show the "Z" Value defined on G31, but when i go measure with the wedge feeler, it is 0,40mm above the bed. Allways!
0,40
do you use , or . ?
since you never posted the config with a value in it its hard to tell -
@Veti yes... is with "."
send the G31 command to verify that your offset is put in correctly
When you click that button in the post creation window it adds a section between three dots above and below. Put your code in the middle where it says code_text.
code_text
