    Artillery Genius Duet 2 Wifi Configuration
    Using Duet Controllers
    artillery genius conversation
    3.5k
    • d0minik96undefined
      d0minik96
      Also Extruder temp is shown as 200 °C. 😞
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sat Jan 23 2021 18:37:34 GMT+0100 (Mitteleuropäische Normalzeit)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Dominik's 3D"                           ; set printer name
      M669 K2                                        ; select CoreXY mode
      M551 P"test"                                   ; set password
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 Z16 I0                                    ; configure microstepping without interpolation
      M350 X16 Y16 E16 I1                            ; configure microstepping with interpolation
      M92 X80.121 Y80.121 Z399.78 E445.00              ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E300.00           ; set maximum instantaneous speed changes (mm/min)
      M203 X1200.00 Y1200.00 Z150.00 E240.00        ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z20.00 E1500.00           ; set accelerations (mm/s^2)
      M906 X1050 Y1050 Z1050 E600 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X220 Y220 Z250 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                       ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; sensor 1
      ;M308 S1 P"spi.cs1" Y"rtd-max31865"             ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                   ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1 T45                              ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M501                                           ; load saved parameters from non-volatile memory
      • Vetiundefined
        Veti
        @d0minik96 said in Artillery Genius Duet 2 Wifi Configuration:
        are you sure the thermistor setting is correct?
        why do you have this commented out?
        d0minik96undefined 1 Reply Last reply Reply Quote 0
          d0minik96 @Veti
          @Veti i set it upo wrong with the configurator. it should be thermistor 1 in merlin like the heatbed. heatbed sensor shows 20°C so it works. Not sure what i did wrong with the extruder thermistor
          • Vetiundefined
            Veti
            is it 200 or 2000 ?
              d0minik96 @Veti
              @Veti 2000
                d0minik96
                So i just did some try and error. I have 2 Z motors. They worked against each other. Now it they work right.
                y axis works fine. When i move X-axis z Axis moves aswell. I move the motors without homing atm.
                I plugged all motors off and tried each motor alone with the y axis. they worked all great. not sure why they move together when i move z or y axis alone in the dashboard. U have any suggestions what i can check ?
                • Vetiundefined
                  Veti
                  2000 means open circuit.
                  so check the wiring.
                  measure the resistance with a multimeter
                  d0minik96undefined 2 Replies Last reply Reply Quote 0
                    d0minik96 @Veti
                    @Veti ok!
                      d0minik96 @Veti
                      @Veti Both Thermistors work now! Thank you very much 🙂
                      U have any idea why both x and z axis move when i try to move one of them ?
                      • Vetiundefined
                        Veti
                        i could be because of mesh compensation
                        how are you moving the axis?
                          d0minik96 @Veti
                          @Veti I just do the M564 S0 H0 Command so i can move axis without homing
                          and than i just go to dashboard and click on the bottons to move the axis manual. I did not active do a mesh bed compensation, is there a way to check in config if there is any setting done ?
                          • Vetiundefined
                            Veti
                            in what way is the z axis moving when you move the x
                            • Vetiundefined
                              Veti
                              post your current config.g m122 and a picture of your wiring
                                d0minik96 @Veti
                                @Veti The movement of second axis is not random, if i move pos the second axis does as well. when i move neg. it moves neg. aswell.
                                M112:
                                m122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                                Board ID: 0JD0M-9P6M2-NW4SN-6J9D2-3SD6S-9VT7M
                                Used output buffers: 3 of 24 (18 max)
                                Static ram: 23460
                                Dynamic ram: 73284 of which 24 recycled
                                Never used RAM 15312, free system stack 189 words
                                Tasks: NETWORK(ready,160) HEAT(blocked,309) MAIN(running,450) IDLE(ready,19)
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:06:15 ago, cause: power up
                                Last software reset at 2021-01-29 19:39, reason: User, GCodes spinning, available RAM 15276, slot 2
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                MCU temperature: min 21.1, current 28.5, max 29.1
                                Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: position 0, standstill, SG min/max not available
                                Driver 1: position 0, standstill, SG min/max not available
                                Driver 2: position 0, standstill, SG min/max not available
                                Driver 3: position 0, standstill, SG min/max not available
                                Driver 4: position 0, standstill, SG min/max not available
                                Driver 5: position 0
                                Driver 6: position 0
                                Driver 7: position 0
                                Driver 8: position 0
                                Driver 9: position 0
                                Driver 10: position 0
                                Driver 11: position 0
                                Date/time: 2021-01-29 20:09:26
                                Cache data hit count 464421949
                                Slowest loop: 6.16ms; fastest: 0.20ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 2.9ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 15.17ms; fastest: 0.00ms
                                HTTP sessions: 1 of 8
                                • WiFi -
                                  Network state is active
                                  WiFi firmware version 1.21RC2
                                  WiFi MAC address 40:f5:20:1d:c0:8e
                                  WiFi Vcc 3.45, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 16912
                                  WiFi IP address 192.168.178.160
                                  WiFi signal strength -51dBm, mode none, reconnections 0, sleep mode modem
                                  Clock register ffffffff
                                • Vetiundefined
                                  Veti
                                  did you plug in x motor into the second z header by accident?
                                  you did not update your wifi firmware
                                    d0minik96
                                    Could this be the problem ? When i click on Compensation and Callibration it says: Compensation in use: none.
                                    Im 100% Sure i use the right motor in the right plugs. Tested the connection like an hour ago and tested every motor while i plugged off all others
                                      Upload this zip file to the system tab in DWC.
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                                        d0minik96 @Phaedrux
                                        @Phaedrux I will test it after installation!
                                        • Vetiundefined
                                          Veti
                                            d0minik96 @Phaedrux
                                            @Phaedrux Reply how long does the installation normally take ? Now i cant connect. Does it save my Networksettings normally ?
