    Artillery Genius Duet 2 Wifi Configuration
    Using Duet Controllers
    artillery genius conversation
    3.5k
    • Vetiundefined
      Veti
      @d0minik96 said in Artillery Genius Duet 2 Wifi Configuration:
      Also Extruder temp is shown as 200 °C
      are you sure the thermistor setting is correct?
      why do you have this commented out?
      M308 S1 P"spi.cs1" Y"rtd-max31865"
      d0minik96undefined 1 Reply Last reply Reply Quote 0
      • d0minik96undefined
        d0minik96 @Veti
        @Veti i set it upo wrong with the configurator. it should be thermistor 1 in merlin like the heatbed. heatbed sensor shows 20°C so it works. Not sure what i did wrong with the extruder thermistor
        • Vetiundefined
          Veti
          is it 200 or 2000 ?
            d0minik96 @Veti
            @Veti 2000
              d0minik96
              So i just did some try and error. I have 2 Z motors. They worked against each other. Now it they work right.
              y axis works fine. When i move X-axis z Axis moves aswell. I move the motors without homing atm.
              I plugged all motors off and tried each motor alone with the y axis. they worked all great. not sure why they move together when i move z or y axis alone in the dashboard. U have any suggestions what i can check ?
              • Vetiundefined
                Veti
                2000 means open circuit.
                so check the wiring.
                measure the resistance with a multimeter
                d0minik96undefined 2 Replies Last reply Reply Quote 0
                  d0minik96 @Veti
                  @Veti ok!
                    d0minik96 @Veti
                    @Veti Both Thermistors work now! Thank you very much 🙂
                    U have any idea why both x and z axis move when i try to move one of them ?
                    • Vetiundefined
                      Veti
                      i could be because of mesh compensation
                      how are you moving the axis?
                        d0minik96 @Veti
                        @Veti I just do the M564 S0 H0 Command so i can move axis without homing
                        and than i just go to dashboard and click on the bottons to move the axis manual. I did not active do a mesh bed compensation, is there a way to check in config if there is any setting done ?
                        • Vetiundefined
                          Veti
                          in what way is the z axis moving when you move the x
                          • Vetiundefined
                            Veti
                            post your current config.g m122 and a picture of your wiring
                              d0minik96 @Veti
                              @Veti The movement of second axis is not random, if i move pos the second axis does as well. when i move neg. it moves neg. aswell.
                              M112:
                              m122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                              Board ID: 0JD0M-9P6M2-NW4SN-6J9D2-3SD6S-9VT7M
                              Used output buffers: 3 of 24 (18 max)
                              Static ram: 23460
                              Dynamic ram: 73284 of which 24 recycled
                              Never used RAM 15312, free system stack 189 words
                              Tasks: NETWORK(ready,160) HEAT(blocked,309) MAIN(running,450) IDLE(ready,19)
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:06:15 ago, cause: power up
                              Last software reset at 2021-01-29 19:39, reason: User, GCodes spinning, available RAM 15276, slot 2
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU temperature: min 21.1, current 28.5, max 29.1
                              Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: position 0, standstill, SG min/max not available
                              Driver 1: position 0, standstill, SG min/max not available
                              Driver 2: position 0, standstill, SG min/max not available
                              Driver 3: position 0, standstill, SG min/max not available
                              Driver 4: position 0, standstill, SG min/max not available
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Date/time: 2021-01-29 20:09:26
                              Cache data hit count 464421949
                              Slowest loop: 6.16ms; fastest: 0.20ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 2.9ms, write time 0.0ms, max retries 0
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 15.17ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              • WiFi -
                                Network state is active
                                WiFi firmware version 1.21RC2
                                WiFi MAC address 40:f5:20:1d:c0:8e
                                WiFi Vcc 3.45, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 16912
                                WiFi IP address 192.168.178.160
                                WiFi signal strength -51dBm, mode none, reconnections 0, sleep mode modem
                                Clock register ffffffff
                              • Vetiundefined
                                Veti
                                did you plug in x motor into the second z header by accident?
                                you did not update your wifi firmware
                                  d0minik96
                                  Could this be the problem ? When i click on Compensation and Callibration it says: Compensation in use: none.
                                  Im 100% Sure i use the right motor in the right plugs. Tested the connection like an hour ago and tested every motor while i plugged off all others
                                    Upload this zip file to the system tab in DWC.
                                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                                      d0minik96 @Phaedrux
                                      @Phaedrux I will test it after installation!
                                      • Vetiundefined
                                        Veti
                                          d0minik96 @Phaedrux
                                          @Phaedrux Reply how long does the installation normally take ? Now i cant connect. Does it save my Networksettings normally ?
                                            d0minik96 @Veti
                                            @Veti The current config is the one i posted a bit upper in this thread. did not change anything since than and i cant connect to my board due to the update right now
