    Duet 3 - Cooling fan configurations
    2.4k
      A Former User @kj3d
      @kj3d
      I was just looking here https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
      and this section made me curious:
      Hnn:nn:nn... Enable thermostatic mode and select heaters monitored. H-1 disables thermostatic mode. (In RRF_3 relates to the sensor number(s) created by M308, not the temperature sensor pin number on the board)
        A Former User @Phaedrux
        @Phaedrux said in Duet 3 - Cooling fan configurations:
        The tool fan slider will mirror what your part cooling fan is set to.
        Does that make any sense or doesn´t that mean that the "part cooling fan" should be kicked out forever once and for all from the firmware?
        EDIT: Moved, see conversation
          I don't know what you mean by that.
            If that is the same fan:
            why is it occupying screen-space 2 times? hey, I do not know, I am a single-extruder-single-tool-user, maybe somebody can explain it to me - could be that there is a benefit for multi-tool-users I guess?
              As I explained, in machines with multiple tools the tool fan slider will always control the fan of the currently selected tool.
              In machines with only a single tool you can hide either the tool fan or the print cool fan slider if you wish with the change visibility button.
                @Phaedrux
                Maybe for our kind (the OP and me) why not only have within DWC "Tool Fan (your current print cool fan)" and that´s it? If it is really the same why have 2 sliders when you can do it with one. If you insist to have 2 sliders then they are not the same? Or am I wrong here (maybe time for a 2nd tool to try out and see?)
                  Because the Duet is built around the concept of flexible tools. Some of those decisions and functions only become usefully apparent when multiple tools are apparent.
                  I would agree that it would be clearer for new users with only a single tool to show only a single slider, but it's really not such a big deal is it? You can hide it if you wish. There is a button right above it that says change visibility.
                  Here's another use case that might make more sense even if you have only a single tool, you may have 2 part cooling fans. left and right for instance. The tool fan will control the fans configured in the tool definition, so both fans at once. But you would also have an independant slider for each fan in case you wanted to adjust only one or the other.
                    @Phaedrux
                    Thanks for the example! So basically "all" tool fans i guess.
                    EDIT: I moved this side-talk to https://forum.duet3d.com/topic/21300/tool-fans-representation-within-dwc
                    But I deraild now what the OP had as problem! He actually sat down and tried different values and there seems to be some intertwining with the fans anyway (let´s keep DWC out from now on):
                    If the temperature on the tool fan is below the set point (35c) then only Fan 0 (part cooling fan) turns on. If the temp on the hotend is above 35c then moving the slider in the DWC ui changes the speed in both fans
                    Sorry @kj3d
                      @kj3d Can you post your config.g as copy and paste text?
                      Can you also send M122 and post the results, along with M98 P"config.g"?
                      your config appears to be correct. Usually if the heat sink fan is changing speed along with the part cooling fan that would indicate either the tool definition is incorrectly mapping both fans, or there is a wiring problem.
                      kj3dundefined 3 Replies Last reply Reply Quote 0
                        A Former User @kj3d
                        @kj3d
                        If you happen to have a permanent marker or a sticker I like to put that on the fan, that helps to be able to vaguely judge the running speed beside wetting a finger and putting it in front of it
                        • kj3dundefined
                          kj3d @Phaedrux
                          @Phaedrux
                          config.g:
                          ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 27 2021 12:22:57 GMT+0000 (Greenwich Mean Time)
                          M550 P"KJ3D Delta" ; set printer name
                          M665 R227 L440 B185 H405 ; Set delta radius, diagonal rod length, printable radius and homed height
                          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                          M551 P"freddy5363" ; set password
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                          M92 X80.00 Y80.00 Z80.00 E335.00 ; set steps per mm
                          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
                          M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 Z0 S1 ; set minimum Z
                          M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
                          M574 Y2 S1 P"io2.in" ; configure active-high endstop for high end on Y via pin io2.in
                          M574 Z2 S1 P"io3.in" ; configure active-high endstop for high end on Z via pin io3.in
                          M558 P5 R0.4 C"io4.in+io4.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
                          ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                          G31 P500 X0 Y0 Z-0.232 ; set Z probe trigger value, offset and trigger height
                          M557 R185 S20 ; define mesh grid
                          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                          M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                          M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                          M106 P1 S1 H1 T35 ; set fan 1 value. Thermostatic control is turned on
                          • kj3dundefined
                            kj3d @Phaedrux
                            @Phaedrux
                            M112 produced an interesting result (sent via consel)
                            kj3dundefined 1 Reply Last reply Reply Quote 0
                            • kj3dundefined
                              kj3d @kj3d
                              M122 was much better!!
                              KJ3D Delta
                              Send code...
                              Status
                              Idle
                              Mode: FFF
                              Tool Position
                              X
                              0.0
                              Y
                              0.0
                              Z
                              399.04
                              Extruder Drives
                              Drive 0
                              0.0
                              Speeds
                              Requested Speed
                              0 mm/s
                              Top Speed
                              0 mm/s
                              Sensors
                              Vin
                              23.9 V
                              V12
                              12.1 V
                              MCU Temperature
                              29.5 C
                              Z-Probe
                              0
                              Tools
                              Extra
                              Control All
                              Tool Heater Current Active Standby
                              Tool 0
                              T0 - Sunlu - White Heater 1
                              off 13.1 C
                              0
                              0
                              Bed Heater 0
                              off 15.4 C
                              0
                              0
                              Temperature Chart
                              M122
                              29/01/2021, 18:43:40 M122
                              RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
                              Board ID: 08DJM-956BA-NA3TJ-6JKD4-3S46M-KB8USUsed output buffers: 1 of 40 (12 max)
                              Static ram: 154572
                              Dynamic ram: 161276 of which 44 recycled
                              Exception stack ram used: 440
                              Never used ram: 76884
                              Tasks: NETWORK(ready,236) ETHERNET(blocked,444) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1436) CanClock(blocked,1428) TMC(blocked,80) MAIN(running,4532) IDLE(ready,80)
                              Owned mutexes:
                              Last reset 00:00:54 ago, cause: software
                              Last software reset at 2021-01-29 18:42, reason: User, spinning module GCodes, available RAM 77060 bytes (slot 2)
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                              Error status: 0
                              Free file entries: 10
                              MCU temperature: min 28.2, current 29.4, max 29.5
                              Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                              Driver 0: standstill, reads 5931, writes 19 timeouts 0, SG min/max 0/166
                              Driver 1: standstill, reads 5932, writes 19 timeouts 0, SG min/max 0/160
                              Driver 2: standstill, reads 5932, writes 19 timeouts 0, SG min/max 0/158
                              Driver 3: standstill, reads 5938, writes 14 timeouts 0, SG min/max 0/0
                              Driver 4: standstill, reads 5942, writes 11 timeouts 0, SG min/max 0/0
                              Driver 5: standstill, reads 5942, writes 11 timeouts 0, SG min/max 0/0
                              Date/time: 2021-01-29 18:43:40
                              Slowest loop: 8.89ms; fastest: 0.14ms
                              Hiccups: 0(0), FreeDm: 375, MinFreeDm: 369, MaxWait: 13123ms
                              === MainDDARing ===
                              Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                              === AuxDDARing ===
                              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              SBC is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 10.27ms; fastest: 0.03ms
                              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                              HTTP sessions: 1 of 8
                              • Ethernet -
                                State: active
                                Error counts: 0 0 0 0 0
                                === CAN ===
                                Messages sent 219, longest wait 0ms for type 0
                                === Linux interface ===
                                State: 0, failed transfers: 0
                                Last transfer: 54411ms ago
                                RX/TX seq numbers: 0/1
                                SPI underruns 0, overruns 0
                                Number of disconnects: 0
                                Buffer RX/TX: 0/0-0
                                29/01/2021, 18:42:49 Connection established
                                29/01/2021, 18:42:49 Connection interrupted, attempting to reconnect...
                                29/01/2021, 18:40:57 Emergency stop, attemping to reconnect...
                                Phaedrux Moderator @kj3d
                                @kj3d said in Duet 3 - Cooling fan configurations:
                                Let's update your firmware.
                                If you still have access to DWC. Upload these zip files, one at a time. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                                https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                                That will get your firmware and DWC up to date.
                                • kj3dundefined
                                  kj3d @Phaedrux
                                  M98 P"config.g"?
                                  • kj3dundefined
                                    kj3d @Phaedrux
                                    @Phaedrux
                                    Please confirm how the files are uploaded (DWC is connected)
                                      Go to the system tab and use the upload file button.
                                      • kj3dundefined
                                        kj3d @Phaedrux
                                        @Phaedrux
                                        Thanks
                                        • kj3dundefined
                                          kj3d @kj3d
                                          Updates done (very impressed at how easy that was!!)
                                          • kj3dundefined
                                            kj3d
                                            Will test the revised Firmware in the morning and let you know how it is
                                            Thanks for everyone's help today.
